path: root/cpu/ppc4xx
2009-04-28Replace __attribute references with __attribute__Peter Tyser
__attribute__ follows gcc's documented syntax and is generally more common than __attribute. This change is only asthetic and should not affect functionality. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-16ppc4xx: Add "booting from NAND" to 4xx NAND-booting targetsStefan Roese
This additional text in the bootup log helps to see if the board is configured for NAND-booting. Especially helpful for boards that can boot from NOR and NAND (e.g. most of the AMCC eval boards). Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-20ppc4xx: Don't write the MAC address into the internal SoC registersStefan Roese
Remove this code. It's not needed. The 4xx EMAC driver stores the MAC addresses into the SoC registers instead. Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-20cpu/: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. The cpus that get converted here: at91rm9200 mpc512x mpc5xxx mpc8260 mpc8xx ppc4xx Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: John Rigby <jrigby@freescale.com> CC: Stefan Roese <sr@denx.de>
2009-03-20ppc4xx: Fix bug in PCI outbound map configuration for canyonlandsAnatolij Gustschin
PCI outbound address map configuration doesn't match the PCI memory address range covered by appropriate TLB entry configuration for canyonlands causing machine check exceptions while accessing PCI memory regions. This patch provides a fix for this issue. Kazuaki Ichinohe observed and reported this issue while testing display output with PCI ATI video card on canyonlands. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-02-18ppc4xx: PCIe: Change 16GB inbound memory to 4GBStefan Roese
This patch fixes a problem recently seen on some 4xx platforms. For example on Kilauea PCIe slot #0. Signed-off-by: Stefan Roese <sr@denx.de>
2009-02-12ppc4xx: Fix initialization of the SDRAM_CODT registerCarolyn Smith
This fixes the initialization of the SDRAM_CODT register in the ppc4xx DDR2 initialization code. It also removes use of the SDRAM_CODT_FEEDBACK_RCV_SINGLE_END and SDRAM_CODT_FEEDBACK_DRV_SINGLE_END #define's since they are reserved bits. Signed-off-by: Carolyn Smith <carolyn.smith@tektronix.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-02-12ppc4xx: Autocalibration can set RDCC to over aggressive value.Adam Graham
The criteria of the AMCC SDRAM Controller DDR autocalibration U-Boot code is to pick the largest passing write/read/compare window that also has the smallest SDRAM_RDCC.[RDSS] Read Sample Cycle Select value. On some Kilauea boards the DDR autocalibration algorithm can find a large passing write/read/compare window with a small SDRAM_RDCC.[RDSS] aggressive value of Read Sample Cycle Select value "T1 Sample". This SDRAM_RDCC.[RDSS] Read Sample Cycle Select value of "T1 Sample" proves to be to aggressive when later on U-Boot relocates into DDR memory and executes. The memory traces on the Kilauea board are short so on some Kilauea boards the SDRAM_RDCC.[RDSS] Read Sample Cycle Select value of "T1 Sample" shows up as a potentially valid value for the DDR autocalibratiion algorithm. The fix is to define a weak default function which provides the minimum SDRAM_RDCC.[RDSS] Read Sample Cycle Select value to accept for DDR autocalibration. The default will be the "T2 Sample" value. A board developer who has a well defined board and chooses to be more aggressive can always provide their own board specific string function with the more aggressive "T1 Sample" value or stick with the default minimum SDRAM_RDCC.[RDSS] value of "T2". Also put in a autocalibration loop fix for case where current write/read/compare passing window size is the same as a prior window size, then in this case choose the write/read/compare result that has the associated smallest RDCC T-Sample value. Signed-off-by: Adam Graham <agraham@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-02-10ppc: Move CONFIG_MAX_MEM_MAPPED to common config.hKumar Gala
Moved CONFIG_MAX_MEM_MAPPED to the asm/config.h so its kept consistent between the two current users (lib_ppc/board.c, 44x SPD DDR2). Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefan Roese <sr@denx.de>
