path: root/cpu/pxa/serial.c
2009-06-12pxa: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
2007-10-23fix pxa255_idp boardMarcel Ziswiler
The pxa255_idp being an old unmaintained board showed several issues: 1. CONFIG_INIT_CRITICAL was still defined. 2. Neither CONFIG_MAC_PARTITION nor CONFIG_DOS_PARTITION was defined. 3. Symbol flash_addr was undeclared. 4. The boards lowlevel_init function was still called memsetup. 5. The TEXT_BASE was still 0xa3000000 rather than 0xa3080000. 6. Using -march=armv5 instead of -march=armv5te resulted in lots of 'target CPU does not support interworking' warnings on recent compilers. 7. The PXA's serial driver redefined FFUART, BTUART and STUART used as indexes rather than the register definitions from the pxa-regs header file. Renamed them to FFUART_INDEX, BTUART_INDEX and STUART_INDEX to avoid any ambiguities. 8. There were several redefinition warnings concerning ICMR, OSMR3, OSCR, OWER, OIER, RCSR and CCCR in the PXA's assembly start file. 9. The board configuration file was rather outdated. 10. The part header file defined the vendor, product and revision arrays as unsigned chars instead of just chars in the block_dev_desc_t structure. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2007-09-07PXA270: Add support for multiple serial ports.stefano babic
This patch adds support for multiple serial ports to the PXA target. FFUART, BTUART and STUART are supported. Signed-off-by: Stefano Babic <sbabic@denx.de>
2006-02-07This is the first commit for the u-boot zylonite port. The following has beMarkus Klotzbücher
done so far: * created zylonite board dir (based on lubbock) * extended some - but not all pxa sources and headers for Intel Monahans support (CONFIG_CPU_MONAHANS) * created Makefile zylonite target + MAKEALL entry * added some debug nonsense, remove later, grep for mk@tbd Status: compiles (eldk-4.0), and can be started with BDI, but runs forever and doesn't halt at breakpoints. Hmmm...
2003-09-18* Patches by Anders Larsen, 17 Sep 2003:wdenk
- fix spelling errors - set GD_FLG_DEVINIT flag only after device function pointers are valid - Allow CFG_ALT_MEMTEST on systems where address zero isn't writeable - enable 3.rd UART (ST-UART) on PXA(XScale) CPUs - trigger watchdog while waiting in serial driver
2003-05-23Patch by Kyle Harris, 20 May 2003:LABEL_2003_05_23_1450wdenk
In preparation for an ixp port, rename cpu/xscale and arch-xscale into cpu/pxa and arch-pxa.
