path: root/cpu
2005-12-06Fix DPRAM offset/size for MPC8541/8555.Wolfgang Denk
Simplify TQM85xx Makefile handling.
2005-12-04Code cleanup, especially MIPS for GCC 4.xWolfgang Denk
2005-12-01Fix U-Boot compilation for MIPS boards using ELDK 4.0Wolfgang Denk
2005-11-29Compile warning fixedStefan Roese
Patch by Stefan Roese, 29 Nov 2005
2005-11-29Add support for AMCC 440SP, add support for AMCC Luan 440SP eval board.Stefan Roese
Patch by John Otken, 23 Nov 2005
2005-11-27Changed PPC44x startup message (cpu info, speed...) to common style:Stefan Roese
On PPC44x platforms, the startup message generated in "cpu.c" only comprised the ppc type and revision but not additional informations like speed etc. Those speed infos where printed in the board specific code. This new implementation now prints all CPU infos in the common cpu specific code. No board specific code is needed anymore and therefore removed from all current 44x implementations. Patch by Stefan Roese, 27 Nov 2005
2005-11-22Add support for Prodrive P3P440 board:Stefan Roese
- Added onboard PPC440 DDR autodetection in cpu/ppc/sdram.c - CFG_FLASH_QUIET_TEST added to use the common CFI driver for bank autodetection Patch by Stefan Roese, 22 Nov 2005
2005-11-15Fix Bamboo DDR SDRAM initialization (problem with onboard SDRAM)Stefan Roese
Patch by Stefan Roese, 15 Nov 2005
2005-11-07Fix MPC85xx PCI support (pci_register_hose() before pci config access)Stefan Roese
Patch by Stefan Roese, 07 Nov 2005
2005-11-01Add support for Ocotea pass 3 with 440GX Rev. FStefan Roese
Patch by Stefan Roese, 01 Nov 2005
2005-10-29Merge with /home/m8/git/u-bootWolfgang Denk
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-10-21Merge with /home/wd/git/u-boot/masterWolfgang Denk
2005-10-20Add NetConsole Support for AMCC eval boardsStefan Roese
Patch by Stefan Roese, 20 Oct 2005
2005-10-18Fix NetConsole support on 4xx (only print eth link on 1st transfer)Stefan Roese
Patch by Stefan Roese, 18 Oct 2005
2005-10-17Add PCI support for the TQM834x board.Rafal Jaworowski
2005-10-15Merge with /home/m8/git/u-bootWolfgang Denk
2005-10-13Merge with /home/sr/git/u-bootWolfgang Denk
2005-10-13Support passing of OF flat trees to the kernel.Wolfgang Denk
Patch by Pantelis Antoniou, 04 Sep 2005
2005-10-11Added support for TQM834x boards.Marian Balakowicz
2005-10-10Fix problem in ppc4xx eth-driver without ethaddr (only withoutStefan Roese
CONFIG_NET_MULTI set) Patch by Stefan Roese, 10 Oct 2005
2005-10-09Add support for NetSilicon NS7520 processor.Wolfgang Denk
Patch by Art Shipkowski, 12 May 2005 Cleanup.
2005-10-09Add support for AP1000 board.Wolfgang Denk
Patch by James MacAulay, 07 Oct 2005
2005-10-09Eliminate hard-coded address of Ethernet transfer buffer on at91rm9200Wolfgang Denk
Patch by Anders Larsen, 07 Oct 2005 The Atmel errata #11 states that the transfer buffer descriptor table must be aligned on a 16-word boundary. As it turned out, this is insufficient - it seems the table must be aligned on a boundary at least as large as the table itself (in Linux this is not an issue - the table is aligned on a PAGE_SIZE (4096) boundary).
2005-10-09Cleanup warnings for cpu/arm720t & cpu/arm1136 files.Wolfgang Denk
sed the linker scripts, rather than pre-process them. Patch by Peter Pearse, 07 Oct 2005
2005-10-06Update make target for ARM supported boards.Wolfgang Denk
Use lowlevel_init() instead of platformsetup() [rename]. Patch by Peter Pearse, 06 Oct 2005
2005-10-06Complete support for the KwikByte KB920x boardsWolfgang Denk
Patch by Anders Larsen, 05 Oct 2005
2005-10-05Set the AT91RM9200 clock to asynchronous modeWolfgang Denk
Patch by Anders Larsen, 03 May 2005
2005-10-05Set the AT91RM9200 clock to synchronous modeWolfgang Denk
Patch by Anders Larsen, 29 Apr 2005
2005-10-05Add support for Cogent csb637Wolfgang Denk
2005-10-05Fix dm9161.c initializationWolfgang Denk
2005-10-05* Move dm9161.c and lxt972.c into cpu/arm920t/at91rm9200Wolfgang Denk
Patch by Anders Larsen, 29 Apr 2005 * Fix problems introduced by Patch by Steven Scholz, 02 Mar 2005 (8e2be51de8dd03c1ce4d06cbb18ad06133d47cd5)
2005-10-05Added support for KwikByte KB920x boards (based on AT91RM9200)Wolfgang Denk
Patch by Matt ?? <kb9200_dev@kwikbyte.com>, 27 Apr 2005
2005-10-05E500 update: repoint IVPR to RAM when code is relocatedWolfgang Denk
Patch by Kylo Ginsberg, 13 Apr 2005
2005-10-04Update ARM Integrator boards:Wolfgang Denk
Correct addessing errors in platform files. Split off common core module data from Integrator header files to include/armcoremodule.h. Patch by Peter Pearse, 04 Oct 2005
2005-10-04Make sure only supported compiler options are usedWolfgang Denk
Import "cc-option" shell function from kernel and use it to get the correct ARM GCC options for individual CPUs Patch by Peter Pearse, 30 Jun 2005
2005-10-04Fix 440GR to print correct cpu revisionStefan Roese
Patch by Stefan Roese, 4 Oct 2005
2005-09-26Add support for AT91RM9200 OHCI Controller.Wolfgang Denk
Patch by Eric Benard, 07 Apr 2005
2005-09-26Add board support for armadillo HT1070Wolfgang Denk
Patch by Rowel Atienza, 06 Apr 2005
2005-09-25CleanupWolfgang Denk
2005-09-25Fix au1x00_serial baud rate calculation:Wolfgang Denk
remove hardcoded cpu clock divisor and use register instead; round up instead of truncate Patch by Andrew Dyer, 15 Feb 2005
2005-09-25Added support for PCI bridge on MPC8272ADSWolfgang Denk
Patch by Vitaly Bordug, Feb 09 2005
2005-09-25Add ARM946E cpu and core module targets; remap memory to 0x00000000Wolfgang Denk
Patch by Peter Pearse, 2 Feb 2005
2005-09-25Fix MGT5100 PSC baudrate calculationWolfgang Denk
Patch by Sebastian Schau, 27 Jan 2005
2005-09-25Add support for AMD's Pb1x00 eval board;Wolfgang Denk
add MII routines to the au1x00 ethernet driver; add USB ohci driver (work in progress) Patch by Thomas Sailer, 20 Jan 2005
2005-09-25Fix warnings for PCI code on ixpWolfgang Denk
Patch by Joe <lgxue@yahoo.com>, 13 Jan 2005
2005-09-24Fix ethernet timeouts on dbau1550 and other au1x00 systemsWolfgang Denk
Patch by Leif Lindholm, 29 Dec 2004
