path: root/cpu
2009-08-21ARM: compiler options cleanup - improve tool chain supportWolfgang Denk
For some time there have been repeated reports about build problems with some ARM (cross) tool chains. Especially issues about (in)compatibility with the tool chain provided runtime support library libgcc.a caused to add and support a private implementation of such runtime support code in U-Boot. A closer look at the code indicated that some of these issues are actually home-made. This patch attempts to clean up some of the most obvious problems and make building of U-Boot with different tool chains easier: - Even though all ARM systems basicy used the same compiler options to select a specific ABI from the tool chain, the code for this was distributed over all cpu/*/config.mk files. We move this one level up into lib_arm/config.mk instead. - So far, we only checked if "-mapcs-32" was supported by the tool chain; if yes, this was used, if not, "-mabi=apcs-gnu" was selected, no matter if the tool chain actually understood this option. There was no support for EABI conformant tool chains. This patch implements the following logic: 1) If the tool chain supports "-mabi=aapcs-linux -mno-thumb-interwork" we use these options (EABI conformant tool chain). 2) Otherwise, we check first if "-mapcs-32" is supported, and then check for "-mabi=apcs-gnu" If one test succeeds, we use the first found option. 3) In case 2), we also test if "-mno-thumb-interwork", and use this if the test succeeds. [For "-mabi=aapcs-linux" we set "-mno-thumb-interwork" mandatorily.] This way we use a similar logic for the compile options as the Linux kernel does. - Some EABI conformant tool chains cause external references to utility functions like raise(); such functions are provided in the new file lib_arm/eabi_compat.c Note that lib_arm/config.mk gets parsed several times, so we must make sure to add eabi_compat.o only once to the linker list. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Dirk Behme <dirk.behme@googlemail.com> Cc: Magnus Lilja <lilja.magnus@gmail.com> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Sergey Kubushyn <ksi@koi8.net> Tested-by: Magnus Lilja <lilja.magnus@gmail.com> Tested-by: Andrzej Wolski <awolski@poczta.fm> Tested-by: Gaye Abdoulaye Walsimou <walsimou@walsimou.com> Tested-by: Tom Rix <Tom.Rix@windriver.com> Tested-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-08-1485xx: Fix addrmap to include memoryKumar Gala
When we init the addrmap based on the TLB we will not end up getting the TLB that covers memory if we are using SPD. The reason is we haven't relocated at the point that we setup the memory TLB and thus it will not get setup in the addrmap. Instead we can just walk over the TLB array after we've relocated and see all the TLBs that have been set and use that information to populate the initial addrmap. By doing this we insure that we get the TLB entries that cover memory. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-10Minor coding style cleanup.Wolfgang Denk
2009-08-10ARM Cortex A8: Remove bogus config.mk entriesDirk Behme
Remove bogus config.mk entry, fix newline and remove redundant omap3/config.mk Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-08-09mxc-mmc: sdhc host driver for MX2 and MX3 proccessorIlya Yanok
This is a port of Linux driver for SDHC host controller hardware found on Freescale's MX2 and MX3 processors. Uses new generic MMC framework (CONFIG_GENERIC_MMC) and it looks like there are some problems with a framework (at least on LE cpus). Some of these problems are addressed in the following patches. Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2009-08-09Dual-license IBM code contributionsJosh Boyer
It was brought to our attention that U-Boot contains code derived from the IBM OpenBIOS source code originally provided with some of the older PowerPC 4xx development boards. As a result, the original license of this code has been carried in the various files for a number of years in the U-Boot project. IBM is dual-licensing the IBM code contributions already present in U-Boot under either the terms of the GNU General Public License version 2, or the original code license already present. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2009-08-08omap3: bug fix for NOR boot supportPenda Naveen Kumar
This patch provides bug fix, when omap3 uses nor boot. Signed-off-by: Penda Naveen Kumar<pnaveen@ti.com> Acked-by: Dirk Behme <dirk.behme@googlemail.com>
2009-08-08omap3: replace all instances of gpmc config struct by one globalDirk Behme
Signed-off-by: Matthias Ludwig <mludwig@ultratronik.de> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-08-08omap3: remove typedefs for configuration structsDirk Behme
2009-08-07omap3: embedd gpmc_cs into gpmc config structMatthias Ludwig
Embedd chip select configuration into struct for gpmc config instead of having it completely separated as suggested by Wolfgang Denk on http://lists.denx.de/pipermail/u-boot/2009-May/052247.html Signed-off-by: Matthias Ludwig <mludwig@ultratronik.de>
2009-08-04Merge branch 'next' of git://git.denx.de/u-boot-coldfireWolfgang Denk
2009-08-03rm9200 lowevel_init: don't touch reserved/readonly registersDavid Brownell
