path: root/cpu
2008-02-14Remove duplicate defines for ARRAY_SIZEKumar Gala
2008-02-12QE: Move FDT support into a common fileKumar Gala
Move the flat device tree setup for QE related devices into a common file shared between 83xx & 85xx platforms that have QE's. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-02-07Device tree updatesJohn Rigby
Changes to match 5121 device tree going mainline in 2.6.25. Change OF_SOC from "soc5121" to plain "soc". Remove unneeded "ref-frequency" fixups. Remove "address" enetaddr fixup. Add bus-frequency fixup for old OF_SOC so old kernels with old device trees will work with new u-boot with 66MHz IPS clock Signed-off-by: John Rigby <jrigby@freescale.com>
2008-02-04ARM: S3C24x0 SoC NAND controller supportHarald Welte
This patch adds NAND support to the S3C24x0 SoC code in u-boot Signed-off-by: Harald Welte <laforge@openmoko.org>
2008-02-04ARM: s3c24xx: Multiple serial port supportHarald Welte
This patch adds support for CONFIG_SERIAL_MULTI on s3c24x0 CPU's Signed-off-by: Harald Welte <laforge@openmoko.org>
2008-02-04ARM: arm920t: Allow use of 'gd' pointer from IRQHarald Welte
This patch allows us to use the 'gd' pointer (and thus environment and everything else associated with it) from interrupt context on arm920t. Signed-off-by: Harald Welte <laforge@openmoko.org>
2008-02-04ARM: arm920/s3c24xx: IRQ demulitplexer callbackHarald Welte
This patch adds a IRQ demultiplexer callback to the arm920 cpu core code, plus a stub implementation of it for the S3C2410. The purpose is to allow arm920t implementations such as the s3c24x0 to implement interrupt handlers in u-boot without having to touch core arm920t code. Signed-off-by: Harald Welte <laforge@openmoko.org>
2008-02-03MMC for PXA 27X (resubmit)stefano babic
MMC support for X_Scale PXA is broken and does not work. Mainly, the mmc_init() function cannot recognize current SD/MMC cards. There were already some patches around the world but none of them was merged into the official u-boot tree. This patch makes order fixing this issue. Resubmit after code cleanup. Applied and tested on PXA 270 (TrizepsIV module). Signed-off-by: Stefano Babic <sbabic@denx.de>
2008-01-23Merge ../custodiansWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-ixpWolfgang Denk
2008-01-23Coding Style Cleanup; update CHANGELOGWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-coldfireWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-mpc85xxWolfgang Denk
2008-01-18IXP: enable RTSMichael Schwingen
enables the RTS signal with CONFIG_SERIAL_RTS_ACTIVE. No handshaking is done, but the active RTS signal allows to connect to the target using a PC which is using RTS/CTS handshake, and does no harm if the PC is set to ignore RTS. Signed-off-by: Michael Schwingen <michael@schwingen.org>
2008-01-18IXP: add dynamic microcode addrJean-Christophe PLAGNIOL-VILLARD
allow to load the microde from flash or ram by download it through the serial or other. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Stefan Roese <sr@denx.de>
2008-01-18load ixp42x NPE firmware from separate flash block, remove dead codeMichael Schwingen
Hi, the following patch adds support to move the IXP42X NPE firmware to a separate flash block, whose start address is defined in CONFIG_IXP4XX_NPE_EXT_UCODE_BASE. Using that, it is possible to build NPE-enabled u-boot without copyright problems due to the NPE firmware. I hope the patch applies, I get whitespace-related differences in the NPE files due to trailing whitespace in the original versions. Signed-off-by: Michael Schwingen <michael@schwingen.org> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-01-17Merge branch 'kumar'Andy Fleming
2008-01-17ColdFire: Add MCF547x_8x cpu archTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
2008-01-17ColdFire: Add MCF5227x cpu and MCF52277EVB support-2TsiChungLiew
2008-01-17ColdFire: Add M5373EVB platform support - 2TsiChungLiew
2008-01-17ColdFire: PCI and misc updates for MCF5445xTsiChungLiew
2008-01-17mpc83xx: Fix the fatal conflict of mergeDave Liu
The commit 9e89647889cd4b5ada5b5e7cad6cbe55737a08d7 will cause the mpc8315erdb board can't boot up. The patch fix that bug, and remove the duplicated #ifdef CFG_SPCR_TSECEP code and clean the SCCR_TSEC2 for MPC8313E processor. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-17Merge branch 'master' of /home/stefan/git/u-boot/u-bootStefan Roese
2008-01-1785xx: Get ride of old TLB setup codeKumar Gala
