r14 is not supposed to be clobbered by functions. Switch
to r12 and call GET_GOT when needed. This will allow u-boot
to loose the -ffixed-r14 gcc option.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
Using the GOT in IRQ handlers requires r14 to be -ffixed-r14.
Avoid this by relocatate transfer_to_handler too.
This will allow to free up r14 later on.
NULL is an absolute value and should not be relocated.
After this correction code like:
void weak_fun(void) __attribute__((weak));
printf("weak_fun:%p\n", weak_fun);
will still print null after relocation.
This patch cleans up multiple issues of the 4xx register (mostly
DCR, SDR, CPR, etc) definitions:
- Change lower case defines to upper case (plb4_acr -> PLB4_ACR)
- Change the defines to better match the names from the
user's manuals (e.g. cprpllc -> CPR0_PLLC)
- Removal of some unused defines
Please test this patch intensive on your PPC4xx platform. Even though
I tried not to break anything and tested successfully on multiple
4xx AMCC platforms, testing on custom platforms is recommended.
It was brought to our attention that U-Boot contains code derived from the
IBM OpenBIOS source code originally provided with some of the older PowerPC
4xx development boards. As a result, the original license of this code has
been carried in the various files for a number of years in the U-Boot project.
IBM is dual-licensing the IBM code contributions already present in U-Boot
under either the terms of the GNU General Public License version 2, or the
original code license already present.
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Patch d873133f [ppc4xx: Add Sequoia RAM-booting target] broke "normal"
booting on some 44x platforms. This breakage is only noticed in some
cases while powercycling. As it seems, the code in question in start.S
didn't invalidate TLB #0. This makes sense since this TLB is used for
the bootrom mapping. With the patch mentioned above even TLB #0 got
invalidated resulting in an error later on.
This patch now fixes this issue by only invalidating TLB #0 in the RAM-
booting case.
Tested succesfully on Sequoia and Canyonlands.
Cc: Dirk Eibach <Eibach@gdsys.de>
This patch makes pll_write on PPC405EP boards
global and callable from C code.
pll_write can be used to dynamically modify the PLB:PCI divider
as it is required for 33/66 MHz pci adapters based on the 405EP.
board_early_init_f() is a good place to do that (check M66EN signal
and call pll_write() when it is required).
This patch adds another build target for the AMCC Sequoia PPC440EPx
eval board. This RAM-booting version is targeted for boards without
NOR FLASH (NAND booting) which need a possibility to initially
program their NAND FLASH. Using a JTAG debugger (e.g. BDI2000/3000)
configured to setup the SDRAM, this debugger can load this RAM-
booting image to the target address in SDRAM (in this case 0x1000000)
and start it there. Then U-Boot's standard NAND commands can be
used to program the NAND FLASH (e.g. "nand write ...").
Here the commands to load and start this image from the BDI2000:
440EPX>reset halt
440EPX>load 0x1000000 /tftpboot/sequoia/u-boot.bin
440EPX>go 0x1000000
Please note that this image automatically scans for an already
initialized SDRAM TLB (detected by EPN=0). This TLB will not be
cleared. This TLB doesn't need to be TLB #0, this RAM-booting
version will detect it and preserve it. So booting via BDI2000
will work and booting with a complete different TLB init via
U-Boot works as well.
Use the GNU 'date' command to auto-generate a new U-Boot
timestamp on every compile.
Expanded OCM TLB to allow access to 64K OCM as well as 256K of
internal SRAM.
Adjusted internal SRAM initialization to match updated user
manual recommendation.
OCM & ISRAM are now mapped as follows:
physical virtual size
ISRAM 0x4_0000_0000 0xE300_0000 256k
OCM 0x4_0004_0000 0xE304_0000 64k
A single TLB was used for this mapping.
Signed-off-by: Dave Mitchell <dmitch71@gmail.com>
Added include/asm-ppc/ppc4xx-isram.h and moved internal SRAM and
L2 cache DCRs from ppc440.h to this new header.
Also converted these DCR defines from lowercase to uppercase and
modified referencing modules to use them.
This is needed on Canyonlands which still has an exception pending
while running relocate_code(). This leads to a failure after trap_init()
is moved to the top of board_init_r().
As "ppc44x: Unification of virtex5 pp440 boards" did for the xilinx
ppc440 boards, this patch presents a common architecture for all the
xilinx ppc405 boards.
Any custom xilinx ppc405 board can be added very easily with no code
duplicity.
This patch also adds a simple generic board, that can be used on almost
any design with xilinx ppc405 replacing the file ppc405-generic/xparameters.h
This patch is prepared to work with the latest version of EDK (10.1)
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
Signed-off-by: Feng Kan <fkan@amcc.com>
Historically the 405 U-Boot port had a dram_init() call in early init
stage. This function was still called from start.S and most of the time
coded in assembler. This is not needed anymore (since a long time) and
boards should implement the common initdram() function in C instead.
This patch now removed the dram_init() call from start.S and removes the
empty implementations that are scattered through most of the 405 board
ports. Some older board ports really implement this dram_init() though.
