* Enable long help on CMC PU2 board;
fix reset issue;
increase CPU speed from 179 to 207 MHz.
- Enable booting directly from flash
- fix CMC_PU2 flash driver
* Fix mkimage usage message
- add support for MPC8220 CPU
- Add support for Alaska and Yukon boards
* Adjust MIPS compiler options at run-time depending on tools version
("-march=4kc -mtune=4kc -Wa,-mips_allow_branch_to_undefined" for new,
"-mcpu=4kc" for old tools)
[Remember: CFG_HZ should be 1000 on ALL systems!]
- Add support to revA version of PQ27 and PQ27E.
- Reverted MPC8260ADS baudrate back to original 115200
* Patch by Hojin, 17 Sep 2004:
Fix typo in cfi_flash.c
* Patch by Mark Jonas, 09 September 2004:
mtest's data line test (with CFG_ALT_MEMTEST set) returned a wrong
error message
* Patch by Mark Jonas, 31 August 2004:
Added option CFG_XLB_PIPELINING to enable XLB pipelining. This
improves FTP performance for MPC5200 systems. Enabled for IceCube
by default.
- Add support for Altera Nios-II processors.
- Add support for Psyent PCI-5441 board.
- Add support for Psyent PK1C20 board.
- Fix PCI window on MPC85xx; remove unneeded PCI initialization
from board_early_init_f()
- Provide SW workaround for PCI initialization on 85xx CDS
- Convert MPC85xxADS to use common CFI flash driver
* Cleanup: avoid compiler warnings
* Add CMC PU2 board to MAKEALL script
Patch by Gary Jennejohn, 04 Oct 2004:
- fix I2C on at91rm9200
- add support for Ricoh RS5C372A RTC
- add support for CMC PU2 board
- add support for I2C on at91rm9200
* Patch by Gary Jennejohn, 28 Sep 2004:
fix baudrate handling on at91rm9200
* Patch by Hinko Kocevar, 21 Aug 2004:
- Group common framebuffer functions in common/lcd.c
- Group common framebuffer macros and #defines in include/lcd.h
- Provide calc_fbsize() for video ATAG
- Introducing the concept of SoCs "./cpu/$(CPU)/$(SOC)"
- creating subdirs for SoCs ./cpu/arm920t/imx and ./cpu/arm920t/s3c24x0
- moving SoC specific code out of cpu/arm920t/ into cpu/arm920t/$(SOC)/
- moving drivers/s3c24x0_i2c.c and drivers/serial_imx.c out of drivers/
- Added I2C support for ML300.
- Added support for ML300 to read out its environment information
stored on the EEPROM.
- Added support to use board specific parameters as part of
U-Boot's environment information.
- Updated MLD files to support configuration for new features
above.
* Patches by Travis Sawyer, 5 Aug 2004:
- Remove incorrect bridge settings for eth group 6
- Add call to setup bridge in ppc_440x_eth_initialize
- Fix ppc_440x_eth_init to reset the phy only if its the
first time through, otherwise, just check the phy for the
autonegotiated speed/duplex. This allows the use of netconsole
- only print the speed/duplex the first time the phy is reset.
- Fix host tools building in Cygwin environment
- Fix header files search order for host tools
* Patch by Tom Armistead, 19 Jul 2004:
Fix kgdb.S support for 74xx_75x cpu
Fix MPC85xx I2C driver
Allow clock setting on MPC866/MPC885 series chips according to
environment variable `cpuclk'
* Patch by Yuli Barcohen, 20 Apr 2004:
Remove unnecessary redefine of CPM_DATAONLY_SIZE for MPC826x
allow to use USART1 as console port on at91rm9200dk boards
- move at45.c to board/at91rm9200dk/ since this is at91rm9200dk
board specific
- split out the LXT971A PHY from ns_9750_eth.h
- split the dm9161 phy part out of at91rm9200_ether.c
- support larger DDR memories up to 2G on the PC8540/8560ADS and
STXGP3 boards
- Made MPC8540/8560ADS be 33Mhz PCI by default.
