path: root/cpu/ppc4xx/start.S
2008-12-16Coding style cleanup, update CHANGELOG.Wolfgang Denk
2008-12-06Update U-Boot's build timestamp on every compilePeter Tyser
Use the GNU 'date' command to auto-generate a new U-Boot timestamp on every compile. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-11-21ppc4xx: Changed 460EX/GT OCM TLB and internal SRAM initializationDave Mitchell
Expanded OCM TLB to allow access to 64K OCM as well as 256K of internal SRAM. Adjusted internal SRAM initialization to match updated user manual recommendation. OCM & ISRAM are now mapped as follows: physical virtual size ISRAM 0x4_0000_0000 0xE300_0000 256k OCM 0x4_0004_0000 0xE304_0000 64k A single TLB was used for this mapping. Signed-off-by: Dave Mitchell <dmitch71@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-21ppc4xx: Added ppc4xx-isram.h for internal SRAM and L2 cache DCRsDave Mitchell
Added include/asm-ppc/ppc4xx-isram.h and moved internal SRAM and L2 cache DCRs from ppc440.h to this new header. Also converted these DCR defines from lowercase to uppercase and modified referencing modules to use them. Signed-off-by: Dave Mitchell <dmitch71@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-20ppc4xx: Clear all potentially pending exceptions in MCSRStefan Roese
This is needed on Canyonlands which still has an exception pending while running relocate_code(). This leads to a failure after trap_init() is moved to the top of board_init_r(). Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-24ppc4xx: Generic architecture for xilinx ppc405(v3)Ricardo Ribalda Delgado
As "ppc44x: Unification of virtex5 pp440 boards" did for the xilinx ppc440 boards, this patch presents a common architecture for all the xilinx ppc405 boards. Any custom xilinx ppc405 board can be added very easily with no code duplicity. This patch also adds a simple generic board, that can be used on almost any design with xilinx ppc405 replacing the file ppc405-generic/xparameters.h This patch is prepared to work with the latest version of EDK (10.1) Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11ppc4xx: Add initial 460SX defines for the cpu/ppc4xx directory.Feng Kan
Signed-off-by: Feng Kan <fkan@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Remove superfluous dram_init() call or replace it by initdram()Stefan Roese
Historically the 405 U-Boot port had a dram_init() call in early init stage. This function was still called from start.S and most of the time coded in assembler. This is not needed anymore (since a long time) and boards should implement the common initdram() function in C instead. This patch now removed the dram_init() call from start.S and removes the empty implementations that are scattered through most of the 405 board ports. Some older board ports really implement this dram_init() though. These are: csb272 csb472 ERIC EXBITGEN W7OLMC W7OLMG I changed those boards to call this assembler dram_init() function now from their board specific initdram() instead. This *should* work, but please test again on those platforms. And it is perhaps a good idea that those boards use some common 405 SDRAM initialization code from cpu/ppc4xx at some time. So further patches welcome here. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx/NAND_SPL: Consolidate 405 and 440 NAND booting code in start.SStefan Roese
This patch consolidates the 405 and 440 parts of the NAND booting code selected via CONFIG_NAND_SPL. Now common code is used to initialize the SDRAM by calling initdram() and to "copy/relocate" to SDRAM/OCM/etc. Only *after* running from this location, nand_boot() is called. Please note that the initsdram() call is now moved from nand_boot.c to start.S. I experienced problems with some boards like Kilauea (405EX), which don't have internal SRAM (OCM) and relocation needs to be done to SDRAM before the NAND controller can get accessed. When initdram() is called later on in nand_boot(), this can lead to problems with variables in the bss sections like nand_ecc_pos[]. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Scott Wood <scottwood@freescale.com>
2008-06-03ppc4xx: Enable Primordial Stack for 40x and Unify ECC HandlingGrant Erickson
