Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
Patch by David Updegraff, 02 Dec 2005
AMCC suggested to set the PMU bit to 0 for best performace on
the PPC440 DDR controller.
Please see doc/README.440-DDR-performance for details.
Patch by Stefan Roese, 28 Jul 2006
Patch by JinHua Luo, 01 Sep 2005
Patch by Thomas Lange, 10 Aug 2005
The TB5200 ("Tinybox") is a small baseboard for the TQM5200 module
integrated in a little aluminium case.
Patch by Martin Krause, 8 Jun 2006
Some code cleanup
Patch by Martin Krause, 20 Mar 2006
Signed-off-by: Martin Krause <martin.krause@tqs.de>
All MII configuration is done via FEC1 registers. But MII_SPEED was
configured according to FEC used. So if only FEC2 was used, this caused
the real MII_SPEED register in FEC1 to stay uninitalised, what lead
to "mii_send STUCK!" messages. Fix: always configure MII_SPEED on FEC1
only.
Patch by Markus Klotzbuecher, 12 Jul 2006
Set Timer Clock Select to use CPU clock as a timer input source.
Enabled it for Yucca board.
Patch from Richard Danter, 12 Aug 2005
This patch supports two serial consoles on boards with
a MPC5xxx CPU. The console can be switched at runtime
by setting stdin, stdout and stderr to the desired serial
interface (serial0 or serial1). The PSCs to be used as
console port are definded by CONFIG_PSC_CONSOLE
and CONFIG_PSC_CONSOLE2.
See README.serial_multi for details.
If the bus is blocked because of a previously interrupted
transfer, up to eleven clocks are generated on the I2CSCL
line to complete the transfer and to free the bus.
With this fix pin I2CSCL (PG6) is really configured as GPIO
so the clock pulses are really generated.
Patch by Martin Krause, 04 Apr 2006
Patch by Stefan Roese, 14 Jun 2006
Patch by Stefan Roese, 13 Jun 2006
-When booting from an epcs controller, the epcs bootrom may leave the
slave select in an asserted state causing soft reset hang. This
patch ensures slave select is negated at reset.
Patch by Scott McNutt, 08 Jun 2006
-Fix asm/io.h macros
-Eliminate use of CACHE_BYPASS in cpu code
-Eliminate assembler warnings
-Fix mini-app stubs and force no small data
Patch by Stefan Roese, 02 Jun 2006
We use the "automatic" mode that was used for the MPC8266ADS and
MPC8272 boards. Eventually this should be used on all boards?]
Patch by Wolfgang Grandegger, 17 Jan 2006
- Add IXP4xx NPE ethernet MAC support
- Add support for Intel IXDPG425 board
- Add support for Prodrive PDNB3 board
- Add IRQ support
Patch by Stefan Roese, 23 May 2006
[This patch does not include cpu/ixp/npe/IxNpeMicrocode.c which still
sufferes from licensing issues. Blame Intel.]
Patch by Stefan Roese, 18 May 2006
Patch by John Otken, 08 May 2006
- Fix OMAP support that omap5912osk compiles in current source tree
- Update with code from "http://omap.spectrumdigital.com/osk5912"
to fix problems with DDR initialization
- Fix timer setup
- Use CFI flash driver and support complete 32MB of onboard flash
- Add "print_cpuinfo()" and "checkboard()" functions to display
CPU (with frequency) and Board infos
Patch by Stefan Roese, 10 May 2006
- Removed MPC8349ADS port
- Added PCI support to MPC8349ADS
- reworked memory map to allow mapping of all regions with BATs
Patch by Kumar Gala 20 Apr 2006
Patch from Scott McNutt 11, Aug 2005
Patch by Scott McNutt 11, Aug 2005
relocate ichache_State to ram
u-boot can run from internal flash
Add EB+MCF-EV123 board support.
Add m68k Boards to MAKEALL
Patch from Jens Scharsig, 08 Aug 2005
is configured; othrwise DMA accesses aren't cache coherent which
causes for example USB to fail.
