According to the PPC reference implementation the udelay() function is
responsible for resetting the watchdog timer as frequently as needed.
Most other architectures do not meet that requirement, so long-running
operations might result in a watchdog reset.
This patch adds a generic udelay() function which takes care of
resetting the watchdog before calling an architecture-specific
__udelay().
Signed-off-by: Ingo van Lil <inguin@gmx.de>
-fno-strict-aliasing is hidding warnings.
For some time there have been repeated reports about build problems
with some ARM (cross) tool chains. Especially issues about
(in)compatibility with the tool chain provided runtime support
library libgcc.a caused to add and support a private implementation
of such runtime support code in U-Boot. A closer look at the code
indicated that some of these issues are actually home-made. This
patch attempts to clean up some of the most obvious problems and make
building of U-Boot with different tool chains easier:
- Even though all ARM systems basicy used the same compiler options
to select a specific ABI from the tool chain, the code for this was
distributed over all cpu/*/config.mk files. We move this one level
up into lib_arm/config.mk instead.
- So far, we only checked if "-mapcs-32" was supported by the tool
chain; if yes, this was used, if not, "-mabi=apcs-gnu" was
selected, no matter if the tool chain actually understood this
option. There was no support for EABI conformant tool chains.
This patch implements the following logic:
1) If the tool chain supports
"-mabi=aapcs-linux -mno-thumb-interwork"
we use these options (EABI conformant tool chain).
2) Otherwise, we check first if
"-mapcs-32"
is supported, and then check for
"-mabi=apcs-gnu"
If one test succeeds, we use the first found option.
3) In case 2), we also test if "-mno-thumb-interwork", and use
this if the test succeeds. [For "-mabi=aapcs-linux" we set
"-mno-thumb-interwork" mandatorily.]
This way we use a similar logic for the compile options as the
Linux kernel does.
- Some EABI conformant tool chains cause external references to
utility functions like raise(); such functions are provided in the
new file lib_arm/eabi_compat.c
Note that lib_arm/config.mk gets parsed several times, so we must
make sure to add eabi_compat.o only once to the linker list.
Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Cc: Dirk Behme <dirk.behme@googlemail.com>
Cc: Magnus Lilja <lilja.magnus@gmail.com>
Cc: Tom Rix <Tom.Rix@windriver.com>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Acked-by: Sergey Kubushyn <ksi@koi8.net>
Tested-by: Magnus Lilja <lilja.magnus@gmail.com>
Tested-by: Andrzej Wolski <awolski@poczta.fm>
Tested-by: Gaye Abdoulaye Walsimou <walsimou@walsimou.com>
Tested-by: Tom Rix <Tom.Rix@windriver.com>
Tested-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
So far the console API uses the following naming convention:
======Extract======
typedef struct device_t;
int device_register (device_t * dev);
int devices_init (void);
int device_deregister(char *devname);
struct list_head* device_get_list(void);
device_t* device_get_by_name(char* name);
device_t* device_clone(device_t *dev);
which is too generic and confusing.
Instead of using device_XX and device_t we change this
into stdio_XX and stdio_dev
This will also allow to add later a generic device mechanism in order
to have support for multiple devices and driver instances.
Edited commit message.
move s3c44b0 to arch_cpu_init and as noone use cpu_init remove it
all arm init the IRQ stack the same way
so unify it in lib_arm/interrupts.c and then call arch specific interrupt init
all arm boards except a few use the same cpu linker script
so move it to cpu/$(CPU)
that could be overwrite in following order
SOC
BOARD
via the corresponding config.mk
actually the timer init use the interrupt_init as init callback
which make the interrupt and timer implementation difficult to follow
so now rename it as int timer_init(void) and use interrupt_init for interrupt
btw also remane the corresponding file to the functionnality implemented
as ixp arch implement two timer - one based on interrupt - so all the timer
related code is moved to timer.c
unify arm cache management except for non standard cache as ARM7TDMI
import system.h from linux
introduce new macro CONFIG_PXA_MMC to activate it
These structures are defined in the common mmc.h
This was compile checked on cerf250.
