This patch adds flush_/invalidate_dcache_range() to the MIPS architecture.
Those functions are needed for the upcoming dcache support for the USB
EHCI driver. I chose this API because those cache handling functions are
already present in the PPC architecture.
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
Added support for a second memory bank to DDR autodetection for 440
platforms.
Made hardcoded values configurable.
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
CONFIG_SC520 is now used for conditional compile
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
Reset function specific to AMD SC520 microcontroller - Is more of a
'hard reset' that the triple fault.
Requires CONFIG_SYS_RESET_SC520 to be defined in config
I would have liked to add this to a new file (cpu/i386/sc520/reset.c)
but ld requires that a object file in a library arhive MUST contain
at least one function which does not override a weak function (and is
called from outside the object file) in order for that object file to
be extracted from the archive. This would be the only function on the
new file, and hence, will never get linked in.
Moved from interrupts.c to cpu.c and made into a weak function to
allow vendor specific override
Vendor specific CPU reset (like the AMD SC520 MMCR reset) can now be
added to the vendor specific code without the need to remember to
#undef usage of the generic method and if you forget to include your
custom reset method, you will always get the default.
This allows for future tidy ups and functionality that will require
set_vector ()
Brings i386 in line with other CPUs with a reset vector and frees up reset.c
for CPU reset functions
This patch updates e500 freqProcessor to array based on CONFIG_NUM_CPUS,
and prints each CPU's frequency separately. It also fixes up each CPU's
frequency in "clock-frequency" of fdt blob.
Signed-off-by: James Yang <James.Yang@freescale.com>
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
For light loaded system, we use the 1T timing to gain better
memory performance, but for some heavily loaded system,
you have to add the 2T timing options to board files.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Acked-by: Andy Fleming <afleming@freescale.com>
Some 85xx processors have the advanced power management feature,
such as wake up ARP, that needs enable the automatic self refresh.
If the DDR controller pass the SR_IT (self refresh idle threshold)
idle cycles, it will automatically enter self refresh. However,
anytime one transaction is issued to the DDR controller, it will
reset the counter and exit self refresh state.
- The DDR3 controller is expanding the bits for timing config
- Add the DDR3 32-bit bus mode support
According to the latest 8572 UM, the DDR3 controller
is expanding the bit mask, and we use the extend ACTTOPRE
mode when tRAS more than 19 MCLK.
Use CONFIG_SYS_PCI*_IO_BUS for the bus relative address instead
of _IO_BASE so we are more explicit.
Use CONFIG_SYS_{PCI,RIO}_MEM_BUS for the bus relative address instead
of _MEM_BASE so we are more explicit.
in systems which are configured without flash
This ensures that subsequent accesses properly hit the new window.
The dcbi during the NAND loop was accidentally working around this;
it's no longer necessary, as the cache is not enabled.
Reported-by: Suchit Lepcha <Suchit.Lepcha@freescale.com>
This patch adds support for MPC83xx PCI-E controllers in Root Complex
mode.
The patch is based on Tony Li and Dave Liu work[1].
Though unlike the original patch, by default we don't register PCI-E
buses for use in U-Boot, we only configure the controllers for future
use in other OSes (Linux). This is done because we don't have enough
of spare BATs to map all the PCI-E regions.
To actually use PCI-E in U-Boot, users should explicitly define
CONFIG_83XX_GENERIC_PCIE_REGISTER_HOSES symbol in the board file. And
only then U-Boot will able to access PCI-E, but at the cost of disabled
address translation.
[1] http://lists.denx.de/pipermail/u-boot/2008-January/027630.html
Signed-off-by: Tony Li <tony.li@freescale.com>
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Acked-by: Dave Liu <daveliu@freescale.com>
When running a system with 2 or more MPC8349EMDS boards in PCI agent mode,
the boards will lock up the PCI bus by scanning against each other.
The boards lock against each other by trying to access the PCI bus before
clearing their configuration lock bit. Both boards end up in a loop,
sending and receiving "Target Not Ready" messages forever.
When running in PCI agent mode, the scanning now takes place after the
boards have cleared their configuration lock bit.
Also, add a missing declaration to the mpc83xx.h header file, fixing a
build warning.
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
Currently there are in excess of 100 bytes located at the beginning of the image
built by start.S that are not being utilized. This patch moves a few functions
into this part of the image. This will create a greater number of *available*
bytes that can be used by board specific code in NAND builds and will decrease
the size of the assembled code in other builds.
Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net>
Fix up rsk7203 target to build successfully using out-of-tree build.
Signed-off-by: Kieran Bingham <kbingham@mpc-data.co.uk>
Parallel builds would occasionally issue this build warning:
ln: creating symbolic link `cpu/mpc824x/bedbug_603e.c': File exists
Use "ln -sf" as quick work around for the issue.
