path: root/cpu
2006-10-09Coding style cleanupWolfgang Denk
2006-09-13Add support for AMCC Rainier PPX440GRx eval boardStefan Roese
Patch by Stefan Roese, 13 Sep 2006
2006-09-09Merge with /home/m8/git/u-bootWolfgang Denk
2006-09-07Fix build problem cpu/ppc4xx/ndfc.cStefan Roese
Patch by Stefan Roese, 07 Sep 2006
2006-09-07Remove dead code (i2o and dma) from cpu/mpc824x/drivers/ directory.Marian Balakowicz
2006-09-07Add support for AMCC Sequoia PPC440EPx eval boardStefan Roese
- Add support for PPC440EPx & PPC440GRx - Add support for PPC440EP(x)/GR(x) NAND controller in cpu/ppc4xx directory - Add NAND boot functionality for Sequoia board, please see doc/README.nand-boot-ppc440 for details - This Sequoia NAND image doesn't support environment in NAND for now. This will be added in a short while. Patch by Stefan Roese, 07 Sep 2006
2006-09-04Fix build problems on sorcery board.Wolfgang Denk
2006-09-04Merge with /home/m8/git/u-bootWolfgang Denk
2006-09-01Added interrupt handling capabilities for mpc5xxx processors.Detlev Zundel
Also added Linux like BUG() macros.
2006-08-30Add splashscreen support for MCC200 board.Wolfgang Denk
2006-08-29PCIe endpoint support for AMCC Yucca 440SPe boardStefan Roese
Patch by Tirumala R Marri, 26 Aug 2006
2006-08-27Code cleanupWolfgang Denk
2006-08-14Update for SC520 board.Wolfgang Denk
Patch by David Updegraff, 02 Dec 2005
2006-08-11Merge with /home/raj/git/u-bootWolfgang Denk
2006-08-11Fix PCI-Express on PPC440SPe rev. A.Rafal Jaworowski
2006-08-10Merge with /home/raj/git/u-bootWolfgang Denk
2006-08-10Add support for PCI-Express on PPC440SPe (Yucca board).Rafal Jaworowski
2006-07-28PPC440 DDR setup: Set SDRAM0_CFG0[PMU]=0 for best performanceStefan Roese
AMCC suggested to set the PMU bit to 0 for best performace on the PPC440 DDR controller. Please see doc/README.440-DDR-performance for details. Patch by Stefan Roese, 28 Jul 2006
2006-07-21Code cleanupWolfgang Denk
2006-07-21Add support for friendly-arm SBC-2410X boardWolfgang Denk
Patch by JinHua Luo, 01 Sep 2005
2006-07-21Fix MIPS LE build problemWolfgang Denk
Patch by Thomas Lange, 10 Aug 2005
2006-07-19Add support for TB5200 boardWolfgang Denk
The TB5200 ("Tinybox") is a small baseboard for the TQM5200 module integrated in a little aluminium case. Patch by Martin Krause, 8 Jun 2006 Some code cleanup
2006-07-12Add support for TQM885D board.Markus Klotzbuecher
Patch by Martin Krause, 20 Mar 2006 Signed-off-by: Martin Krause <martin.krause@tqs.de>
2006-07-12Bugfix in FEC initialisation:Markus Klotzbuecher
All MII configuration is done via FEC1 registers. But MII_SPEED was configured according to FEC used. So if only FEC2 was used, this caused the real MII_SPEED register in FEC1 to stay uninitalised, what lead to "mii_send STUCK!" messages. Fix: always configure MII_SPEED on FEC1 only.
2006-07-12Support for spc1920 board.Markus Klotzbuecher
Patch by Markus Klotzbuecher, 12 Jul 2006
2006-07-06Fix timer problems on AMCC yucca board.Marian Balakowicz
Set Timer Clock Select to use CPU clock as a timer input source.
