path: root/cpu/ppc4xx/usb_ohci.c
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-10-21Merge git://git.denx.de/u-boot into x1Markus Klotzbuecher
Conflicts: drivers/usb/usb_ohci.c
2008-10-14The PIPE_INTERRUPT flag is used wrongRemy Bohmer
At a lot of places in the code the PIPE_INTERRUPT flags and friends are used wrong. The wrong bits are compared to this flag resulting in wrong conditions. Also there are macros that should be used for PIPE_* flags. This patch tries to fix them all, however, I was not able to test the changes, because I do not have any of these boards. Review required! Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2008-04-25USB: fix more GCC 4.2.x aliasing warningsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Markus Klotzbuecher <mk@denx.de>
2007-03-21[PATCH] Add AMCC PPC405EZ supportStefan Roese
This patch adds support for the new AMCC 405EZ PPC. It is in preparation for the AMCC Acadia board support. Please note that this Acadia/405EZ support is still in a beta stage. Still lot's of cleanup needed but we need a preliminary release now. Signed-off-by: Stefan Roese <sr@denx.de>
2006-09-07Add support for AMCC Sequoia PPC440EPx eval boardStefan Roese
- Add support for PPC440EPx & PPC440GRx - Add support for PPC440EP(x)/GR(x) NAND controller in cpu/ppc4xx directory - Add NAND boot functionality for Sequoia board, please see doc/README.nand-boot-ppc440 for details - This Sequoia NAND image doesn't support environment in NAND for now. This will be added in a short while. Patch by Stefan Roese, 07 Sep 2006
2005-08-08Changed CONFIG_440_xx to CONFIG_440xx for a consistent design (405 and linux)Stefan Roese
Patch by Stefan Roese, 08 Aug 2005
2005-08-02Fix low-level OHCI transfers for PPC440EP (same as ARM920t and MPC5xxx).Stefan Roese
Patch by Stefan Roese, 2 Aug 2005
2005-08-01Add support for AMCC PPC440EP/GR eval boards Yosemite and Yellowstone.Stefan Roese
Patch by Steven Blakeslee, 27 Jul 2005