- Removed moldy CONFIG_RAM_AS_FLASH, CFG_FLASH_PORT_WIDTH_16
and CONFIG_L2_INIT_RAM options.
- Refactor Local Bus initialization out of SDRAM setup.
- Re-implement new version of LBC11/DDR11 errata workarounds.
- Moved board specific PCI init parts out of CPU directory.
- Added TLB entry for PCI-1 IO Memory
- Updated README.mpc85xxads
* Patch by Sascha Hauer, 28 Jun:
- add generic support for Motorola i.MX architecture
- add support for mx1ads, mx1fs2 and scb9328 boards
* Patches by Marc Leeman, 23 Jul 2004:
- Add define for the PCI/Memory Buffer Configuration Register
- corrected comments in cpu/mpc824x/cpu_init.c
* Add support for multiple serial interfaces
(for example to allow modem dial-in / dial-out)
Fix lowboot (again) on MPC5xxx
relocate exception vectors on arm720t if needed
- update mach-types.h to latest arm.linux.org.uk master list
- Set correct OMAP1610 bi_arch_number for build target
* Patch by Curt Brune, 06 Jul 2004:
evb4510: add support for timer interrupt; cleanup
Added support for Total5100 and Total5200 (Rev.1 and Rev.2)
MGT5100 and MPC5200 based Freescale platforms.
Add support for TQM5200 board
* Patch by Martin Krause, 29 Jun 2004:
Add loopw command: infinite write loop on address range
Add support for WindRiver's SBC8560 board
* Patch by Nicolas Lacressonniere, 24 Jun 2004
Small Bugs fixes for "at91rm9200dk" board:
- Timing modifications for SPI DataFlash access
- Fix NAND flash detection bug
* Patch by Nicolas Lacressonniere, 24 Jun 2004:
Add Support for Flash AT49BV6416 for AT91RM9200DK board
Completion of the 8540ADS/8560ADS updates:
Fix some PCI and Rapid I/O memory maps,
Initialize both TSEC 1 and 2,
Initialize SDRAM
Update MAINTAINER for 85xx boards and README.mpc85xxads
Remove obsolete AdderII port which was superseded by unified
AdderII/Adder87x port
* Patch by Ladislav Michl, 16 Jun 2004:
Fix gcc-3.3.3 warnings for smc91111.c
Update for PPChameleon board:
- support for SysClk @ 25MHz
- support for Silicon Motion SM712 VGA controller
- some clean ups
* Patch by Curt Brune, 17 May 2004:
- Add support for Samsung S3C4510B CPU (ARM7tdmi based SoC)
- Add support for ESPD-Inc. EVB4510 Board
* Increase NFS download timeout (now 1 min - 10 sec is to short for a
slow download of a big image)
display even after showing a bitmap
- DDR Ram support for PM520 (MPC5200)
- support for different flash types (PM520)
- USB / IDE / CF-Card / DiskOnChip support for PM520
- 8 bit boot rom support for PM520/CE520
- Add auto SDRAM module detection for MicroSys CPC45 board (MPC8245)
- I2C and RTC support for CPC45
- support of new flash type (28F160C3T) for CPC45
* Remove eth_init() from lib_arm/board.c; it's done in net.net.c.
fix support for Logic SDK-LH7A404 board and clean up the
LH7A404 register macros.
* Patch by Matthew McClintock, 10 Jun 2004:
Modify code to select correct serial clock on Sandpoint8245
Add support for Analogue&Micro Adder87x and the older AdderII board.
* Patch by Ming-Len Wu, 09 Jun 2004:
Add suppport for MC9328 (Dargonball) CPU and Motorola MX1ADS board
- Add support for RPXlite_DW board
- Update FLASH driver for 4*AM29DL323DB90VI
- Add option configuration of CFG_ENV_IS_IN_NVRAM on RPXlite_DW board
- Make MPC5200 boards evaluate the SVR to print processor name and
version in checkcpu() (cpu/mpc5xxx/cpu.c).
* Patch by Kai-Uwe Bloem, 06 May 2004:
Fix endianess problem in cramfs code