2009-02-07pci: Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY for clarityKumar Gala
The PCI_REGION_MEMORY and PCI_REGION_MEM are a bit to similar and can be confusing when reading the code. Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY to clarify its used for system memory mapping purposes. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-02-06ppc4xx: Make PCIE support selectableDirk Eibach
On some platforms PCIE support is not required, but would be included because the cpu supports it. To reduce fooprint it is now configurable via CONFIG_PCI_DISABLE_PCIE. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-02-06ppc4xx: Only fixup opb attached UARTsMatthias Fuchs
This patch updates the fdt UART clock fixup code to only touch CPU internal UARTs on 4xx systems. Only these UARTs are definitely clocked by gd->uart_clk. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2009-01-26ppc4xx: Improve DDR autodetectDirk Eibach
Added support for a second memory bank to DDR autodetection for 440 platforms. Made hardcoded values configurable. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2008-12-16Coding style cleanup, update CHANGELOG.Wolfgang Denk
2008-12-15i2c: merge all i2c_reg_read() and i2c_reg_write() into inline functionsTimur Tabi
All implementations of the functions i2c_reg_read() and i2c_reg_write() are identical. We can save space and simplify the code by converting these functions into inlines and putting them in i2c.h. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-By: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-12-09Section name should be ".data", not "data"Trent Piepho
Signed-off-by: Trent Piepho <tpiepho@freescale.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-06Update U-Boot's build timestamp on every compilePeter Tyser
Use the GNU 'date' command to auto-generate a new U-Boot timestamp on every compile. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-11-21ppc4xx: Changed 460EX/GT OCM TLB and internal SRAM initializationDave Mitchell
Expanded OCM TLB to allow access to 64K OCM as well as 256K of internal SRAM. Adjusted internal SRAM initialization to match updated user manual recommendation. OCM & ISRAM are now mapped as follows: physical virtual size ISRAM 0x4_0000_0000 0xE300_0000 256k OCM 0x4_0004_0000 0xE304_0000 64k A single TLB was used for this mapping. Signed-off-by: Dave Mitchell <dmitch71@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-21ppc4xx: Added ppc4xx-isram.h for internal SRAM and L2 cache DCRsDave Mitchell
Added include/asm-ppc/ppc4xx-isram.h and moved internal SRAM and L2 cache DCRs from ppc440.h to this new header. Also converted these DCR defines from lowercase to uppercase and modified referencing modules to use them. Signed-off-by: Dave Mitchell <dmitch71@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-20ppc4xx: Clear all potentially pending exceptions in MCSRStefan Roese
This is needed on Canyonlands which still has an exception pending while running relocate_code(). This leads to a failure after trap_init() is moved to the top of board_init_r(). Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-09Moved initialization of PPC4xx EMAC to cpu_eth_init()Ben Warren
Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-11-09Moved PPC4xx EMAC driver to drivers/netBen Warren
Also changed path in all linker scripts that reference this driver Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-11-09Changed PPC4xx EMAC driver to require CONFIG_PPC4xx_EMACBen Warren
All in-tree IBM/AMCC PPC4xx boards using the EMAC get this new CONFIG Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-10-24ppc4xx: Generic architecture for xilinx ppc405(v3)Ricardo Ribalda Delgado
As "ppc44x: Unification of virtex5 pp440 boards" did for the xilinx ppc440 boards, this patch presents a common architecture for all the xilinx ppc405 boards. Any custom xilinx ppc405 board can be added very easily with no code duplicity. This patch also adds a simple generic board, that can be used on almost any design with xilinx ppc405 replacing the file ppc405-generic/xparameters.h This patch is prepared to work with the latest version of EDK (10.1) Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-21Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2008-10-21ppc4xx: Correctly setup ranges property in ebc nodeStefan Roese
