path: root/cpu
2009-09-10ppc4xx: Fix compilation warning in 4xx miiphy.cStefan Roese
This patch fixes the following compilation warning: miiphy.c: In function 'emac4xx_miiphy_read': miiphy.c:353: warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-10ppc4xx: Allow overwriting pci target registers for all 4xx boardsMatthias Fuchs
This patch adds the CONFIG_PCI_4xx_PTM_OVERWRITE option and replaces the ugly 'if defined(BOARD1) || ... || defined(BOARDn)' construct in 4xx pci code. When CONFIG_PCI_4xx_PTM_OVERWRITE is defined the default ptm register setup can be overwritten through environment variables ptm1la, ptm1ms, ptm2la and ptm2ms to do application specific pci target BAR configuration. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-09ppc/85xx: Introduce RESET_VECTOR_ADDRESS to handle non-standard link addressKumar Gala
Some board ports place TEXT_BASE at a location that would cause the RESET_VECTOR_ADDRESS not to be at 0xfffffffc when we link. By default we assume RESET_VECTOR_ADDRESS will be 0xfffffffc if the board doesn't explicitly set it. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Wolfgang Denk <wd@denx.de>
2009-09-08ppc/85xx: Clean up do_resetKumar Gala
There is no reason to do a run time check for e500 v1 based cores to determine if we have the GUTs RSTCR facility. Only the first generation of PQ3 parts (MPC8540/41/55/60) do not have it. So checking to see if we are e500 v2 would miss future parts (like e500mc). Just change this to be ifdef'd based on CONFIG_MPC85{40,41,55,60}. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-08ppc/85xx/86xx: Bug fix: call to puts in probecpu() moved to checkcpu().Poonam Aggrwal
While in probecpu() UART is still not initialized. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-08ppc/85xx/86xx: Device tree fixup for number of coresPoonam Aggrwal
Fixing the number of cores in the device tree based on the actual number of cores on the system. With this same device tree image can be used for dual core and single core members of otherwise exactly same SOC. For example: * P2020RDB and P2010RDB * P1020RDB and P1011RDB * MPC8641D and MPC8641 Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-08ppc/85xx,86xx: Handling Unknown SOC versionPoonam Aggrwal
Incase the system is detected with Unknown SVR, let the system boot with a default value and a proper message. Now with dynamic detection of SOC properties from SVR, this is necessary to prevent a crash. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-08ppc/8xxx: Refactor code to determine if PCI is enabled & agent/hostKumar Gala
Refactor the code into a simple bitmask lookup table that determines if a given PCI controller is enabled and if its in host/root-complex or agent/end-point mode. Each processor in the PQ3/MPC86xx family specified different encodings for the cfg_host_agt[] and cfg_IO_ports[] boot strapping signals. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-08ppc/85xx: Cleanup makefile and related optional filesKumar Gala
Cleaned up cpu/mpc85xx/Makefile to use CONFIG_* for those obvious cases we have like PCI, CPM2, QE. Also reworked it to use one line per file for everything and sorted in alphabetical order. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-08ppc/85xx: Fix bug in setup_mp codeKumar Gala
Its possible that we try and copy the boot page code out of flash into a DDR location that doesn't have a TLB cover it. For example, if we have 3G of DDR we typically only map the first 2G. In the cases of 4G+ this wasn't an issue since the reset page TLB mapping covered the last page of memory which we wanted to copy to. We now change the physical address of the reset page TLB to map to the true physical location of the boot page code, copy and than set the TLB back to its 1:1 mapping of the reset page. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-08ppc/85xx: Add a simple function to search the TLBKumar Gala
Allow us to search the TLB array based on an address. This is useful if we want to change an entry but dont know where it happens to be located. For example, the boot page mapping we use on MP or the flash TLB that we change the WIMGE settings for after we've relocated. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-0885xx: Add support for setting IVORs to fixed offset defaultsKumar Gala
In future Book-E implementations IVORs will most likely go away and be replaced with fixed offsets. The IVPR will continue to exist to allow for relocation of the interrupt vectors. This code adds support to setup the IVORs as their fixed offset values per the ISA 2.06 spec when we transition from u-boot to another OS either via 'bootm' or a cpu release. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-08ppc/85xx: Fix up eSDHC controller clock frequency in the device treeDipen Dudhat
Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-08ppc/8xxx: Remove ddr_pd_cntl register since it doesn't existKumar Gala
The ddr_pd_cntl isn't defined in any reference manual and thus we wil remove especially since we set it to 0, which would most likely be its POR value. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-08ppc/85xx: Use CONFIG_FSL_ESDHC to enable sdhc clkDipen Dudhat
Enable eSDHC Clock based on generic CONFIG_FSL_ESDHC define instead of a platform define. This will enable all the 85xx platforms to use sdhc_clk based on CONFIG_FSL_ESDHC. Signed-off-by: Gao Guanhua <B22826@freescale.com> Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-07Merge branch 'master' of git://git.denx.de/u-boot-i2cWolfgang Denk
2009-09-07Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-09-06Reset i2c slave devices during init on mpc5xxx cpusEric Millbrandt
Reset any i2c devices that may have been interrupted during a system reset. Normally this would be accomplished by clocking the line until SCL and SDA are released and then sending a start condtiion (From an Atmel datasheet). There is no direct access to the i2c pins so instead create start commands through the i2c interface. Send a start command then delay for the SDA Hold time, repeat this by disabling/enabling the bus a total of 9 times. Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com>
2009-09-05ARM: DaVinci: DaVinci DM365 SOC specific codeSandeep Paulraj
This patch adds support for DaVinci DM365 SOC. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-09-04mpc83xx/serdes: License cleanup: remove "All Rights Reserved" noticeAnton Vorontsov
"All Rights Reserved" conflicts with the GPL. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2009-09-04arm: Remove -fno-strict-aliasingKumar Gala
-fno-strict-aliasing is hidding warnings. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-04ppc: Remove -fno-strict-aliasingKumar Gala
2009-09-04i386: Replace [read, write]_mmcr_[byte, word, long] with memory mapped structureGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-09-04i386: Misc PCI fixupsGraeme Russ
Change PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY (Originally done in commit ff4e66e93c1a, regressed by commit 6d7f610b09f8) Cast PCI_ROM_ADDRESS_MASK to u32 Wrap probe_pci_video() call inside #ifdef CONFIG_VIDEO Change call to pci_find_class() to pci_find_devices(). This is based on a patch submitted on 1st March 2007 (Patch that fixes the compilation errors for sc520_cdp board) by mushtaq_k This patch requires that PCI_VIDEO_VENDOR_ID and PCI_VIDEO_DEVICE_ID be specified in the board config file. Dummy values have been added for the SC520 CDP board to enable compilation, but since I do not have one of these, I do know what the values should be Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-09-04Fix sc520 timer interrupt generationGraeme Russ
The current implementation has the timer being started before the interrupt handler is installed. It the interrupt occurs before the handler is installed, the timer interrupt is never reset and the timer stops Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-09-04i386: Change inline asm global symbols to localGraeme Russ
gcc 4.3.2 optimiser creates multiple copies of inline asm (who knows why) Remove use of global names for labels to prevent 'symbol already defined' errors Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-09-02Blackfin: use scratch pad for exception stackMike Frysinger
If the memory layout pushes the stack out of the default DCPLB coverage, the exception handler may trigger a double fault by trying to push onto the uncovered stack. So handle the exception stack similar to the kernel by using the top of the scratch pad SRAM. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-01arm: Kirkwood: add SYSRSTn Duration Counter SupportPrafulla Wadaskar
This feature can be used to trigger special command "sysrstcmd" using reset key long press event and environment variable "sysrstdelay" is set (useful for reset to factory or manufacturing mode execution) Kirkwood SoC implements a hardware-based SYSRSTn duration counter. When SYSRSTn is asserted low, a SYSRSTn duration counter is running. The counter value is stored in the SYSRSTn Length Counter Register The counter is based on the 25-MHz reference clock (40ns) It is a 29-bit counter, yielding a maximum counting duration of 2^29/25 MHz (21.4 seconds). When the counter reach its maximum value, it remains at this value until counter reset is triggered by setting bit 31 of KW_REG_SYSRST_CNT Implementation: Upon long reset assertion (> ${sysrstdelay} in secs) sysrstcmd will be executed if pre-defined in environment variables. This feature will be disabled if "sysrstdelay" variable is unset. for-ex. setenv sysrst_cmd "echo starting factory reset; nand erase 0xa0000 0x20000; echo finish ed sysrst command;" will erase particular nand sector if triggered by this event Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-09-01Add support for the Calao SBC35-A9G20 boardAlbin Tonnerre
