When the timestamp is incremented via interrupt and the interrupt
period is greater than 1 msec, successive calls to get_timer() can
produce inaccurate timing since the interrupts are asynchronous
to the timing loop. For example, with an interrupt period of 10 msec
two successive calls to get_timer() could indicate an elapsed time
of 10 msec after only several hundred usecs -- depending on when
the next interrupt actually occurs. This behavior can cause
reliability issues with components such as CFI and NAND.
This can be remedied by calling reset_timer() prior to establishing
the base timestamp with get_timer(0), provided reset_timer()
resets the hardware timer (rather than simply resetting only the
timestamp). This has the effect of synchronizing the interrupts
(and the advance of the timestamp) with the timing loop.
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
The outx/writex macros were using writex(addr, val) rather than
the standard writex(val, addr), resulting in incompatibilty with
architecture independent components. This change set uses standard
parameter order.
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
-Fix asm/io.h macros
-Eliminate use of CACHE_BYPASS in cpu code
-Eliminate assembler warnings
-Fix mini-app stubs and force no small data
Patch by Scott McNutt, 08 Jun 2006
- Add support for Altera Nios-II processors.
- Add support for Psyent PCI-5441 board.
- Add support for Psyent PK1C20 board.
