This patch does some shifting around of OF support on 8xx.
Signed-off-by: Bryan O'Donoghue <bodonoghue@codehermit.ie>
CAS-Latency=2, Write Recovery Time tWR=2
The max. supported bus frequency is 66 MHz. Therefore, changed
threshold to switch from 1:1 mode to 2:1 from 80 MHz to 66 MHz.
Signed-off-by: Martin Krause <martin.krause@tqs.de>
Patch by Martin Krause, 20 Mar 2006
Patch by Bryan O'Donoghue, 25 Apr 2005
Allow clock setting on MPC866/MPC885 series chips according to
environment variable `cpuclk'
* Patch by Yuli Barcohen, 20 Apr 2004:
Remove unnecessary redefine of CPM_DATAONLY_SIZE for MPC826x
- Rename DUET_ADS to MPC885ADS
- Rename CONFIG_DUET to CONFIG_MPC885_FAMILY
- Rename CONFIG_866_et_al to CONFIG_MPC866_FAMILY
- Clean up FADS family port to use the new defines
binary image for all clock frequencies. Implement run-time
optimization of flash access timing based on the actual bus
frequency.
modules at CPU clock frequencies above 66 MHz.
* Optimize flash programming speed for LWMON (by another 100% :-)
see doc/README.MPC866 for details;
implement workaround for "SIU4" and "SIU9" silicon bugs on MPC866;
calculate CPU clock frequency from PLL register values.
* Add support for 128 MB RAM on TQM8xxL/M modules
* Minor code cleanup (coding style)
* Patch by Reinhard Meyer, 30 Dec 2003:
- cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE,
- added CONFIG_PHY_ADDR to include/configs/IceCube.h,
- turned debug print of PHY registers into a function (called in two places)
- added support for EMK MPC5200 based modules
* Fix MPC8xx PLPRCR_MFD_SHIFT typo
* Add support for TQM866M modules
* Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash)
* Fix a few compiler warnings
- Added Motorola CPU 8540/8560 support (cpu/85xx)
- Added Motorola MPC8540ADS board support (board/mpc8540ads)
- Added Motorola MPC8560ADS board support (board/mpc8560ads)
add delay to get I2C working with "imm" command and s3c24x0_i2c.c
* Patch by Richard Woodruff, 17 July 03:
- Fixed bug in OMAP1510 baud rate divisor settings.
* Patch by Nye Liu, 16 July 2003:
MPC860FADS fixes:
- add MPC86xADS support (uses MPC86xADS.h)
- add 866P/T core support (also MPC859T/MPC859DSL/MPC852T)
o PLPRCR changes
o BRG changes (EXTAL/XTAL restricted to 10MHz)
o don't trust gclk() software measurement by default, depend on
CONFIG_8xx_GCLK_FREQ
- add DRAM SIMM not installed detection
- use more "correct" SDRAM initialization sequence
- allow different SDRAM sizes (8xxADS has 8M)
- default DER is 0
- remove unused MAMR defines from FADS860T.h (all done in fads.c)
- rename MAMR/MBMR defines to be more consistent. Should eventually
be merged into MxMR to better reflect the PowerQUICC datasheet.
* Patch by Yuli Barcohen, 16 Jul 2003:
support new Motorola PQ2FADS-ZU evaluation board which replaced
MPC8260ADS and MPC8266ADS
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
