We define CONFIG_MONITOR_BASE_EARLY to define the initial location
of the bootpage in flash. Use this to create an early mapping
definition for the FLASH, and change the early_bats code to use this.
This change facilitates the relocation of the flash since the early
mappings are no longer tied to the final location of the flash.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Using a mtmsr/blr means that you have to be executing at the
same virtual address once you enable translation. This is
unnecessarily restrictive, and is not really how this is
usually done. Change it to use the more common mtspr SRR0/SRR1
and rfi method.
In order to later allow for a physical relocation of the
flash, setup_bats, which sets up the final BAT mapping
for the board, needs to happen *after* init_laws().
Otherwise, there will be no window programmed for the flash
at the new physical location at the point when we change
the mmu translation.
Removed initialization of the driver from net/eth.c
Also changed path in all linker scripts that reference this driver
All in-tree IBM/AMCC PPC4xx boards using the EMAC get this new CONFIG
Affected boards:
Several MPC8xx boards
Several MPC8260/MPC8272 boards
Several MPC85xx boards
CONFIG_MPC85xx_FEC -> CONFIG_MPC85XX_FEC
This patch will move au1x00_eth_initialize from net/eth.c to cpu_eth_init
as a part of ongoing eth_initialize cleanup work. The function ret value
is also fixed as it should be negative on fail.
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
Also, removed the driver initialization from net/eth.c
Signed-off-by: Tomohiro Masubuchi <tomohiro_masubuchi@tripeaks.co.jp>
OMAP identification is implemented in 'cpuinfo.c' and located in ARM926EJ-S directory.
It makes sense to place this file in OMAP specific subdirectory, i.e. cpu/arm926ejs/omap
Signed-off-by: Roman Mashak <romez777@gmail.com>
We put the bootpg for the secondary cpus into memory and use
BPTR to get to it. This is a step towards converting to the
ePAPR boot methodology. Also, the code is written to
deal properly with more than 4GB of RAM.
Currently, the CCSR gets relocated while translation is
enabled, meaning we need 2 BAT translations to get to both the
old location and the new location. Also, the DEFAULT
CCSR location has a dependency on the BAT that maps the
FLASH region. Moving the relocation removes this unnecessary
dependency. This makes it easier and more intutive to
modify the board's memory map.
Swap BATs 3 and 4 on 8610 so that all 86xx boards use the same
BAT for CCSR space.
The error was caused by the change for strmhz() in cpu.c.
A few of them were one extra close parenthesis.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Add serial boot support
Place FEC pin assignments in cpu_init.c from platform's
mii.c
Consolidate ATA, ePORT, QSPI, FlexCan, PWM, RNG,
MDHA, SKHA, INTC, and FlexBus structures and
definitions in immap_5xxx.h to more unify modules
header files. Append DSPI support for m547x_8x.
SSI cleanup. Remove USB Host structure from immap_539.h.
Apply changes to use FlexBus structures in mcf52x2's
cpu_init.c and platform configuration files.
There were several, now there is one (two if you count the lower-case
versions).
Signed-off-by: Andy Fleming <afleming@freescale.com>
The patch is following the commit 392438406041415fe64ab8748ec5ab5ad01d1cf7
mpc86xx: use r4 instead of r2 in lock_ram_in_cache and unlock_ram_in_cache
This is needed in unlock_ram_in_cache() because it is called from C and
will corrupt the small data area anchor that is kept in R2.
lock_ram_in_cache() is modified similarly as good coding practice, but
is not called from C.
Signed-off-by: Nick Spence <nick.spence@freescale.com>
also, the r2 is used as global data pointer.
Signed-off-by: Dave Liu <daveliu@freescale.com>
The current calculation will fail to cover all memory if
its size is not a power of two.
The commit 67256678f00c09b0a7f19e862e5c1847553d31bc add
the another global data pointer save, but in fact the
global data pointer will be initialized in the board_init_r,
so remove it such as the 85xx/83xx family.
Acked-by: Kumar Gala <kumar.gala@freescale.com>
I believe these code was copied from 74xx family, but for
86xx, it is unused.
We must invalidate TLBs before MMU turn on, but
currently the code is not, if there are some stale
TLB entry valid in the TLBs, it will cause strange
issue.
Acked-by: Becky Bruce <becky.bruce@freescale.com>
- Rename lbus83xx_t to fsl_lbus_t and move it to asm/fsl_lbc.h so that it
can be shared by both 83xx and 85xx
- Remove lbus83xx_t and replace it with fsl_lbus_t in all 83xx boards
files which use lbus83xx_t.
- Move FMR, FIR, FCR, FPAR, LTESR from mpc83xx.h to asm/fsl_lbc.h so that
85xx can share them.
Signed-off-by: Jason Jin <Jason.Jin@freescale.com>
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
Renamed show_boot_progress in assembler init phase to
show_boot_progress_asm to avoid link conflicts with C version
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
The 8572 DDR erratum1:
DDR controller may enter an illegal state when operating
in 32-bit bus mode with 4-beat bursts.
Description:
When operating with a 32-bit bus, it is recommended that
DDR_SDRAM_CFG[8_BE] is cleared when DDR2 memories are used.
This forces the DDR controller to use 4-beat bursts when
communicating to the DRAMs. However, an issue exists that
could lead to data corruption when the DDR controller is
in 32-bit bus mode while using 4-beat bursts.
Projected Impact:
If the DDR controller is operating in 32-bit bus mode with
4-beat bursts, then the controller may enter into a bad state.
All subsequent reads from memory is corrupted.
Four-beat bursts with a 32-bit bus only is used with DDR2 memories.
Therefore, this erratum does not affect DDR3 mode.
Work Arounds:
To work around this issue, software must set DEBUG_1[31] in
DDR memory mapped space (CCSRBAR offset + 0x2f00 for DDR_1
and CCSRBAR offset + 0x6f00 for DDR_2).
Currenlty, the code is using incorrect register DDR_SDRAM_CFG_2
as condition, but it should be DDR_SDRAM_CFG register.
Introduce CONFIG_E500MC to deal with the minor differences between
e500v2 and e500mc.
* Certain fields of HID0/1 don't exist anymore on e500mc
* Cache line size is 64-bytes on e500mc
* reset value of PIR is different
Using CONFIG_SYS_CACHELINE_SIZE instead of 31 means we can handle
e500mc's 64-byte cacheline properly when it gets added.
As "ppc44x: Unification of virtex5 pp440 boards" did for the xilinx
ppc440 boards, this patch presents a common architecture for all the
xilinx ppc405 boards.
Any custom xilinx ppc405 board can be added very easily with no code
duplicity.
This patch also adds a simple generic board, that can be used on almost
any design with xilinx ppc405 replacing the file ppc405-generic/xparameters.h
This patch is prepared to work with the latest version of EDK (10.1)
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
Some Blackfin UARTs are read-to-clear while others are write-to-clear.
This can cause problems when we poll the LSR and then later try and handle
any errors detected.
Use the sti instruction to set the initial interrupt mask rather than
banging on the core IMASK MMR to save both space and time.
We should use the algorithm in the Linux kernel so that the UART divisor
calculation is more accurate. It also fixes problems on some picky UARTs
that have sampling anomalies.
Having to decode hwerrcause/excause values is a pain, so automate it.
Make sure we report RETI/IPEND correctly.
The hang function already tells you to reboot, so no point in showing it
twice.
During cpu init, make sure we initialize the CEC properly so that
interrupts can fire and be handled while U-Boot is running.