This patch (Part 1 of 2): * Rolls up a suite of changes to enable correct primordial stack and global data handling when the data cache is used for such a purpose for PPC40x-variants (i.e. CFG_INIT_DCACHE_CS). * Related to the first, unifies DDR2 SDRAM and ECC initialization by eliminating redundant ECC initialization implementations and moving redundant SDRAM initialization out of board code into shared 4xx code. * Enables MCSR visibility on the 405EX(r). * Enables the use of the data cache for initial RAM on both AMCC's Kilauea and Makalu and removes a redundant CFG_POST_MEMORY flag from each board's CONFIG_POST value. - Removed, per Stefan Roese's request, defunct memory.c file for Makalu and rolled sdram_init from it into makalu.c. With respect to the 4xx DDR initialization and ECC unification, there is certainly more work that can and should be done (file renaming, etc.). However, that can be handled at a later date on a second or third pass. As it stands, this patch moves things forward in an incremental yet positive way for those platforms that utilize this code and the features associated with it. Signed-off-by: Grant Erickson <gerickson@nuovations.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-29ppc4xx: Complete remove bogus dflush()Stefan Roese
Since the current dflush() implementation is know to have some problems (as seem on lwmon5 ECC init) this patch removes it completely and replaces it by using clean_dcache_range(). Tested on Katmai with ECC DIMM. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-15ppc4xx: Add Canyonlands NAND booting supportStefan Roese
460EX doesn't support a fixed bootstrap option to boot from 512 byte page NAND devices. The only bootstrap option for NAND booting is option F for 2k page devices. So to boot from a 512 bype page device, the I2C bootstrap EEPROM needs to be programmed accordingly. This patch adds basic NAND booting support for the AMCC Canyonlands aval board and also adds support to the "bootstrap" command, to enable NAND booting I2C setting. Tested with 512 byte page NAND device (32MByte) on Canyonlands. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-15ppc4xx: Add basic support for AMCC 460EX/460GT (2/5)Stefan Roese
This patch adds basic support for the AMCC 460EX/460GT PPC's. Signed-off-by: Stefan Roese <sr@denx.de>
2008-02-15Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2008-02-14ppc: Refactor cache routines, so there is only one common set.Rafal Jaworowski
Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
2008-02-04ppc4xx: Fix problem with init-ram bigger than 4k on 440 platformsStefan Roese
2008-01-10ppc4xx: Fix dflush() to restore DVLIM registerLarry Johnson
Signed-off-by: Larry Johnson <lrj@acm.org>
2008-01-09ppc4xx: Add 44x cache locking to better support init-ram in d-cacheStefan Roese
This patch adds support for locking the init-ram/stack in d-cache, so that other regions may use d-cache as well Note, that this current implementation locks exactly 4k of d-cache, so please make sure that you don't define a bigger init-ram area. Take a look at the lwmon5 440EPx implementation as a reference. Signed-off-by: Stefan Roese <sr@denx.de>
2007-12-27Fix ppc4xx clear_bss() codeAnatolij Gustschin
ppc4xx clear_bss() fails if BSS segment size is not divisible by 4 without remainder. This patch provides fix for this problem. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2007-12-27PPC4xx: Minimal changes to add vxWorks supportNiklaus Giger
Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2007-10-31ppc4xx: Rework 4xx cache supportStefan Roese
New cache handling functions added and all existing functions moved from start.S into seperate cache.S. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Add PPC405EX supportStefan Roese
2007-08-14ppc4xx: Add initial Zeus (PPC405EP) board supportStefan Roese
2007-07-26ppc4xx: Add support for AMCC 405EP Taihu boardJohn Otken
Signed-off-by: John Otken <john@softadvances.com>
2007-07-10Coding style cleanup; update CHANGELOG.Wolfgang Denk
2007-07-05Merged POST framework with the current TOT.Sergei Poselenov
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
2007-06-22[ppc] Fix build breakage for all non-4xx PowerPC variants.Rafal Jaworowski
- adapt to the more generic EXCEPTION_PROLOG and CRIT_EXCEPTION macros - minor 4xx cleanup
2007-06-20Coding style cleanup. Refresh CHANGELOG.Wolfgang Denk
2007-06-19[ppc4xx] Fix problem with NAND booting on AMCC AcadiaStefan Roese
The latest changes showed a problem with the location of the NAND-SPL image in the OCM and the init-data area (incl. cache). This patch fixes this problem. Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-15ppc4xx: Clean up 440 exceptions handlingGrzegorz Bernacki
