path: root/cpu/ppc4xx/commproc.c
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2008-06-03PPC4xx: Simplified post_word_{load, store}Grant Erickson
This patch simplifies post_word_{load,store} by using the preprocessor to eliminate redundant, copy-and-pasted code. Signed-off-by: Grant Erickson <gerickson@nuovations.com>
2008-01-09ppc4xx: Add CFG_POST_ALT_WORD_ADDR to support non OCM POST WORD storageStefan Roese
The privious 4xx POST implementation only supported storing the POST WORD in OCM. Since we need to reserve the OCM on LWMON5 for the logbuffer we need to store the POST WORD in some other non volatile location. This patch adds CFG_POST_ALT_WORD_ADDR to specify an address for such a location. Signed-off-by: Stefan Roese <sr@denx.de>
2004-02-23* Patches by Reinhard Meyer, 14 Feb 2004:wdenk
- update board/emk tree; use common flash driver - Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c [adapted for other PPC CPUs -- wd] - Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c * Patch by Jon Diekema, 13 Feb 2004: Call show_boot_progress() whenever POST "FAILED" is printed. * Patch by Nishant Kamat, 13 Feb 2004: Add support for TI OMAP1610 H2 Board Fixes for cpu/arm926ejs/interrupt.c (based on Richard Woodruff's patch for arm925, 16 Oct 03) Fix for a timer bug in OMAP1610 Innovator Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2 * Patches by Stephan Linz, 12 Feb 2004: - add support for NIOS timer with variable period preload counter value - prepare POST framework support for NIOS targets * Patch by Denis Peter, 11 Feb 2004: add POST support for the MIP405 board