These are:
csb272
csb472
ERIC
EXBITGEN
W7OLMC
W7OLMG
I changed those boards to call this assembler dram_init() function now
from their board specific initdram() instead. This *should* work, but please
test again on those platforms. And it is perhaps a good idea that those
boards use some common 405 SDRAM initialization code from cpu/ppc4xx at
some time. So further patches welcome here.
This patch consolidates the 405 and 440 parts of the NAND booting code
selected via CONFIG_NAND_SPL. Now common code is used to initialize the
SDRAM by calling initdram() and to "copy/relocate" to SDRAM/OCM/etc.
Only *after* running from this location, nand_boot() is called.
Please note that the initsdram() call is now moved from nand_boot.c
to start.S. I experienced problems with some boards like Kilauea
(405EX), which don't have internal SRAM (OCM) and relocation needs to
be done to SDRAM before the NAND controller can get accessed. When
initdram() is called later on in nand_boot(), this can lead to problems
with variables in the bss sections like nand_ecc_pos[].
Acked-by: Scott Wood <scottwood@freescale.com>
This patch (Part 1 of 2):
* Rolls up a suite of changes to enable correct primordial stack and
global data handling when the data cache is used for such a purpose
for PPC40x-variants (i.e. CFG_INIT_DCACHE_CS).
* Related to the first, unifies DDR2 SDRAM and ECC initialization by
eliminating redundant ECC initialization implementations and moving
redundant SDRAM initialization out of board code into shared 4xx
code.
* Enables MCSR visibility on the 405EX(r).
* Enables the use of the data cache for initial RAM on
both AMCC's Kilauea and Makalu and removes a redundant
CFG_POST_MEMORY flag from each board's CONFIG_POST value.
- Removed, per Stefan Roese's request, defunct memory.c file for
Makalu and rolled sdram_init from it into makalu.c.
With respect to the 4xx DDR initialization and ECC unification, there
is certainly more work that can and should be done (file renaming,
etc.). However, that can be handled at a later date on a second or
third pass. As it stands, this patch moves things forward in an
incremental yet positive way for those platforms that utilize this
code and the features associated with it.
Signed-off-by: Grant Erickson <gerickson@nuovations.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Since the current dflush() implementation is know to have some problems
(as seem on lwmon5 ECC init) this patch removes it completely and replaces
it by using clean_dcache_range().
Tested on Katmai with ECC DIMM.
460EX doesn't support a fixed bootstrap option to boot from 512 byte page
NAND devices. The only bootstrap option for NAND booting is option F for
2k page devices. So to boot from a 512 bype page device, the I2C bootstrap
EEPROM needs to be programmed accordingly.
This patch adds basic NAND booting support for the AMCC Canyonlands aval
board and also adds support to the "bootstrap" command, to enable NAND
booting I2C setting.
Tested with 512 byte page NAND device (32MByte) on Canyonlands.
This patch adds basic support for the AMCC 460EX/460GT PPC's.
Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
Signed-off-by: Larry Johnson <lrj@acm.org>
This patch adds support for locking the init-ram/stack in d-cache,
so that other regions may use d-cache as well
Note, that this current implementation locks exactly 4k of d-cache,
so please make sure that you don't define a bigger init-ram area. Take
a look at the lwmon5 440EPx implementation as a reference.
ppc4xx clear_bss() fails if BSS segment size is not
divisible by 4 without remainder. This patch provides
fix for this problem.
Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
New cache handling functions added and all existing functions
moved from start.S into seperate cache.S.
Signed-off-by: John Otken <john@softadvances.com>
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
- adapt to the more generic EXCEPTION_PROLOG and CRIT_EXCEPTION macros
- minor 4xx cleanup
The latest changes showed a problem with the location of the NAND-SPL
image in the OCM and the init-data area (incl. cache). This patch
fixes this problem.
- Introduced dedicated switches for building 440 and 405 images required
for 440-specific machine instructions like 'rfmci' etc.
- Exception vectors moved to the proper location (_start moved away from
the critical exception handler space, which it occupied)
- CriticalInput now serviced (with default handler)
- MachineCheck properly serviced (added a dedicated handler and return
subroutine)
- Overall cleanup of exceptions declared with STD_EXCEPTION macro (unused,
unhandled and those not relevant for 4xx were eliminated)
- Eliminated Linux leftovers, removed dead code
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
This patch adds NAND booting support for the AMCC Acadia eval board.
Please make sure to configure jumper J7 to position 2-3 when booting
from NOR, and to position 1-2 when booting for NAND.
I also added a board command to configure the I2C bootstrap EEPROM
values. Right now only 267MHz is support for booting either via NOR
or NAND FLASH. Here the usage:
=> bootstrap 267 nor ;to configure the board for 267MHz NOR booting
=> bootstrap 267 nand ;to configure the board for 267MHz NNAND booting
This patch adds NAND booting support for the AMCC Bamboo eval board.
Since the NAND-SPL boot image is limited to 4kbytes, this version
only supports the onboard 64MBytes of DDR. The DIMM modules can't be
supported, since the setup code for I2C DIMM autodetection and
configuration is too big for this NAND bootloader.
As pointed out by Bruce Adler <bruce.adler@acm.org> this patch
fixes a small bug in the 405EZ OCM initialization. Thanks for
spotting.
This patch cleans up all the open issue of the preliminary
Acadia support.
