path: root/cpu/ppc4xx/fdt.c
2009-02-06ppc4xx: Only fixup opb attached UARTsMatthias Fuchs
This patch updates the fdt UART clock fixup code to only touch CPU internal UARTs on 4xx systems. Only these UARTs are definitely clocked by gd->uart_clk. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-21ppc4xx: Correctly setup ranges property in ebc nodeStefan Roese
Previously only the NOR flash mapping was written into the ranges property of the ebc node. This patch now writes all enabled chip select areas into the ranges property. Signed-off-by: Stefan Roese <sr@denx.de>
2008-08-21fdt: rework fdt_fixup_ethernet() to use env instead of bd_tKumar Gala
Move to using the environment variables 'ethaddr', 'eth1addr', etc.. instead of bd->bi_enetaddr, bi_enet1addr, etc. This makes the code a bit more flexible to the number of ethernet interfaces. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-11ppc4xx: Remove redundant ft_board_setup() functions from some 4xx boardsStefan Roese
This patch removes some ft_board_setup() functions from some 4xx boards. This can be done since we now have a default weak implementation for this in cpu/ppc4xx/fdt.c. Only board in need for a different/custom implementation like canyonlands need their own version. Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-08ppc4xx: Add weak default ft_board_setup() routineStefan Roese
This patch adds a default ft_board_setup() routine to the 4xx fdt code. This routine is defined as weak and can be overwritten by a board specific one if needed. Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-29ppc4xx: Fixup ebc clock in FDT for 405GP/EPMarkus Brunner
On ppc405EP and ppc405GP (at least) the ebc is directly attached to the plb and not to the opb. This patch will try to fixup /plb/ebc if /plb/opb/ebc doesn't exist. Signed-off-by: Markus Brunner <super.firetwister@gmail.com>
2008-04-25ppc4xx: Pass PCIe root-complex/endpoint configuration to Linux via the fdtStefan Roese
The PCIe root-complex/endpoint setup as configured via the "pcie_mode" environment variable will now get passed to the Linux kernel by setting the device_type property of the PCIe device tree node. For normal root- complex configuration it will keep its defaults value of "pci" and for endpoint configuration it will get changed to "pci-endpoint". Signed-off-by: Stefan Roese <sr@denx.de>
2007-12-27ppc4xx: fdt: Cleanup setup of cpu node setupStefan Roese
Now the cpu node setup ("timebase-frequency" and "clock-frequency") is without using the absolute path to the cpu node. This makes it possible to use this U-Boot version with both versions of cpu-node naming "cpu@0" and the former "PowerPC,440EPx@0". Signed-off-by: Stefan Roese <sr@denx.de>
2007-12-27ppc4xx: fdt: use fdt_fixup_ethernet()Stefan Roese
By using aliases in the dts file, the ethernet node fixup is much easier with the recently added functions. Please note that the dts file needs the aliases for this to work. Signed-off-by: Stefan Roese <sr@denx.de>
2007-12-27ppc4xx: Bring 4xx fdt support up-to-dateStefan Roese
This patch update the 4xx fdt support. It enabled fdt booting on the AMCC Kilauea and Sequoia for now. More can follow later quite easily. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Correct UART input clock calculation and passing to fdtStefan Roese
We now use a value in the gd (global data) structure for the UART input frequency, since the PPC4xx_SYS_INFO struct is always rewritten completely in get_sys_info(). Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Add freqUART to CPU speed detectionStefan Roese
This value is needed later for the device tree configuration of the uart clock. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Add additional debug info to 4xx fdt supportStefan Roese
2007-10-31ppc4xx: Add initial fdt support to 4xx (first needed on 405EX)Stefan Roese