The Calao SBC35-A9G20 board is manufactured and sold by Calao Systems <http://www.calao-systems.com>. It is built around an AT91SAM9G20 ARM SoC running at 400MHz. It features an Ethernet port, an SPI RTC backed by an onboard battery , an SD/MMC slot, a CompactFlash slot, 64Mo of SDRAM, 256Mo of NAND flash, two USB host ports, and an USB device port. More informations can be found at <http://www.calao-systems.com/articles.php?lng=en&pg=5936> Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
2009-09-01imx27lite: add support for imx27lite board from LogicPDIlya Yanok
This patch adds support for i.MX27-LITEKIT development board from LogicPD. This board uses i.MX27 SoC and has 2MB NOR flash, 64MB NAND flash, FEC ethernet controller integrated into i.MX27. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Acked-by: Wolfgang Denk <wd@denx.de>
2009-08-2885xx: Improve MPIC initializationTimur Tabi
The MPIC initialization code for Freescale e500 CPUs was not using I/O accessors, and it was not issuing a read-back to the MPIC after setting mixed mode. This may be the cause of a spurious interrupt on some systems. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Added single core members of FSL P1xx/P2xx processors seriesPoonam Aggrwal
P1011 - Single core variant of P1020 P2010 - Single core variant of P2020 Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Add L2SRAM Register's macro definitionMingkai Hu
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Move to a common linker scriptKumar Gala
There are really no differences between all the 85xx linker scripts so we can just move to a single common one. Board code is still able to override the common one if need be. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Added P1020 Processor Support.Poonam Aggrwal
P1020 is another member of QorIQ series of processors which falls in ULE category. It is an e500 based dual core SOC. Being a scaled down version of P2020 it has following differences: - 533MHz - 800MHz core frequency. - 256Kbyte L2 cache - Ethernet controllers with classification capabilities. Also the SOC is pin compatible with P2020 Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-288xxx: Removed CONFIG_NUM_CPUS from 85xx/86xxPoonam Aggrwal
The number of CPUs are getting detected dynamically by checking the processor SVR value. Also removed CONFIG_NUM_CPUS references from all the platforms with 85xx/86xx processors. This can help to use the same u-boot image across the platforms. Also revamped and corrected few Freescale Copyright messages. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-288xxx: Refactored common cpu specific code for 85xx/86xx into one file.Poonam Aggrwal
Removed same code pieces from cpu/mpc85xx/cpu.c and cpu/mpc86xx/cpu.c and moved to cpu/mpc8xxx/cpu.c(new file) Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2886xx: Remove redudant PLATFORM_CPPFLAGSKumar Gala
For historic reasons we had defined some additional PLATFORM_CPPFLAGS like: PLATFORM_CPPFLAGS += -DCONFIG_MPC86xx=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC8641=1 However these are all captured in the config.h and thus redudant. Also moved common 86xx flags into cpu/mpc86xx/config.mk. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Remove redudant PLATFORM_CPPFLAGSKumar Gala
For historic reasons we had defined some additional PLATFORM_CPPFLAGS like: PLATFORM_CPPFLAGS += -DCONFIG_E500=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC85xx=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC8548=1 However these are all captured in the config.h and thus redudant. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-26ColdFire: Fix compile warning messagesTsiChung Liew
Change %08lX to %08X in board.c. Remove unused variable 'oscillator' in mcf5227x/cpu_init.c and 'scm2' in mcf532x/cpu_init.c. Provide argument type cast in drivers/dma/MCD_dmaApi.c. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-08-25Add support for USB on PSC3 for the mpc5200Eric Millbrandt
Support USB on PSC3 on the mpc5200. Before this patch, enabling USB support would reconfigure PSC4 and PSC5 to USB. The mpc5200 does not support USB enabled on both the standard USB port and PSC3. This patch masks the appropriate bits when enabling USB. Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Remy Bohmer <linux@bohmer.net>
2009-08-22Prepare 2009.08-rc3v2009.08-rc3Wolfgang Denk