So that we can locate the DDR tlb start entry to the value other than 8. By
default, it is still 8.
Currently MPC85xx and MPC86xx boards just calculate the localbus frequency
and print it out, but don't save it.
This changes where its calculated and stored to be more consistent with the
CPU, CCB, TB, and DDR frequencies and the MPC83xx localbus clock.
The localbus frequency is added to sysinfo and calculated when sysinfo is
set up, in cpu/mpc8[56]xx/speed.c, the same as the other frequencies are.
get_clocks() copies the frequency into the global data, as the other
frequencies are, into a new field that is only enabled for MPC85xx and
MPC86xx.
checkcpu() in cpu/mpc8[56]xx/cpu.c will print out the local bus frequency
from sysinfo, like the other frequencies, instead of calculating it on the
spot.
Signed-off-by: Trent Piepho <tpiepho@freescale.com>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Acked-by: Jon Loeliger <jdl@freescale.com>
The local bus clock divider should be doubled for both 8610 and 8641.
The clock divider for the MPC8568 local bus should be doubled, like the
other newer MPC85xx chips.
Since there are now more chips with a 2x divider than a 1x, and any new
85xx chips will probably be 2x, invert the sense of the #if so that it
lists the 1x chips instead of the 2x ones.
If one custom board is using the 8MB flash, it is set
as FLASH_BASE = 0xef000000, TEXT_BASE = 0xef780000.
The current start.S code will be broken at switch_as.
It is because the TLB1[15] is set as 16MB page size,
EPN = TEXT_BASE & 0xff000000, RPN = 0xff000000.
For the 8MB flash case, the EPN = 0xefxxxxxx,
RPN = 0xffxxxxxx. Assume the virt address of switch_as
is 0xef7ff18c, the real address of the instruction at
switch_as should be 0xff7ff18c. the 0xff7ff18c is out
of the range of the default 8MB boot LAW window
0xff800000 - 0xffffffff.
So when we switch to AS1 address space at switch_as,
the core can't fetch the instruction at switch_as any
more. It will cause broken issue.
Assuming the OSes exception vectors start from the base of kernel address, and
the kernel physical starting address can be relocated to an non-zero address.
This patch enables the second core to have a valid IVPR for debugger before
kernel setting IVPR in CAMP mode. Otherwise, IVPR is 0x0 and it is not a valid
value for second core which runs kernel at different physical address other
than 0x0.
On newer CPUs, 8536, 8572, and 8610, the CLKDIV field of LCRR is five bits
instead of four.
In order to avoid an ifdef, LCRR_CLKDIV is set to 0x1f on all systems. It
should be safe as the fifth bit was defined as reserved and set to 0.
Code that was using a hard coded 0x0f is changed to use LCRR_CLKDIV.
Export the localbus frequency in the device tree, the same way the CPU, TB,
CCB, and various other frequencies are exported in their respective device
tree nodes.
Some localbus devices need this information to be programed correctly, so
it makes sense to export it along with the other frequencies.
Unfortunately, when someone wrote the localbus dts bindings, they didn't
bother to define what the "compatible" property should be. So it seems no
one was quite sure what to put in their dts files.
Based on current existing dts files in the kernel source, I've used
"fsl,pq3-localbus" and "fsl,elbc" for MPC85xx, which are used by almost all
of the 85xx devices, and are looked for by the Linux code. The eLBC is
apparently not entirely backward compatible with the pq3 LBC and so eLBC
equipped platforms like 8572 won't use pq3-localbus.
For MPC86xx, I've used "fsl,elbc" which is used by some of the 86xx systems
and is also looked for by the Linux code. On MPC8641, I've also used
"fsl,mpc8641-localbus" as it is also commonly used in dts files, some of
which don't use "fsl,elbc" or any other acceptable name to match on.
All implementations of the functions i2c_reg_read() and
i2c_reg_write() are identical. We can save space and simplify the
code by converting these functions into inlines and putting them in
i2c.h.
Acked-By: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Also fix some minor typos.
This warning is issued by modern ARM-EABI GCC on non-thumb targets.
Signed-off-by: Vladimir Panfilov <pvr@emcraft.com>
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
This patch now adds a flush to the data cache upon relocation. The
current implementation is missing this. Only a comment states that it
should be done. So let's really do it now.
This patch adds the CONFIG_SKIP_LOWLEVEL_INIT option to start.S. This
enables support for boards where the lowlevel initialization is
already done when U-Boot runs (e.g. via OnChip ROM).
This will be used in the upcoming VCTH board support.
Change to write/readX function and fix timer problem.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
Signed Off By: Graeme Russ <graeme.russ@gmail.com>
Since commit 561858ee building for FADS823 and RRvision
doesn't work. Let's include version.h and timestamp.h
unconditionally to fix the problem.
