Allow bzip2 compression for small memory footprint boards
* Patch by Brad Kemp, 21 Jan 2004:
Add support for CFI flash driver for both the Intel and the AMD
command sets.
* Patch by Travis Sawyer, 20 Jan 2004:
Fix pci bridge auto enumeration of sibling p2p bridges.
* Patch by Tolunay Orkun, 12 Jan 2004:
Add some delays as needed for Intel LXT971A PHY support
* Patches by Stephan Linz, 09 Jan 2004:
- avoid warning: unused variable `piop' in board/altera/common/sevenseg.c
- make DK1C20 board configuration related to ASMI conform to
documentation
Add support for IBM PPC440GX. Multiple EMAC Ethernet devices,
select MDI port based on enabled EMAC device.
Add support for XES Inc <http://www.xes-inc.com> XPedite1000 440GX
base PrPMC board.
* Minor code cleanup (coding style)
* Patch by Reinhard Meyer, 30 Dec 2003:
- cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE,
- added CONFIG_PHY_ADDR to include/configs/IceCube.h,
- turned debug print of PHY registers into a function (called in two places)
- added support for EMK MPC5200 based modules
* Fix MPC8xx PLPRCR_MFD_SHIFT typo
* Add support for TQM866M modules
* Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash)
* Fix a few compiler warnings
add support for mvblue (mvBlueLYNX and mvBlueBOX) boards
* Patch by Pavel Bartusek, 21 Nov 2003:
set ZMII bridge speed on 440
* Patch by Anders Larsen, 17 Nov 2003:
Fix mismatched #ifdef / #endif in include/asm-arm/arch-pxa/hardware.h
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c
* Patch by Anders Larsen, 17 Sep 2003:
Bring ARM memory layout in sync with the documentation:
stack and malloc-heap are now located _below_ the U-Boot code
recent tools
* Add checksum verification to 'imls' command
* Add bd_info fields needed for 4xx Linux I2C driver
* Patch by Martin Krause, 4 Nov. 2003:
Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap)
* Print used network interface when CONFIG_NET_MULTI is set
(tested with USB memory sticks only)
* Avoid flicker on TRAB's VFD
* Add support for P3G4 board
* Fix problem with MGT5100 FEC driver: add "early" MAC address
initialization
applications: instead of using (PPC-specific) system calls we now
use a jump table; please see doc/README.standalone for details
* Patch by Dave Westwood, 24 Jul 2003:
added support for Unity OS (a proprietary OS)
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
Modifications for Atmel AT91RM9200DK ARM920T based development kit
- Add Atmel DataFlash support for reading and writing.
- Add possibility to boot a Linux from DataFlash with BOOTM command.
- Add Flash detection on Atmel AT91RM9200DK
(between Atmel AT49BV1614 and AT49BV1614A flashes)
- Replace old Ethernet PHY layer functions
- Change link address
* Patch by Frank Smith, 9 Jun 2003:
use CRIT_EXCEPTION for machine check on 4xx
* Patch by Detlev Zundel, 13 Jun 2003:
added implementation of the "carinfo" command in cmd_immap.c
make ppc405 ethernet driver compatible with CONFIG_NET_MULTI option
(tschaefer@giga-stream.de). Now inital stack in data cache can be used even if the chip select is in use.
add support for the MIP405T board
- Added support for custom keyboards, initialized by defining a
board-specific drv_keyboard_init as well as defining CONFIG_KEYBOARD .
- Added support for the RBC823 board.
- cpu/mpc8xx/lcd.c now automatically calculates the
Horizontal Pixel Count field.
* Fix alignment problem in BOOTP (dhcp_leasetime option)
[pointed out by Nicolas Lacressonnière, 2 Jun 2003]
* Patch by Mark Rakes, 14 May 2003:
add support for Intel e1000 gig cards.
* Patch by Nye Liu, 3 Jun 2003:
fix critical typo in MAMR definition (include/mpc8xx.h)
* Fix requirement to align U-Boot image on 16 kB boundaries on PPC.
* Patch by Klaus Heydeck, 2 Jun 2003
Minor changes for KUP4K configuration
instead CFG_MONITOR_LEN is now only used to determine _at_compile_
_time_ (!) if the environment is embedded within the U-Boot image,
or in a separate flash sector.
* Cleanup CFG_DER #defines in config files (wd maintained only)
- CONFIG_UART1_CONSOLE added (see README).
Fix problem with only partially cleared .bss segment
* Patch by Rune Torgersen, 12 May 2003:
get PCI to work on a MPC8266ADS board; incorporate change to
cpu/mpc8260/pci.c to enable overrides of PCI memory parameters
PPC405GP designs.
- minimal setup for CardBus bridges
- add EEPROM read/write support in the CS8900 driver
- add support for the builtin I2C controller in the Samsung s3c24x0 chips
- add support for MPL's VCMA9 (Samsung s3c2410 based) board
* Patch by Steven Scholz, 04 Feb 2003:
add support for RTC DS1307
* Patch by Reinhard Meyer, 5 Feb 2003:
fix PLPRCR/SCCR init sequence on 8xx to allow for
changes of EBDF by software
* Patch by Vladimir Gurevich, 07 Feb 2003:
"API-compatibility patch" for 4xx I2C driver
- fix bug in BOOTP code (must use NetCopyIP)
- update of CSB226 port
- clear BSS segment on XScale
- added support for i2c_init_board() function
- update to the Innokom plattform
* Extend support for redundand environments for configurations where
environment size < sector size
Add support for Motorola MPC8266ADS board
* Patch by Kyle Harris, 19 Feb 2003:
patches for the Intel lubbock board:
memsetup.S - general cleanup (based on Robert's csb226 code)
flash.c - overhaul, actually works now
lubbock.c - fix init funcs to return proper value
* Patch by Kenneth Johansson, 26 Feb 2003:
- Fixed off by one in RFTA calculation.
- No need to abort when LDF is lower than we can program it's only
minimum timing so clamp it to what we can do.
- Takes function pointer to function for reading the spd_nvram. Usefull
for faking data or hardcode a module without the nvram.
- fix other user for above change
- fix some comments.
* Patches by Brian Waite, 26 Feb 2003:
- fix port for evb64260 board
- fix PCI for evb64260 board
- fix PCI scan
* Patch by Reinhard Meyer, 1 Mar 2003:
Add support for EMK TOP860 Module
* Patch by Yuli Barcohen, 02 Mar 2003:
Add SPD EEPROM support for MPC8260ADS board
Fix misc problems with AmigaOne support
* Patch by Chris Hallinan, 3 Dec 2002:
minor cleanup to the MPC8245 EPIC driver
* Patch by Pierre Aubert , 28 Nov 2002
Add support for external (SIU) interrupts on MPC8xx
Fix nested syscalls bug in standalone applications
* Patch by David Müller, 27 Nov 2002:
fix output of "pciinfo" command for CardBus bridge devices.
* Fix bug in TQM8260 board detection - boards got stuck when board ID
was not readable
