actually the timer init use the interrupt_init as init callback
which make the interrupt and timer implementation difficult to follow
so now rename it as int timer_init(void) and use interrupt_init for interrupt
btw also remane the corresponding file to the functionnality implemented
as ixp arch implement two timer - one based on interrupt - so all the timer
related code is moved to timer.c
introduce new macro CONFIG_PXA_MMC to activate it
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
CFG_USB_BOARD_INIT and CFG_USB_CPU_INIT for enabling board and cpu specific
initialization and cleanup hooks respectively.
* Patches by Kyle Harris, 13 Mar 2003:
- Add FAT partition support
- Add command support for FAT
- Add command support for MMC
- Add Intel PXA support for video
- Add Intel PXA support for MMC
- Enable MMC and FAT for lubbock board
- Other misc changes for lubbock board
In preparation for an ixp port, rename cpu/xscale and arch-xscale
into cpu/pxa and arch-pxa.
