This is needed in unlock_ram_in_cache() because it is called from C and
will corrupt the small data area anchor that is kept in R2.
lock_ram_in_cache() is modified similarly as good coding practice, but
is not called from C.
Signed-off-by: Nick Spence <nick.spence@freescale.com>
Set DAT value before DIR values to avoid creating glitches on the
GPIO signals.
Set gpio level register before direction register to inhibit
glitches on high level output pins.
Dir and data gets cleared at powerup, so high level output lines see
a short low pulse between setting the direction and level registers.
Issue was seen on a new board with the nReset line of the NOR flash
connected to a GPIO. Setting the direction register puts the NOR flash
in reset so the next instruction to set the level cannot get executed.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Modified board_eth_init() functions of boards that have this FEC in addition
to other Ethernet controllers.
Affected boards:
bc3450
icecube
mvbc_p
o2dnt
pm520
total5200
tq5200
Removed initialization of controller from net/eth.c
Added a cpu_eth_init() function to MPC512x CPU directory and
removed code from net/eth.c
Removed at91sam9_eth_initialize() from net/eth.c
This addresses all drivers whose initializers have already
been moved to board_eth_init()/cpu_eth_init().
The tsec driver contains a hard-coded array of configuration information
for the tsec ethernet controllers. We create a default function that works
for most tsecs, and allow that to be overridden by board code. It creates
an array of tsec_info structures, which are then parsed by the corresponding
driver instance to determine configuration. Also, add regs, miiregs, and
devname fields to the tsec_info structure, so that we don't need the kludgy
"index" parameter.
Signed-off-by: Andy Fleming <afleming@freescale.com>
Add support SH2/SH2A basic function.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
Notice: USB on S3C6400 currently works _only_ with switched off MMU. One could
try to enable the MMU, but map addresses 1-to-1, and disable data cache, then
it should work too and we could still profit from instruction cache.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Based on the original S3C64XX port by Samsung for U-Boot 1.1.6.
DM644x is just one of a series of DaVinci chips that use the EMAC driver.
By replacing all the function names that start with dm644x_* to davinci_*
we make these function more portable. I have tested this change on my EVM.
DM6467 is another DaVinci SOC which uses the EMAC driver and i will
be sending patches that add DaVinci DM6467 support to the list soon.
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
This function is needed for the new NAND infrastructure. We only need
a dummy implementation though for the NDFC.
Made NAND bank configuration setting a config variable.
Signed-off-by: Wolfgang Ocker <weo@reccoware.de>
This patch fixes a UIC external_interrupt hang if critical or non-critical
interrupt is set at the same time as a normal interrupt is set on UIC0.
Signed-off-by: Victor Gallardo <vgallardo@amcc.com>
Removed Magic numbers from Initialization preload registers
Tested with Kilauea, Glacier, Canyonlands and Katmai boards
About 5-7% improvement seen for LMBench memtests
Signed-off-by: Prodyut Hazarika <phazarika@amcc.com>
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
For some reason we duplicated the majority of code in lib_ppc/interrupts.c
not show how that happened, but there is no good reason for it.
Use the interrupt_init_cpu() and timer_interrupt_cpu() since its why
they exist.
The MPC8536 Adds SDHC and SATA controllers to the PQ3 family. We
also have SERDES init code for the 8536.
Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
Signed-off-by: Dejan Minic <minic@freescale.com>
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Signed-off-by: Dave Liu <daveliu@freescale.com>
All 85xx boards have been converted to the new code so we can
remove the old SPD DDR setup code.
Provide a helper function that board code can call to map TLBs when
setting up DDR.
Added a cpu_eth_init() function to leon2/leon3 CPU directories and
Added a cpu_eth_init() function to coldfire CPU directories and
Added a cpu_eth_init() function to cpu/mcf547x_8x directory and
All 86xx boards have been converted to the new code so we can
Compute DIMM parameters based upon the SPD information.
Signed-off-by: James Yang <James.Yang@freescale.com>
Compute DIMM parameters based upon the SPD information in spd.
The main purpose of this rewrite it to be able to share the same
initialization code on all FSL PowerPC products that have DDR
controllers. (83xx, 85xx, 86xx).
The code is broken up into the following steps:
GET_SPD
COMPUTE_DIMM_PARMS
COMPUTE_COMMON_PARMS
GATHER_OPTS
ASSIGN_ADDRESSES
COMPUTE_REGS
PROGRAM_REGS
This allows us to share more code an easily allow for board specific code
overrides.
Additionally this code base adds support for >4G of DDR and provides a
foundation for supporting interleaving on processors with more than one
controller.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
This adds a helper function to unlock the PCI configuration bit, so that
any extra PCI setup (such as outbound windows, etc.) can be done after
using the 83XX_GENERIC_PCI code to set up the PCI bus.
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
Bits MPCTL[MFN] and MPCTL[MFD] were not fully covered.
Signed-off-by: Jens Gehrlein <sew_s@tqs.de>
- According to ARM Dual-Timer Module (SP804) TRM (ARM DDI0271),
-- Timer Value Register @ TIMER Base + 4 is Read-only.
-- Prescale Value (Bits 3-2 of TIMER Control register)
can only be one of 00,01,10. 11 is undefined.
-- CFG_HZ for Versatile board is set to
#define CFG_HZ (1000000 / 256)
So Prescale bits is set to indicate
- 8 Stages of Prescale, Clock divided by 256
- The Timer Control Register has one Undefined/Shouldn't Use Bit
So we should do read/modify/write Operation
Signed-off-by: Gururaja Hebbar <gururajakr@sanyo.co.in>
ARM DaVinci: Removed redundant NAND initialization code.
Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
ARM DaVinci: Fix compilation error with new MTD code.
During recent PCI-E tests it has been found that current
driverl level and de-emphasis values are not set correctly.
After sweeping throgh all de-ephasis values, it was found that
0x130 is a right value. Where 0x13 is driver level and 0 is
de-emphasis.
Signed-off-by: Tirumala R Marri <tmarri@amcc.com>
This patch fixes some minor issues introduced with the patch:
ppc4xx: Optimize PLB4 Arbiter... from Prodyut Hazarika:
- Rework memory-queue and PLB arbiter optimization code, that the
local variable is not needed anymore. This removes one #ifdef.
- Use consistant spacing in ppc4xx.h header (XXX + 0x01 instead
of XXX+ 0x01). This was not introduced by Prodyut, just a
copy-paste problem.
PPC405EX and PPC460EX/GT/SX
- Read pipeline depth set to 4 for PPC440SP/SPE, PPC405EX, PPC460EX/GT/SX
processors
- Moved PLB4 Arbiter register definitions to ppc4xx.h since it is shared
across processors (405 and 440/460)
- Optimize Memory Queue settings for PPC440SP/SPE and PPC460EX/GT/SX
processors
- Add register bit definitions for Memory Queue Configuration registers
