path: root/cpu/mpc86xx/speed.c
2008-04-30Fix calculation of I2C clock for some 86xx chipsTimur Tabi
Some 86xx chips use CCB as the base clock for the I2C, and others used CCB/2. There is no pattern that can be used to determine which chips use which frequency, so the only way to determine is to look up the actual SOC designation and use the right value for that SOC. Signed-off-by: Timur Tabi <timur@freescale.com>
2008-02-1485xx, 86xx: Determine I2C clock frequencies and store in global_dataTimur Tabi
Update global_data to define i2c1_clk and i2c2_clk to 85xx and 86xx. Update the get_clocks() function in 85xx and 86xx to determine the I2C clock frequency and store it in gd->i2c1_clk and gd->i2c2_clk. Signed-off-by: Timur Tabi <timur@freescale.com>
2007-11-18Fix compiler warnings for PPC systems. Update CHANGELOG.Wolfgang Denk
2007-09-15Fix cases where DECLARE_GLOBAL_DATA_PTR was not declared as globalWolfgang Denk
2006-08-22General indent and whitespace cleanups.Jon Loeliger
2006-07-31Move get_board_sys_clk to board directoryHaiying Wang
2006-07-28Fix 8641HPCN pollutionJohn Traill
2006-06-07Fix a get_board_sys_clk() use-before-def warning.Jon Loeliger
Signed-off-by: Jon Loeliger <jdl@jdl.com>
2006-05-31Review cleanups.Jon Loeliger
2006-04-27Cleanup whitespaces and style issues.Jon Loeliger
Removed //-style comments. Use 80-column lines. Remove trailing whitespace. Remove dead code and debug cruft.
2006-04-26Initial support for MPC8641 HPCN board.Jon Loeliger