For some reason the AT91rm9200 lowlevel init writes to a bunch of reserved or read-only addresses. All the boards seem to define the value-to-be-written values as zero ... but they shouldn't actually be writing *anything* there. No documented erratum justifies these accesses. It looks like maybe some pre-release BDI-2000 setup code has been carried along by cargo cult programming since at least late 2004 (per GIT history). Here's a patch disabling what seems to be bogosity. Tested on a csb337; there were no behavioral changes. Signed-off-by: David Brownell <david-b@pacbell.net> on RM9200ek Tested-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-08-01Add AT91SAM9260 to at91's lowlevel_init.SEric Benard
Needed for AT91SAM9260 NOR Boot on Eukrea's CPU9260. Signed-off-by: Eric Benard <eric@eukrea.com>
2009-07-30ppc4xx: Add basic support for AMCC PPC460EX/460GT rev B chipsStefan Roese
This patch is based on a diff created by Phong Vo from AMCC. Signed-off-by: Phong Vo <pvo@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-30Merge branch 'master' of git://git.denx.de/u-boot-i2cWolfgang Denk
2009-07-29Update Freescale copyrights to remove "All Rights Reserved"Kumar Gala
"All Rights Reserved" conflicts with the GPL. Signed-off-by: Kumar Gala <kumar.gala@freescale.com>
2009-07-29arm nomadik: add gpio supportAlessandro Rubini
Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-07-27mpc83xx: CONFIG_83XX_GENERIC_PCI is now synonymous with CONFIG_PCI; remove ↵Kim Phillips
the former Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-27cpu/arm920t/start.S: include <common.h> to have ROUND() definedWolfgang Denk
Commit fcd3c87e made include/common.h usable by assembler code but failed to update cpu/arm920t/start.S Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-27Make include/common.h usable by assembler codeWolfgang Denk
Commit 70ebf316 factored out the ROUND() macro into include/common.h, not realizing that the primary use of this macro on AT91 systems was in start.S where common.h was not included, and could not be included because it contains a lot of C code which the assembler doesn't understand. This patch wraps such code in common.h in a "#ifndef __ASSEMBLY__" construct, and then adds an include to cpu/arm926ejs/start.S thus solving the problem. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-26Merge branch 'master' of git://git.denx.de/u-boot-videoWolfgang Denk
2009-07-26Add AVR32 LCD supportMark Jackson
This patch adds support for the AVR32 LCD controller. This patch is based off the latest u-boot-video. A quick summary of what's going on:- Enable LCDC pixel clock Enable LCDC port pins Add framebuffer pointer to global_data struct Allocate framebuffer To use the new code, update your board config to include something like this:- #define CONFIG_LCD 1 #if defined(CONFIG_LCD) #define CONFIG_CMD_BMP #define CONFIG_ATMEL_LCD 1 #define LCD_BPP LCD_COLOR16 #define CONFIG_BMP_16BPP 1 #define CONFIG_FB_ADDR 0x10600000 #define CONFIG_WHITE_ON_BLACK 1 #define CONFIG_VIDEO_BMP_GZIP 1 #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE 262144 #define CONFIG_ATMEL_LCD_BGR555 1 #define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 #define CONFIG_SPLASH_SCREEN 1 #endif The standard U-Boot BMP and Splash-screen features should just work. Signed-off-by: Mark Jackson <mpfj@mimc.co.uk> [agust@denx.de: fixed some style issues] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2009-07-24ppc4xx: Replace 4xx lowercase SPR referencesMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-24Add "chip_config" command for PPC4xx bootstrap configurationStefan Roese
This patch adds a generic command for programming I2C bootstrap eeproms on PPC4xx. An implementation for Canyonlands board is included. The command name is intentionally chosen not to be PPC4xx specific. This way other CPU's/SoC's can implement a similar command under the same name, perhaps with a different syntax. Usage on Canyonlands: => chip_config Available configurations (I2C address 0x52): 600-nor - NOR CPU: 600 PLB: 200 OPB: 100 EBC: 100 600-nand - NAND CPU: 600 PLB: 200 OPB: 100 EBC: 100 800-nor - NOR CPU: 800 PLB: 200 OPB: 100 EBC: 100 800-nand - NAND CPU: 800 PLB: 200 OPB: 100 EBC: 100 1000-nor - NOR CPU:1000 PLB: 200 OPB: 100 EBC: 100 1000-nand - NAND CPU:1000 PLB: 200 OPB: 100 EBC: 100 1066-nor - NOR CPU:1066 PLB: 266 OPB: 88 EBC: 88 *** 1066-nand - NAND CPU:1066 PLB: 266 OPB: 88 EBC: 88 => chip_config 600-nor Using configuration: 600-nor - NOR CPU: 600 PLB: 200 OPB: 100 EBC: 100 done (dump via 'i2c md 52 0.1 10') Reset the board for the changes to take effect Other 4xx boards will be migrated to use this command soon as well. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Dirk Eibach <eibach@gdsys.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2009-07-24ppc4xx: Fix missing freqOPB for 405EPDirk Eibach
In cpu/ppc4xx/speed.c initialization of sysInfo->freqOPB for 405EP was left out for no obvious reason. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-24ppc4xx: Fix TLB reset problem with recent 44x imagesStefan Roese
Patch d873133f [ppc4xx: Add Sequoia RAM-booting target] broke "normal" booting on some 44x platforms. This breakage is only noticed in some cases while powercycling. As it seems, the code in question in start.S didn't invalidate TLB #0. This makes sense since this TLB is used for the bootrom mapping. With the patch mentioned above even TLB #0 got invalidated resulting in an error later on. This patch now fixes this issue by only invalidating TLB #0 in the RAM- booting case. Tested succesfully on Sequoia and Canyonlands. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <Eibach@gdsys.de>
