path: root/cpu/mpc8xxx/ddr/lc_common_dimm_params.c
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-03-30fsl-ddr: add the DDR3 SPD infrastructureDave Liu
- support mirrored DIMMs, not support register DIMMs - test passed on P2020DS board with MT9JSF12872AY-1G1D1 - test passed on MPC8569MDS board with MT8JSF12864HY-1G1D1 Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Travis Wheatley <travis.wheatley@freescale.com>
2008-08-27FSL DDR: Rewrite the FSL mpc8xxx DDR controller setup code.Kumar Gala
The main purpose of this rewrite it to be able to share the same initialization code on all FSL PowerPC products that have DDR controllers. (83xx, 85xx, 86xx). The code is broken up into the following steps: GET_SPD COMPUTE_DIMM_PARMS COMPUTE_COMMON_PARMS GATHER_OPTS ASSIGN_ADDRESSES COMPUTE_REGS PROGRAM_REGS This allows us to share more code an easily allow for board specific code overrides. Additionally this code base adds support for >4G of DDR and provides a foundation for supporting interleaving on processors with more than one controller. Signed-off-by: James Yang <James.Yang@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