Previously only the NOR flash mapping was written into the ranges property of the ebc node. This patch now writes all enabled chip select areas into the ranges property. Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-21ppc4xx: Add routine to retrieve CPU numberAdam Graham
Provide a weak defined routine to retrieve the CPU number for reference boards that have multiple CPU's. Default behavior is the existing single CPU print output. Reference boards with multiple CPU's need to provide a board specific routine. See board/amcc/arches/arches.c for an example. Signed-off-by: Adam Graham <agraham@amcc.com> Signed-off-by: Victor Gallardo <vgallardo@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-21ppc4xx: Add static support for 44x IBM SDRAM ControllerAdam Graham
This patch add the capability to configure a PPC440 based IBM SDRAM Controller with static, compiled-in, values. PPC440 memory subsystem includes a Memory Queue core. Signed-off-by: Adam Graham <agraham@amcc.com> Signed-off-by: Victor Gallardo <vgallardo@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-21Cleanup: fix "MHz" spellingWolfgang Denk
2008-10-21Merge git://git.denx.de/u-boot into x1Markus Klotzbuecher
Conflicts: drivers/usb/usb_ohci.c
2008-10-18Merge 'next' branchWolfgang Denk
Conflicts: board/freescale/mpc8536ds/mpc8536ds.c include/configs/mgcoge.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-17ppc4xx: PPC44x MQ initializationYuri Tikhonov
Set the MQ Read Passing & MCIF Cycle limits to the recommended by AMCC values. This fixes the occasional 440SPe hard locking issues when the 440SPe's dedicated DMA engines are used (e.g. by the h/w accelerated RAID driver). Previously the appropriate initialization had been made in Linux, by the ppc440spe ADMA driver, which is wrong because modifying the MQ configuration registers after normal operation has begun is not supported and could have unpredictable results. Comment from Stefan: This patch doesn't change the resulting value of the MQ registers. It explicitly sets/clears all bits to the desired state which better documents the resulting register value instead of relying on pre-set default values. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-14The PIPE_INTERRUPT flag is used wrongRemy Bohmer
At a lot of places in the code the PIPE_INTERRUPT flags and friends are used wrong. The wrong bits are compared to this flag resulting in wrong conditions. Also there are macros that should be used for PIPE_* flags. This patch tries to fix them all, however, I was not able to test the changes, because I do not have any of these boards. Review required! Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2008-10-08ppc4xx: Reset and relock memory DLL after SDRAM_CLKTR changeAdam Graham
After changing SDRAM_CLKTR phase value rerun the memory preload initialization sequence (INITPLR) to reset and relock the memory DLL. Changing the SDRAM_CLKTR memory clock phase coarse timing adjustment effects the phase relationship of the internal, to the PPC chip, and external, to the PPC chip, versions of MEMCLK_OUT. Signed-off-by: Adam Graham <agraham@amcc.com> Signed-off-by: Victor Gallardo <vgallardo@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-22Revert "ppc4xx: Fix DDR2 auto calibration on Kilauea 600MHz (200MHz PLB)"Stefan Roese
This reverts commit 3eec160a3a405b29ce9c06920f6427b9047dd8a8. Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-16ppc4xx: Fix DDR2 auto calibration on Kilauea 600MHz (200MHz PLB)Victor Gallardo
Signed-off-by: Victor Gallardo <vgallardo@amcc.com> Signed-off-by: Adam Graham <agraham@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-12ppc4xx: Fix SDRAM inititialization of multiple 405 based board portsStefan Roese
This patch fixes a problem introdiced with patch bbeff30c [ppc4xx: Remove superfluous dram_init() call or replace it by initdram()]. The boards affected are: - PCI405 - PPChameleonEVB - quad100hd - taihu - zeus Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-08ppc4xx: Remove CONFIG_CS8952_PHY defineStefan Roese