Update CHANGELOG, minor Coding Style cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-08-21ARM: compiler options cleanup - improve tool chain supportWolfgang Denk
For some time there have been repeated reports about build problems with some ARM (cross) tool chains. Especially issues about (in)compatibility with the tool chain provided runtime support library libgcc.a caused to add and support a private implementation of such runtime support code in U-Boot. A closer look at the code indicated that some of these issues are actually home-made. This patch attempts to clean up some of the most obvious problems and make building of U-Boot with different tool chains easier: - Even though all ARM systems basicy used the same compiler options to select a specific ABI from the tool chain, the code for this was distributed over all cpu/*/config.mk files. We move this one level up into lib_arm/config.mk instead. - So far, we only checked if "-mapcs-32" was supported by the tool chain; if yes, this was used, if not, "-mabi=apcs-gnu" was selected, no matter if the tool chain actually understood this option. There was no support for EABI conformant tool chains. This patch implements the following logic: 1) If the tool chain supports "-mabi=aapcs-linux -mno-thumb-interwork" we use these options (EABI conformant tool chain). 2) Otherwise, we check first if "-mapcs-32" is supported, and then check for "-mabi=apcs-gnu" If one test succeeds, we use the first found option. 3) In case 2), we also test if "-mno-thumb-interwork", and use this if the test succeeds. [For "-mabi=aapcs-linux" we set "-mno-thumb-interwork" mandatorily.] This way we use a similar logic for the compile options as the Linux kernel does. - Some EABI conformant tool chains cause external references to utility functions like raise(); such functions are provided in the new file lib_arm/eabi_compat.c Note that lib_arm/config.mk gets parsed several times, so we must make sure to add eabi_compat.o only once to the linker list. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Dirk Behme <dirk.behme@googlemail.com> Cc: Magnus Lilja <lilja.magnus@gmail.com> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Sergey Kubushyn <ksi@koi8.net> Tested-by: Magnus Lilja <lilja.magnus@gmail.com> Tested-by: Andrzej Wolski <awolski@poczta.fm> Tested-by: Gaye Abdoulaye Walsimou <walsimou@walsimou.com> Tested-by: Tom Rix <Tom.Rix@windriver.com> Tested-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-08-1485xx: Fix addrmap to include memoryKumar Gala
When we init the addrmap based on the TLB we will not end up getting the TLB that covers memory if we are using SPD. The reason is we haven't relocated at the point that we setup the memory TLB and thus it will not get setup in the addrmap. Instead we can just walk over the TLB array after we've relocated and see all the TLBs that have been set and use that information to populate the initial addrmap. By doing this we insure that we get the TLB entries that cover memory. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-10Minor coding style cleanup.Wolfgang Denk
2009-08-10ARM Cortex A8: Remove bogus config.mk entriesDirk Behme
Remove bogus config.mk entry, fix newline and remove redundant omap3/config.mk Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-08-09mxc-mmc: sdhc host driver for MX2 and MX3 proccessorIlya Yanok
This is a port of Linux driver for SDHC host controller hardware found on Freescale's MX2 and MX3 processors. Uses new generic MMC framework (CONFIG_GENERIC_MMC) and it looks like there are some problems with a framework (at least on LE cpus). Some of these problems are addressed in the following patches. Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2009-08-09Dual-license IBM code contributionsJosh Boyer
It was brought to our attention that U-Boot contains code derived from the IBM OpenBIOS source code originally provided with some of the older PowerPC 4xx development boards. As a result, the original license of this code has been carried in the various files for a number of years in the U-Boot project. IBM is dual-licensing the IBM code contributions already present in U-Boot under either the terms of the GNU General Public License version 2, or the original code license already present. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2009-08-08omap3: bug fix for NOR boot supportPenda Naveen Kumar
This patch provides bug fix, when omap3 uses nor boot. Signed-off-by: Penda Naveen Kumar<pnaveen@ti.com> Acked-by: Dirk Behme <dirk.behme@googlemail.com>
2009-08-08omap3: replace all instances of gpmc config struct by one globalDirk Behme
Signed-off-by: Matthias Ludwig <mludwig@ultratronik.de> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
