path: root/cpu/mpc8xx/cpu.c
2008-03-26Coding Style cleanyp; update CHANGELOGWolfgang Denk
2008-03-258xx: Update OF support on 8xxBryan O'Donoghue
This patch does some shifting around of OF support on 8xx. Signed-off-by: Bryan O'Donoghue <bodonoghue@codehermit.ie>
2008-01-12Added support for the mgsuvd board from keymile.Heiko Schocher
2006-03-18Add support for MPC859/866 Rev. A.0Wolfgang Denk
2005-05-09On LWMON we must use the watchdog to reset the board as the CPULABEL_2005_05_09_1245wdenk
genereated HRESET pulse is too short to reset the external circuitry.
2004-12-18Add support for UC100 boardLABEL_2004_12_18_2335wdenk
2004-09-28* Patch by Yuli Barcohen, 13 Jul 2004:wdenk
Allow clock setting on MPC866/MPC885 series chips according to environment variable `cpuclk' * Patch by Yuli Barcohen, 20 Apr 2004: Remove unnecessary redefine of CPM_DATAONLY_SIZE for MPC826x
2004-05-12Patch by Klaus Heydeck, 12 May 2004:wdenk
Using external watchdog for KUP4 boards in mpc8xx/cpu.c; load_sernum_ethaddr() for KUP4 boards in lib_ppc/board.c; various changes to KUP4 board specific files
2004-01-31Fix variable CPU clock for MPC859/866 systems for low CPU clockswdenk
2004-01-18Fix typo in Makefile;wdenk
fix problem with PARTNUM detection
2004-01-04* Fix problems caused by Robert Schwebel's cramfs patchwdenk
* Patch by Scott McNutt, 02 Jan 2004: Add support for the Nios Active Serial Memory Interface (ASMI) on Cyclone devices * Patch by Andrea Marson, 16 Dec 2003: Add support for the PPChameleon ME and HI modules * Patch by Yuli Barcohen, 22 Dec 2003: Add support for Motorola DUET ADS board (MPC87x/88x)
2003-08-30Patch by Raghu Krishnaprasad, 7 Aug 2003:U-Boot-0_4_7wdenk
add support for Adder II MPC852T module
2003-07-17* Patch by Martin Krause, 17 Jul 2003:wdenk
add delay to get I2C working with "imm" command and s3c24x0_i2c.c * Patch by Richard Woodruff, 17 July 03: - Fixed bug in OMAP1510 baud rate divisor settings. * Patch by Nye Liu, 16 July 2003: MPC860FADS fixes: - add MPC86xADS support (uses MPC86xADS.h) - add 866P/T core support (also MPC859T/MPC859DSL/MPC852T) o PLPRCR changes o BRG changes (EXTAL/XTAL restricted to 10MHz) o don't trust gclk() software measurement by default, depend on CONFIG_8xx_GCLK_FREQ - add DRAM SIMM not installed detection - use more "correct" SDRAM initialization sequence - allow different SDRAM sizes (8xxADS has 8M) - default DER is 0 - remove unused MAMR defines from FADS860T.h (all done in fads.c) - rename MAMR/MBMR defines to be more consistent. Should eventually be merged into MxMR to better reflect the PowerQUICC datasheet. * Patch by Yuli Barcohen, 16 Jul 2003: support new Motorola PQ2FADS-ZU evaluation board which replaced MPC8260ADS and MPC8266ADS
2003-04-10Add support for TQM862L moduleswdenk