Now that all boards have been converted, remove old config code and the config option for the new style. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1785xx: Reworked initial processor initKumar Gala
Reworked the initial processor initialzation sequence: * introduced cpu_early_init_f that is run in address space 1 (AS=1) * Moved TLB/LAW and CCSR init into cpu_early_init_f() * Reworked initial asm code to do most of the core init before TLBs The main reasons for these changes are to allow handling of 36-bit phys addresses in the future and some of the issues that will exist when we do that. There are a few caveats on what can be initialized via the LAW and TLB static tables: * TLB entry 14/15 can't be initialized via the TLB table * any LAW that covers the implicit boot window (4G-8M to 4G) must map to the code that is currently executing. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1785xx: Introduce new tlb APIKumar Gala
Add a set of functions to manipulate TLB entries: * set_tlb() - write a tlb entry * invalidate_tlb() - invalidate a tlb array * disable_tlb() - disable a variable size tlb entry * init_tlbs() - setup initial tlbs based on static table Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1685xx: Remove old style of LAW initKumar Gala
All boards are now using the new fsl_law code so we can drop the old version. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1685xx: Move LAW init code into CKumar Gala
Move the initialization of the LAWs into C code and provide an API to allow modification of LAWs after init. Board code is responsible to provide a law_table and num_law_entries. We should be able to use the same code on 86xx as well. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-16Merge branch 'master' of git://www.denx.de/git/u-boot-shWolfgang Denk
2008-01-16mpc83xx: add support for more system clock performance controlsKim Phillips
System registers that are modified are the Arbiter Configuration Register (ACR), the System Priority Control Register (SPCR), and the System Clock Configuration Register (SCCR). Signed-off by: Michael F. Reiss <Michael.F.Reiss@freescale.com> Signed-off by: Joe D'Abbraccio <ljd015@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-16mpc83xx: Add config of eTSEC emergency priority in SPCRDave Liu
The TSEC emergency priority definition of 831x/837x is different than the definition of 834x in SPCR register. Add the other config of TSEC emergency priority into cpu_init.c Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-15sh: Add support SH3 and SH7720Yoshihiro Shimoda
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-01-15ppc4xx: Remove compiler warning in cpu/ppc4xx/44x_spd_ddr2.cStefan Roese
2008-01-13MPC8xx FEC driver: fix compiler warning.Wolfgang Denk
2008-01-12MPC5200: don't use hardcoded MBAR address in Bestcomm firmwareOliver Weber
Signed-off-by: Oliver Weber <almoeli@gmx.de>
2008-01-12MPC512X: Cleanup bus clock names.Grzegorz Bernacki
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
2008-01-12ads5121: Added support for FDT.Grzegorz Bernacki
2008-01-12Fixed syntax error in function init_e300_core() of mpc83xx/start.S ifHeiko Schocher
Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Heiko Schocher <hs@denx.de>
2008-01-12added basic support for the MUNICes board.Heiko Schocher
2008-01-12Added support for the mgcoge board from keymile.Heiko Schocher
2008-01-12Enable SMC microcode relocation patch for SMC1.Heiko Schocher
2008-01-12Added support for the mgsuvd board from keymile.Heiko Schocher
2008-01-12Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2008-01-12Merge branch 'master' of git://www.denx.de/git/u-boot-mpc83xxWolfgang Denk
2008-01-10mpc83xx: Fix the bug of 266MHz data rate DDRDave Liu
The DDR doesn't work on the 266MHz data rate, the patch fix the bug. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-10mpc83xx: add "fsl, qe" compatible fixupsAnton Vorontsov
New device trees will use "fsl,qe" compatible properties. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-10Merge commit 'wd/master'Jon Loeliger
2008-01-1086xx: Support 2GB DIMMsBecky Bruce
Configure the number of bits used to address the banks inside the SDRAM device. The default register value of 0 means 2 bits to address 4 banks. Higher capacity devices like a 2GB DIMM require 3 bits to address 8 banks. Signed-off-by: Becky Bruce <bgill@freescale.com>
