This patch adds the configuration option CONFIG_SYS_SMC_RXBUFLEN.
With this option it is possible to allow the receive
buffer for the SMC on 8xx to be greater then 1. In case
CONFIG_SYS_SMC_RXBUFLEN == 1 this driver works as the
old version.
When defining CONFIG_SYS_SMC_RXBUFLEN also
CONFIG_SYS_MAXIDLE must be defined to setup the maximum
idle timeout for the SMC.
All implementations of the functions i2c_reg_read() and
i2c_reg_write() are identical. We can save space and simplify the
code by converting these functions into inlines and putting them in
i2c.h.
Acked-By: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Since commit 561858ee building for FADS823 and RRvision
doesn't work. Let's include version.h and timestamp.h
unconditionally to fix the problem.
Use the GNU 'date' command to auto-generate a new U-Boot
timestamp on every compile.
Removed initialization of the driver from net/eth.c
Affected boards:
Several MPC8xx boards
Several MPC8260/MPC8272 boards
Several MPC85xx boards
eventually leads to a machine check. This change assures that DPRAM
is allocated only once in that case.
Signed-off-by: Gary Jennejohn <garyj@denx.de>
Move to using the environment variables 'ethaddr', 'eth1addr', etc..
instead of bd->bi_enetaddr, bi_enet1addr, etc.
This makes the code a bit more flexible to the number of ethernet
interfaces.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
fdt.c: In function 'ft_cpu_setup':
fdt.c:33: warning: implicit declaration of function 'do_fixup_by_prop_u32'
fdt.c:39: warning: implicit declaration of function 'do_fixup_by_compat_u32'
fdt.c:43: warning: implicit declaration of function 'fdt_fixup_ethernet'
fdt.c:45: warning: implicit declaration of function 'fdt_fixup_memory'
This patch does some shifting around of OF support on 8xx.
Signed-off-by: Bryan O'Donoghue <bodonoghue@codehermit.ie>
R29 was an unlucky choice as with recent toolchains (gcc-4.2.x) gcc
will refuse to use load/store multiple insns; instead, it issues a
list of simple load/store instructions upon function entry and exit,
resulting in bigger code size, which in turn makes the build for a
few boards fail.
Use r2 instead.
Change return values of init() functions in all Ethernet drivers to conform
to the following:
>=0: Success
<0: Failure
All drivers going forward should return 0 on success. Current drivers that
return 1 on success were left as-is to minimize changes.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Acked-By: Timur Tabi <timur@freescale.com>
This patch fixes several issues at least on a MPC885 based system with two
FEC interfaces used in MII mode.
1. PHY discovery should first read PHY_PHYIDR2 register and only then
PHY_PHYIDR1 like cpu/mpc8xx/fec.c::mii_discover_phy() does it,
otherwise the values read are wrong. Also notice, that PHY discovery
cannot work on MPC88x / MPC87x in setups with both FECs active at all
in its present form, because for both interfaces the registers from FEC
1 are used to communicate over MII.
2. Remove code duplication for resetting the FEC by isolating it into a
separate function.
3. Initialize MII on FEC 1 when communicating over FEC 2 in fec_init().
4. Optimize mii_init() to only reset the FEC 1 controller once.
5. Fix a typo in mii_init() using index i instead of j thus potentially
leading to unpredictable results.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
CAS-Latency=2, Write Recovery Time tWR=2
The max. supported bus frequency is 66 MHz. Therefore, changed
threshold to switch from 1:1 mode to 2:1 from 80 MHz to 66 MHz.
Signed-off-by: Martin Krause <martin.krause@tqs.de>
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
- adapt to the more generic EXCEPTION_PROLOG and CRIT_EXCEPTION macros
- minor 4xx cleanup
Signed-off-by: Markus Klotzbuecher <mk@denx.de>
Some code cleanup.
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
Patch by Martin Krause, 20 Mar 2006
All MII configuration is done via FEC1 registers. But MII_SPEED was
configured according to FEC used. So if only FEC2 was used, this caused
the real MII_SPEED register in FEC1 to stay uninitalised, what lead
to "mii_send STUCK!" messages. Fix: always configure MII_SPEED on FEC1
only.
Patch by Markus Klotzbuecher, 12 Jul 2006
Patch by Bryan O'Donoghue, 25 Apr 2005
Fix LCD logo for lwmon board which got lost in the merge of 8xx and PXA LCD code
genereated HRESET pulse is too short to reset the external circuitry.
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to
pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for
additional ethernet addresses.
* Cleanup drivers/i82365.c - avoid duplication of code
* Fix bogus "cannot span across banks" flash error message
* Add support for CompactFlash for the CPC45 Board.
* Patch by Hinko Kocevar, 21 Aug 2004:
- Group common framebuffer functions in common/lcd.c
- Group common framebuffer macros and #defines in include/lcd.h
- Provide calc_fbsize() for video ATAG