- Introduced dedicated switches for building 440 and 405 images required for 440-specific machine instructions like 'rfmci' etc. - Exception vectors moved to the proper location (_start moved away from the critical exception handler space, which it occupied) - CriticalInput now serviced (with default handler) - MachineCheck properly serviced (added a dedicated handler and return subroutine) - Overall cleanup of exceptions declared with STD_EXCEPTION macro (unused, unhandled and those not relevant for 4xx were eliminated) - Eliminated Linux leftovers, removed dead code Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Signed-off-by: Rafal Jaworowski <raj@semihalf.com> Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-06ppc4xx: Add NAND booting support for AMCC Acadia (405EZ) eval boardStefan Roese
This patch adds NAND booting support for the AMCC Acadia eval board. Please make sure to configure jumper J7 to position 2-3 when booting from NOR, and to position 1-2 when booting for NAND. I also added a board command to configure the I2C bootstrap EEPROM values. Right now only 267MHz is support for booting either via NOR or NAND FLASH. Here the usage: => bootstrap 267 nor ;to configure the board for 267MHz NOR booting => bootstrap 267 nand ;to configure the board for 267MHz NNAND booting Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-01Merge with /home/stefan/git/u-boot/bamboo-nandStefan Roese
2007-06-01ppc4xx: Add NAND booting support for AMCC Bamboo (440EP) eval boardStefan Roese
This patch adds NAND booting support for the AMCC Bamboo eval board. Since the NAND-SPL boot image is limited to 4kbytes, this version only supports the onboard 64MBytes of DDR. The DIMM modules can't be supported, since the setup code for I2C DIMM autodetection and configuration is too big for this NAND bootloader. Signed-off-by: Stefan Roese <sr@denx.de>
2007-05-24ppc4xx: Fix small 405EZ OCM initilization bug in start.SStefan Roese
As pointed out by Bruce Adler <bruce.adler@acm.org> this patch fixes a small bug in the 405EZ OCM initialization. Thanks for spotting. Signed-off-by: Stefan Roese <sr@denx.de>
2007-04-18Merge with /home/wd/git/u-boot/custodian/u-boot-74xx-7xxWolfgang Denk
2007-03-24Merge with /home/stefan/git/u-boot/acadiaStefan Roese
2007-03-24[PATCH] Clean up 40EZ/Acadia supportStefan Roese
This patch cleans up all the open issue of the preliminary Acadia support. Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-21Merge with /home/stefan/git/u-boot/acadiaStefan Roese
2007-03-21[PATCH] Add AMCC PPC405EZ supportStefan Roese
This patch adds support for the new AMCC 405EZ PPC. It is in preparation for the AMCC Acadia board support. Please note that this Acadia/405EZ support is still in a beta stage. Still lot's of cleanup needed but we need a preliminary release now. Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-08Merge with /home/git/u-bootWolfgang Denk
2007-03-08Merge with /home/wd/git/u-boot/custodian/u-boot-ppc4xxWolfgang Denk
2007-03-08[PATCH] Update AMCC Luan 440SP eval board supportStefan Roese
The AMCC Luan now uses the common 440SP(e) DDR SPD code for DDR inititializition. This includes DDR auto calibration and support for different DIMM modules, instead of the fixed setup used in the earlier version. This patch also enables the cache in FLASH for the startup phase of U-Boot (while running from FLASH). After relocating to SDRAM the cache is disabled again. This will speed up the boot process, especially the SDRAM setup, since there are some loops for memory testing (auto calibration). Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-06Restructure POST directory to support of other CPUs, boards, etc.Wolfgang Denk
2007-03-04Some code cleanup.Wolfgang Denk
2007-03-01Merge with /home/stefan/git/u-boot/denx-merge-srStefan Roese
2007-03-01[PATCH] Update AMCC Katmai 440SPe eval board supportStefan Roese
This patch updates the recently added Katmai board support. The biggest change is the support of ECC DIMM modules in the 440SP(e) SPD DDR2 driver. Please note, that still some problems are left with some memory configurations. See the driver for more details. Signed-off-by: Stefan Roese <sr@denx.de>
2007-02-27Minor code cleanup.Wolfgang Denk
2007-02-20[PATCH] Add support for the AMCC Katmai (440SPe) eval boardStefan Roese