Since this define is only used on one board that was never really in production, removing this compile time option doesn't hurt and makes the code more readable. Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-08ppc4xx: Fix compilation warning for PIP405Stefan Roese
This patch fixes a compilation warning for the PIP405 board. It moves the #ifndef CONFIG_CS8952_PHY define a little so that the warning doesn't occur anymore. I am a little unsure if this #ifdef is at the correct place now or if it could be removed completely. This needs to get tested on the PIP405 board. Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-08ppc4xx: Fix compilation warning for canyonlands & glacierStefan Roese
2008-09-05ppc4xx: Add support for GPCS, SGMII and M88E1112 PHYVictor Gallardo
This patch adds GPCS, SGMII and M88E1112 PHY support for the AMCC PPC460GT/EX processors. Signed-off-by: Victor Gallardo <vgallardo@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-05ppc4xx: Update Kilauea to use PPC4xx DDR autocalibration routinesAdam Graham
2008-09-05ppc4xx: IBM Memory Controller DDR autocalibration routinesAdam Graham
Alternate SDRAM DDR autocalibration routine that can be generically used for any PPC4xx chips that have the IBM SDRAM Controller core allowing for support of more DIMM/memory chip vendors and gets the DDR autocalibration values which give the best read latency performance (SDRAM0_RDCC.[RDSS]). Two alternate SDRAM DDR autocalibration algoritm are provided in this patch, "Method_A" and "Method_B". DDR autocalibration Method_A scans the full range of possible PPC4xx SDRAM Controller DDR autocalibration values and takes a lot longer to run than Method_B. Method_B executes in the same amount of time as the currently existing DDR autocalibration routine, i.e. 1 second or so. Normally Method_B is used and it is set as the default method. The current U-Boot PPC4xx DDR autocalibration code calibrates the IBM SDRAM Controller registers.[bit-field]: 1) SDRAM0_RQDC.[RQFD] 2) SDRAM0_RFDC.[RFFD] This alternate PPC4xx DDR autocalibration code calibrates the following IBM SDRAM Controller registers.[bit-field]: 1) SDRAM0_WRDTR.[WDTR] 2) SDRAM0_CLKTR.[CKTR] 3) SDRAM0_RQDC.[RQFD] 4) SDRAM0_RFDC.[RFFD] and will also use the calibrated settings of the above four registers that produce the best "Read Sample Cycle Select" value in the SDRAM0_RDCC.[RDSS] register.[bit-field]. Signed-off-by: Adam Graham <agraham@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-08-30ppc4xx/NAND: Add select_chip function to 4xx NDFC driverStefan Roese
This function is needed for the new NAND infrastructure. We only need a dummy implementation though for the NDFC. Signed-off-by: Stefan Roese <sr@denx.de>
2008-08-29ppc4xx: NAND configurationWolfgang Ocker
Made NAND bank configuration setting a config variable. Signed-off-by: Wolfgang Ocker <weo@reccoware.de> Signed-off-by: Stefan Roese <sr@denx.de>
2008-08-29ppc4xx: fix UIC external_interrupt hang on UIC0Victor Gallardo
This patch fixes a UIC external_interrupt hang if critical or non-critical interrupt is set at the same time as a normal interrupt is set on UIC0. Signed-off-by: Victor Gallardo <vgallardo@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-08-29ppc4xx: Optimizations/Cleanups for IBM DDR2 Memory ControllerProdyut Hazarika
Removed Magic numbers from Initialization preload registers Tested with Kilauea, Glacier, Canyonlands and Katmai boards About 5-7% improvement seen for LMBench memtests Signed-off-by: Prodyut Hazarika <phazarika@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-08-22ppc4xx: AMCC PPC460GT/EX PCI-E de-emphasis adjustment fixTirumala R Marri
During recent PCI-E tests it has been found that current driverl level and de-emphasis values are not set correctly. After sweeping throgh all de-ephasis values, it was found that 0x130 is a right value. Where 0x13 is driver level and 0 is de-emphasis. Signed-off-by: Tirumala R Marri <tmarri@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