Fixing the get_timer function to return time in miliseconds instead of
ticks. Also fixed PXA boards to use the conventional value of 1000 for
CONFIG_SYS_HZ.
Signed-off-by: Micha Kalfon <smichak.uv@gmail.com>
The current MMC infrastructure relies on the existence of an
arch-specific header file. This isn't necessary, and a couple
drivers were forced to implement dummy files to meet this requirement.
Instead, we move the stuff in those header files into a more appropriate
place, and eliminate the stubs and the #include of asm/arch/mmc.h
Signed-off-by: Andy Fleming <afleming@freescale.com>
This is to get it out of the way of incoming MMC framework
MMC cards are not memory, so we stop treating them that way.
All implementations of the functions i2c_reg_read() and
i2c_reg_write() are identical. We can save space and simplify the
code by converting these functions into inlines and putting them in
i2c.h.
Acked-By: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
This warning is issued by modern ARM-EABI GCC on non-thumb targets.
Signed-off-by: Vladimir Panfilov <pvr@emcraft.com>
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
Signed-off-by: Adrian Filipi <adrian.filipi@eurotech.com>
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
This moves the MMC and SD Card command definitions from
include/asm/arch/mmc.h into include/mmc.h. These definitions are
given by the MMC and SD Card standards, not by any particular
architecture.
There's a lot more room for consolidation in the MMC drivers which
I'm hoping to get done eventually, but this patch is a start.
Compile-tested for all avr32 boards as well as lpc2292sodimm and
lubbock. This should cover all three mmc drivers in the tree.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
start.S:183:1: warning: "ICMR" redefined
In file included from start.S:33:
include/asm/arch/pxa-regs.h:935:1: warning: this is the location of the previous definition
start.S:187:1: warning: "RCSR" redefined
fix mmc_bread function prototype
Move duplicated exception handling code into lib_arm.
Signed-off-by: Andreas Engel <andreas.engel@ericsson.com>
MMC support for X_Scale PXA is broken and does not work.
Mainly, the mmc_init() function cannot recognize current SD/MMC cards.
There were already some patches around the world but none of them was
merged into the official u-boot tree.
This patch makes order fixing this issue. Resubmit after code cleanup.
Applied and tested on PXA 270 (TrizepsIV module).
board/tqm5200/tqm5200.c
Some USB keys need to be switched off before loading the kernel
otherwise they can remain in an undefined status which prevents them
to be correctly recognized by the kernel.
Signed-off-by: Rodolfo Giometti <giometti@linux.it>
Signed-off-by: Markus Klotzbuecher <mk@denx.de>
The pxa255_idp being an old unmaintained board showed several issues:
1. CONFIG_INIT_CRITICAL was still defined.
2. Neither CONFIG_MAC_PARTITION nor CONFIG_DOS_PARTITION was defined.
3. Symbol flash_addr was undeclared.
4. The boards lowlevel_init function was still called memsetup.
5. The TEXT_BASE was still 0xa3000000 rather than 0xa3080000.
6. Using -march=armv5 instead of -march=armv5te resulted in lots of
'target CPU does not support interworking' warnings on recent compilers.
7. The PXA's serial driver redefined FFUART, BTUART and STUART used as
indexes rather than the register definitions from the pxa-regs header
file. Renamed them to FFUART_INDEX, BTUART_INDEX and STUART_INDEX to
avoid any ambiguities.
8. There were several redefinition warnings concerning ICMR, OSMR3,
OSCR, OWER, OIER, RCSR and CCCR in the PXA's assembly start file.
9. The board configuration file was rather outdated.
10. The part header file defined the vendor, product and revision arrays
as unsigned chars instead of just chars in the block_dev_desc_t
structure.
This patch adds support for multiple serial ports to the PXA target.
FFUART, BTUART and STUART are supported.
buffer pointers
Block device read/write is anonymous data; there is no need to use a
typed pointer. void * is fine. Also add a hook for block_read functions
Each of the filesystem drivers duplicate the get_dev routine. This change
merges them into a single function in part.c