2009-07-23unify HOST_CFLAGS and HOSTCFLAGSMike Frysinger
The top build system sets up HOSTCFLAGS a bit and exports it, but other places use HOST_CFLAGS instead. Unify the two as HOSTCFLAGS so that the values stay in sync. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-22fec_mxc: driver for FEC ethernet controller on i.MX27Ilya Yanok
Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-22rm9200 ethernet driver: board-specific quirk (csb337)David Brownell
CSB337 boards originally shipped with MicroMonitor, not U-Boot; and with a version using a different convention for recording Ethernet addresses than anyone else. To avoid breaking Linux when it uses U-Boot, have it use the same convention on that hardware. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-23Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-07-22ARM Cortex A8: Move OMAP3 specific reset handlerMinkyu Kang
Because of the reset_cpu is soc specific, should be move to soc Cc: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-07-2285xx, 86xx: Add common board_add_ram_info()Peter Tyser
Previously, 85xx and 86xx boards would display DRAM information on bootup such as: ... I2C: ready DRAM: Memory controller interleaving enabled: Bank interleaving! 2 GB FLASH: 256 MB ... This patch moves the printing of the DRAM controller configuration to a common board_add_ram_info() function which prints out DDR type, width, CAS latency, and ECC mode. It also makes the DDR interleaving information print out in a more sane manner: ... I2C: ready DRAM: 2 GB (DDR2, 64-bit, CL=4, ECC on) DDR Controller Interleaving Mode: bank FLASH: 256 MB ... Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-2286xx: Rename ccsr_ddr's sdram_mode_1, sdram_cfg_1 fieldsPeter Tyser
Rename sdram_mode_1 to sdram_mode and sdram_cfg_1 to sdram_cfg to match the 86xx user's manual and other Freescale architectures Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-18Blackfin: split cpu COBJS into multilinesMike Frysinger
2009-07-18Blackfin: add os log functionsMike Frysinger
Part of the mini Blackfin ABI with operating systems is that they can use 0x4f0-0x4f8 to pass log buffers to/from bootloaders. So add support to U-Boot for reading the log buffer. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-19Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
2009-07-18OMAP3 Fix compiler warning for v7_flush_dcache_allTom Rix
On build of omap3 targets in MAKEALL, the *.ERR files have cpu.c: In function 'cleanup_before_linux': cpu.c:64: warning: implicit declaration of function 'v7_flush_dcache_all' cpu.c:64: warning: implicit declaration of function 'get_device_type The functions v7_flush_dcache_all and get_device_type are declared in include/asm-arm/arch-omap3/sys_proto.h, so use this file to declare the functions. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-16nand/ppc4xx: Move PPC4xx NAND driver to common NAND driver directoryStefan Roese
Signed-off-by: Stefan Roese <sr@denx.de> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-14usb: mpc834x: added support of the MPH USB controller in addition to the DR oneValeriy Glushkov
Signed-off-by: Valeriy Glushkov <gvv@lstec.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-14ColdFire: Add DSPI support for MCF5227x and MCF5445xTsiChung Liew
Remove individual CPU specific DSPI driver. Add required feature for the common DSPI driver in cpu_init and in platform configuration file. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-07-14ColdFire: Add M5208EVB and MCF520x CPU supportTsiChung Liew
2009-07-14ColdFire: Update for M54451EVBTsiChung Liew
Update serial boot DRAM's Internal RAM, vector table and DRAM in start.S, serial flash's read status command over SPI and NOR flash. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-07-14MPC512x: factor out common codeWolfgang Denk
Now that we have 3 boards for the MPC512x it turns out that they all use the very same fixed_sdram() code. This patch factors out this common code into cpu/mpc512x/fixed_sdram.c and adds a new header file, include/asm-ppc/mpc512x.h, with some macros, inline functions and prototype definitions specific to MPC512x systems. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2009-07-14Merge branch 'master' of /home/wd/git/u-boot/masterWolfgang Denk
2009-07-13Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-07-13Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
2009-07-13Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2009-07-12at91: Introduction of at91sam9g10 SOC.Sedji Gaouaou
AT91sam9g10 is an ARM 926ej-s SOC. It is an evolution of the at91sam9261 with a faster clock speed: 266/133MHz. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
2009-07-12at91: Introduction of at91sam9g45 SOC.Sedji Gaouaou
AT91sam9g45 series is an ARM 926ej-s SOC family clocked at 400/133MHz. It embeds USB high speed host and device, LCD, DDR2 RAM, and a full set of peripherals. The first board that embeds at91sam9g45 chip is the AT91SAM9G45-EKES. On the board you can find 2 USART, USB high speed, a 480*272 LG lcd, ethernet, gpio/joystick/buttons. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
