P1011 - Single core variant of P1020
P2010 - Single core variant of P2020
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
P1020 is another member of QorIQ series of processors which falls in ULE
category. It is an e500 based dual core SOC.
Being a scaled down version of P2020 it has following differences:
- 533MHz - 800MHz core frequency.
- 256Kbyte L2 cache
- Ethernet controllers with classification capabilities.
Also the SOC is pin compatible with P2020
The number of CPUs are getting detected dynamically by checking the
processor SVR value. Also removed CONFIG_NUM_CPUS references from all
the platforms with 85xx/86xx processors.
This can help to use the same u-boot image across the platforms.
Also revamped and corrected few Freescale Copyright messages.
Removed same code pieces from cpu/mpc85xx/cpu.c and cpu/mpc86xx/cpu.c
and moved to cpu/mpc8xxx/cpu.c(new file)
Previously, 85xx and 86xx boards would display DRAM information on
bootup such as:
I2C: ready
DRAM:
Memory controller interleaving enabled: Bank interleaving!
2 GB
FLASH: 256 MB
This patch moves the printing of the DRAM controller configuration to a
common board_add_ram_info() function which prints out DDR type, width,
CAS latency, and ECC mode. It also makes the DDR interleaving
information print out in a more sane manner:
I2C: ready
DRAM: 2 GB (DDR2, 64-bit, CL=4, ECC on)
DDR Controller Interleaving Mode: bank
FLASH: 256 MB
The calculate for rank density in compute_ranksize() for DDR3 used all
integers for the expression, so the result was also a 32-bit integer, even
though the 'bsize' variable is a u64. Fix the expression to calculate a
true 64-bit value.
The ddr code computes most things as 64-bit quantities and had some places
in the middle that it was using phy_addr_t and phys_size_t.
Instead we use unsigned long long through out and only at the last stage of
setting the LAWs and reporting the amount of memory to the board code do we
truncate down to what we can cover via phys_size_t.
This has the added benefit that the DDR controller itself is always setup
the same way regardless of how much memory we have. Its only the LAW
setup that limits what is visible to the system.
- support mirrored DIMMs, not support register DIMMs
- test passed on P2020DS board with MT9JSF12872AY-1G1D1
- test passed on MPC8569MDS board with MT8JSF12864HY-1G1D1
Signed-off-by: Dave Liu <daveliu@freescale.com>
Signed-off-by: Travis Wheatley <travis.wheatley@freescale.com>
1. wr_lat
UM said the total write latency for DDR2 is equal to
WR_LAT + ADD_LAT, the write latency is CL + ADD_LAT - 1.
so, the WR_LAT = CL - 1;
2. rd_to_pre
we missed to add the ADD_LAT for DDR2 case.
Reported-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
Previously if we >=4G of memory and !CONFIG_PHYS_64BIT we'd report
an error and hang. Instead of doing that since DDR is mapped in the
lowest priority LAWs we setup the DDR controller and the max amount
of memory we report back is what we can map (CONFIG_MAX_MEM_MAPPED)
Acked-by: Becky Bruce <beckyb@kernel.crashing.org>
If we only have one controller we can completely ignore how
memctl_intlv_ctl is set. Otherwise other levels of code get confused
and think we have twice as much memory.
For light loaded system, we use the 1T timing to gain better
memory performance, but for some heavily loaded system,
you have to add the 2T timing options to board files.
Acked-by: Andy Fleming <afleming@freescale.com>
Some 85xx processors have the advanced power management feature,
such as wake up ARP, that needs enable the automatic self refresh.
If the DDR controller pass the SR_IT (self refresh idle threshold)
idle cycles, it will automatically enter self refresh. However,
anytime one transaction is issued to the DDR controller, it will
reset the counter and exit self refresh state.
- The DDR3 controller is expanding the bits for timing config
- Add the DDR3 32-bit bus mode support
According to the latest 8572 UM, the DDR3 controller
is expanding the bit mask, and we use the extend ACTTOPRE
mode when tRAS more than 19 MCLK.
Removed while(1) hang if memctl_intlv_ctl is set wrong.
Remove embedded tabs from strings.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
* Check DDR interleaving mode from environment by reading memctl_intlv_ctl and
ba_intlv_ctl.
* Print DDR interleaving mode information
* Add doc/README.fsl-ddr to describe the interleaving setting
Because some dimm parameters like n_ranks needs to be used with the board
frequency to choose the board parameters like clk_adjust etc. in the
board_specific_paramesters table of the board ddr file, we need to pass
the dimm parameters to the board file.
* move ddr dimm parameters header file from /cpu to /include directory.
* add ddr dimm parameters to populate board specific options.
* Fix fsl_ddr_board_options() for all the 8xxx boards which call this function.
Fix some bugs:
1. Correctly set intlv_ctl in cs_config.
2. Correctly set sa, ea in cs_bnds when bank interleaving mode is enabled.
3. Set base_address and total memory for each ddr controller in memory
controller interleaving mode.
ctrl_regs.c: In function 'compute_fsl_memctl_config_regs':
ctrl_regs.c:523: warning: 'caslat' may be used uninitialized in this function
ctrl_regs.c:523: note: 'caslat' was declared here
Add a warning in DDR1 case if cas_latency isn't a value we know about.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Compute DIMM parameters based upon the SPD information.
Signed-off-by: James Yang <James.Yang@freescale.com>
Compute DIMM parameters based upon the SPD information in spd.
The main purpose of this rewrite it to be able to share the same
initialization code on all FSL PowerPC products that have DDR
controllers. (83xx, 85xx, 86xx).
The code is broken up into the following steps:
GET_SPD
COMPUTE_DIMM_PARMS
COMPUTE_COMMON_PARMS
GATHER_OPTS
ASSIGN_ADDRESSES
COMPUTE_REGS
PROGRAM_REGS
This allows us to share more code an easily allow for board specific code
overrides.
Additionally this code base adds support for >4G of DDR and provides a
foundation for supporting interleaving on processors with more than one
controller.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
