Also changed path in all linker scripts that reference this driver
All in-tree IBM/AMCC PPC4xx boards using the EMAC get this new CONFIG
Since this define is only used on one board that was never really in
production, removing this compile time option doesn't hurt and makes
the code more readable.
This patch fixes a compilation warning for the PIP405 board. It moves the
#ifndef CONFIG_CS8952_PHY define a little so that the warning doesn't
occur anymore. I am a little unsure if this #ifdef is at the correct
place now or if it could be removed completely. This needs to get
tested on the PIP405 board.
This patch adds GPCS, SGMII and M88E1112 PHY support
for the AMCC PPC460GT/EX processors.
Signed-off-by: Victor Gallardo <vgallardo@amcc.com>
This patch reworks the 440GX interrupt handling so that the common 4xx
code can be used. The 440GX is an exception to all other 4xx variants
by having the cascading interrupt vectors not on UIC0 but on a special
UIC named UICB0 (UIC Base 0). With this patch now, U-Boot references
the 440GX UICB0 when UIC0 is selected. And the common 4xx interrupt
handling is simpler without any 440GX special cases.
Also some additional cleanup to cpu/ppc4xx/interrupt.c is done.
This 2nd patch now removes all UIC mask bit definition. They should be
generated from the vectors by using the UIC_MASK() macro from now on.
This way only the vectors need to get defined for new PPC's.
Also only the really used interrupt vectors are now defined. This makes
definitions for new PPC versions easier and less error prone.
Another part of this patch is that the 4xx emac driver got a little
cleanup, since now the usage of the interrupts is clearer.
This patch is the first step to consolidate the UIC related defines in the
4xx headers. Move header from asm-ppc/ppc4xx-intvec.h to
asm-ppc/ppc4xx-uic.h as it will hold all UIC related defines in the next
steps.
This patch adds support for placing the RGMII bridge on the
PPC405EX(r) into MII/GMII mode and allows a board-specific
configuration to specify the bridge mode at compile-time.
Signed-off-by: Grant Erickson <gerickson@nuovations.com>
This patch fixes ppc4xx related printf format warning. Those warnings are
now visible since patch dc4b0b38d4aadf08826f6c31270f1eecd27964fd
[Fix printf errors.] by Andrew Klossner has been applied. Thanks, this is
really helpful.
Currently U-Boot crashes in ppc_4xx_eth_init on sequoia
with cache enabled (TLB Parity exeption). This patch
fixes the problem.
This patch fixes a problem with the RGMII setup of the 460GT. The 460GT
has 2 RGMII instances and we need to configure the 2nd RGMII instance
for the EMAC2+3 channels.
This patch adds support for the AMCC Glacier 460GT eval board.
The main difference to the Canyonlands board are listed here:
- 4 ethernet ports instead of 2
- no SATA port
- no USB port
Currently EMAC2+3 are not working. This will be fixed in a later
release.
This patch adds basic support for the AMCC 460EX/460GT PPC's.
The 405EZ only supports 512 bytes of rx-/tx-fifo EMAC sizes. But
currently 4k/2k is configured. This patch fixes this issue.
Thanks to Thomas Kindler <tkindler@lenord.de> for pointing this out.
U-Boot crashes in the net loop if CONFIG_4xx_DCACHE is
enabled. To reproduce the problem ensure that 'ethrotate'
environment variable isn't set to "no" and then run
"tftp 200000 not_existent_file".
This patch tries to fix the issue.
This patch allows the use of 4xx interrupt vector number defines
in board specific code outside cpu/ppc4xx.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
flush + invalidate_dcache_range() expect the start and stop+1 address.
So the stop address is the first address behind (!) the range.
This patch removes some redundant code and decrements the end
address of cache flush and invalidate by 1.
This patch enables the 4xx EMAC driver to work too, when dcache is
enabled.
I lately noticed, that newer 4xx board with GBit support sometimes don't
finish link autonegotiation in 4 seconds. Changing this timeout to 5
seconds seems fine here.
This patch changes all in32/out32 calls to use the recommended in_be32/
out_be32 macros instead.
The Haleakala is nearly identical with the Kilauea eval board. The only
difference is that the 405EXr only supports one EMAC and one PCIe
interface. This patch adds support for the Haleakala board by using
the identical image for Kilauea and Haleakala. The distinction is done
by comparing the PVR.
EPLD forces modes of PHY operation. By default full duplex is turned off.
This fix turns it on.
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
This change fixes a bug in the receive buffer handling, that
could lead to problems upon high network traffic (broadcasts...).
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
This patch adds support for the new AMCC 405EZ PPC. It is in
preparation for the AMCC Acadia board support.
Please note that this Acadia/405EZ support is still in a beta stage.
Still lot's of cleanup needed but we need a preliminary release now.
Patch below corrects the setting of the zmiifer register, it was
overwritting the register rather than ORing the settings.
Signed-off-by: Neil Wilson <NWilson@airspan.com>
Patch by Stefan Roese, 13 Sep 2006
- Add support for PPC440EPx & PPC440GRx
- Add support for PPC440EP(x)/GR(x) NAND controller
in cpu/ppc4xx directory
- Add NAND boot functionality for Sequoia board,
please see doc/README.nand-boot-ppc440 for details
- This Sequoia NAND image doesn't support environment
in NAND for now. This will be added in a short while.
Patch by Stefan Roese, 07 Sep 2006
Patch by John Otken, 23 Nov 2005
Patch by Stefan Roese, 20 Oct 2005
Patch by Stefan Roese, 18 Oct 2005
