path: root/cpu/mpc8xxx
2009-02-16fsl-ddr: Allow system to boot if we have more than 4G of memoryKumar Gala
Previously if we >=4G of memory and !CONFIG_PHYS_64BIT we'd report an error and hang. Instead of doing that since DDR is mapped in the lowest priority LAWs we setup the DDR controller and the max amount of memory we report back is what we can map (CONFIG_MAX_MEM_MAPPED) Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-02-16fsl-ddr: ignore memctl_intlv_ctl setting if only one DDR controllerKumar Gala
If we only have one controller we can completely ignore how memctl_intlv_ctl is set. Otherwise other levels of code get confused and think we have twice as much memory. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-23fsl-ddr: use the 1T timing as default configurationDave Liu
For light loaded system, we use the 1T timing to gain better memory performance, but for some heavily loaded system, you have to add the 2T timing options to board files. Signed-off-by: Dave Liu <daveliu@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2009-01-23fsl-ddr: make the self refresh idle threshold configurableDave Liu
Some 85xx processors have the advanced power management feature, such as wake up ARP, that needs enable the automatic self refresh. If the DDR controller pass the SR_IT (self refresh idle threshold) idle cycles, it will automatically enter self refresh. However, anytime one transaction is issued to the DDR controller, it will reset the counter and exit self refresh state. Signed-off-by: Dave Liu <daveliu@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2009-01-23fsl-ddr: clean up the ddr code for DDR3 controllerDave Liu
- The DDR3 controller is expanding the bits for timing config - Add the DDR3 32-bit bus mode support Signed-off-by: Dave Liu <daveliu@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2009-01-23fsl-ddr: update the bit mask for DDR3 controllerDave Liu
According to the latest 8572 UM, the DDR3 controller is expanding the bit mask, and we use the extend ACTTOPRE mode when tRAS more than 19 MCLK. Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-12-03fsl ddr skip interleaving if not supported.Ed Swarthout
Removed while(1) hang if memctl_intlv_ctl is set wrong. Remove embedded tabs from strings. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2008-10-18Add debug information for DDR controller registersHaiying Wang
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2008-10-18Check DDR interleaving modeHaiying Wang
* Check DDR interleaving mode from environment by reading memctl_intlv_ctl and ba_intlv_ctl. * Print DDR interleaving mode information * Add doc/README.fsl-ddr to describe the interleaving setting Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2008-10-18Pass dimm parameters to populate populate controller optionsHaiying Wang
Because some dimm parameters like n_ranks needs to be used with the board frequency to choose the board parameters like clk_adjust etc. in the board_specific_paramesters table of the board ddr file, we need to pass the dimm parameters to the board file. * move ddr dimm parameters header file from /cpu to /include directory. * add ddr dimm parameters to populate board specific options. * Fix fsl_ddr_board_options() for all the 8xxx boards which call this function. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2008-10-18Make DDR interleaving mode work correctlyHaiying Wang
Fix some bugs: 1. Correctly set intlv_ctl in cs_config. 2. Correctly set sa, ea in cs_bnds when bank interleaving mode is enabled. 3. Set base_address and total memory for each ddr controller in memory controller interleaving mode. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2008-09-13Coding style cleanup, update CHANGELOGWolfgang Denk
2008-09-07Fix compiler warning in mpc8xxx ddr codeKumar Gala
ctrl_regs.c: In function 'compute_fsl_memctl_config_regs': ctrl_regs.c:523: warning: 'caslat' may be used uninitialized in this function ctrl_regs.c:523: note: 'caslat' was declared here Add a warning in DDR1 case if cas_latency isn't a value we know about. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-08-27FSL DDR: Add DDR2 DIMM paramter supportKumar Gala
Compute DIMM parameters based upon the SPD information. Signed-off-by: James Yang <James.Yang@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-27FSL DDR: Add DDR1 DIMM paramter supportKumar Gala
Compute DIMM parameters based upon the SPD information in spd. Signed-off-by: James Yang <James.Yang@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-27FSL DDR: Rewrite the FSL mpc8xxx DDR controller setup code.Kumar Gala
The main purpose of this rewrite it to be able to share the same initialization code on all FSL PowerPC products that have DDR controllers. (83xx, 85xx, 86xx). The code is broken up into the following steps: GET_SPD COMPUTE_DIMM_PARMS COMPUTE_COMMON_PARMS GATHER_OPTS ASSIGN_ADDRESSES COMPUTE_REGS PROGRAM_REGS This allows us to share more code an easily allow for board specific code overrides. Additionally this code base adds support for >4G of DDR and provides a foundation for supporting interleaving on processors with more than one controller. Signed-off-by: James Yang <James.Yang@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