2006-07-04Add system memory to the PCI region list for AMCC PPC44x CPUs.Marian Balakowicz
Enabled it for Yucca board.
2006-07-03Cleanup config file and bootup output for Yucca board.Marian Balakowicz
2006-06-30Fix CONFIG_440_GX define usage.Marian Balakowicz
2006-06-30Merge: Add support for AMCC 440SPe CPU based eval board (Yucca).Marian Balakowicz
2006-06-30Add support for AMCC 440SPe CPU based eval board (Yucca).Marian Balakowicz
2006-06-19Add support for wrPPMC7xx/74xx boardsHeiko Schocher
Patch from Richard Danter, 12 Aug 2005
2006-06-19Merge with ssh://fifi/home/wd/git/u-boot/masterWolfgang Denk
2006-06-16Add support for CONFIG_SERIAL_MULTI on MPC5xxxWolfgang Denk
Patch by Martin Krause, 8 Jun 2006 This patch supports two serial consoles on boards with a MPC5xxx CPU. The console can be switched at runtime by setting stdin, stdout and stderr to the desired serial interface (serial0 or serial1). The PSCs to be used as console port are definded by CONFIG_PSC_CONSOLE and CONFIG_PSC_CONSOLE2. See README.serial_multi for details.
2006-06-16Bugfix in I2C initialisation on S3C2400.Wolfgang Denk
If the bus is blocked because of a previously interrupted transfer, up to eleven clocks are generated on the I2CSCL line to complete the transfer and to free the bus. With this fix pin I2CSCL (PG6) is really configured as GPIO so the clock pulses are really generated. Patch by Martin Krause, 04 Apr 2006
2006-06-14Fix IxEthDB.h to compile againStefan Roese
Patch by Stefan Roese, 14 Jun 2006
2006-06-13Minor cleanup for PCS440EP boardStefan Roese
Patch by Stefan Roese, 13 Jun 2006
2006-06-10Minor code cleanup.Wolfgang Denk
2006-06-10Merge with /home/hs/U-Boot/u-boot-devWolfgang Denk
2006-06-08Nios II - Add EPCS Controller bootrom work-aroundScott McNutt
-When booting from an epcs controller, the epcs bootrom may leave the slave select in an asserted state causing soft reset hang. This patch ensures slave select is negated at reset. Patch by Scott McNutt, 08 Jun 2006
2006-06-08Nios II - Fix I/O Macros and mini-app stubsScott McNutt
-Fix asm/io.h macros -Eliminate use of CACHE_BYPASS in cpu code -Eliminate assembler warnings -Fix mini-app stubs and force no small data Patch by Scott McNutt, 08 Jun 2006
2006-06-02Add support for PCS440EP boardStefan Roese
Patch by Stefan Roese, 02 Jun 2006
2006-05-30Fix PCI to memory window size problems on PM82x boardsWolfgang Denk
We use the "automatic" mode that was used for the MPC8266ADS and MPC8272 boards. Eventually this should be used on all boards?] Patch by Wolfgang Grandegger, 17 Jan 2006
2006-05-30Minor cleanup.Wolfgang Denk
2006-05-30* Update Intel IXP4xx supportWolfgang Denk
- Add IXP4xx NPE ethernet MAC support - Add support for Intel IXDPG425 board - Add support for Prodrive PDNB3 board - Add IRQ support Patch by Stefan Roese, 23 May 2006 [This patch does not include cpu/ixp/npe/IxNpeMicrocode.c which still sufferes from licensing issues. Blame Intel.]
2006-05-18Fix problem in PVR detection for 440GRLABEL_2006_05_19_1133Stefan Roese
Patch by Stefan Roese, 18 May 2006
2006-05-10Minor cleanup.LABEL_2006_05_10_1800Wolfgang Denk
2006-05-10Add support for AMCC 440EP Rev C and 440GR Rev BStefan Roese
Patch by John Otken, 08 May 2006
