Patch by Matt ?? <kb9200_dev@kwikbyte.com>, 27 Apr 2005
Patch by Kylo Ginsberg, 13 Apr 2005
routed to the Watchdog handler
Patch by Eugene Surovegin, 18 Jun 2005
- C++ comments
- Trailing white space
- Indentation not by TAB
- Excessive amount of empty lines
- Trailing empty lines
Add Xianghua Xiao and Lunsheng Wang's support for the
GDA MPC8540 EVAL board.
Move the TSEC driver out of cpu/mpc85xx as it will be shared
by the upcoming mpc83xx family as well.
Implemented support for MPC8548CDS board.
Added DDR II support based on SPD values for MPC85xx boards.
This roll-up patch also includes bugfies for the previously
published patches:
DDRII CPO, pre eTSEC, 8548 LBIU, Andy's TSEC, eTSEC 3&4 I/O
Determine L2 Cache size dynamically on 85XX boards.
- Convert the CPM2 based functionality to use new CONFIG_CPM2
option rather than a myriad of CONFIG_MPC8560-like variants.
Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560.
Eliminates the CONFIG_MPC8560 option entirely. Distributes the
new CONFIG_CPM2 option to each 8260 board.
PM520 boards.
Fix PHY address for canmb board.
- fix clock rates
- remove debug messages
- fix flash sector protection
* Patch by Steven Scholz, 07 Apr 2005:
Fix warning in cpu/arm920t/at91rm9200/i2c.c
Add support for VoiceBlue board.
* Patch by Ladislav Michl, 05 Apr 2005:
Fix netboot_common() prototypes.
* Cleanup.
Interfaces are named as follows: "ENET1" - TSEC2, "ENET2" - FEC
* Patch by Martin Krause, 04 Apr 2005:
Update default configuration for CMC_PU2 board.
- Add support for MicroSys CPU87 board
- Add support for MicroSys PM854 board
- use TQM5200_auto as MAKEALL target for TQM5200 systems
- add support for SM501 graphics controller
- add support for graphic console on TQM5200
- add support for TQM5200 Rev 200
- cleanup, fix typo in include/configs/TQM5200.h
- Change the name of the Ethernet driver: MOTO ENET -> ENET
- Reformat boot messages
- Enable redundant environment
- Replace the -O2 optimization flag with -mno-string
Restore copyright statements in OHCI drivers.
* Add support for TQM8540 board
- Add support for Altera Nios-II processors.
- Add support for Psyent PCI-5441 board.
- Add support for Psyent PK1C20 board.
- Fix PCI window on MPC85xx; remove unneeded PCI initialization
from board_early_init_f()
- Provide SW workaround for PCI initialization on 85xx CDS
- Convert MPC85xxADS to use common CFI flash driver
* Cleanup: avoid compiler warnings
* Add CMC PU2 board to MAKEALL script
Fix MPC85xx I2C driver
- support larger DDR memories up to 2G on the PC8540/8560ADS and
STXGP3 boards
- Made MPC8540/8560ADS be 33Mhz PCI by default.
- Removed moldy CONFIG_RAM_AS_FLASH, CFG_FLASH_PORT_WIDTH_16
and CONFIG_L2_INIT_RAM options.
- Refactor Local Bus initialization out of SDRAM setup.
- Re-implement new version of LBC11/DDR11 errata workarounds.
- Moved board specific PCI init parts out of CPU directory.
- Added TLB entry for PCI-1 IO Memory
- Updated README.mpc85xxads
* Patch by Sascha Hauer, 28 Jun:
- add generic support for Motorola i.MX architecture
- add support for mx1ads, mx1fs2 and scb9328 boards
* Patches by Marc Leeman, 23 Jul 2004:
- Add define for the PCI/Memory Buffer Configuration Register
- corrected comments in cpu/mpc824x/cpu_init.c
* Add support for multiple serial interfaces
(for example to allow modem dial-in / dial-out)
Add support for WindRiver's SBC8560 board
* Patch by Nicolas Lacressonniere, 24 Jun 2004
Small Bugs fixes for "at91rm9200dk" board:
- Timing modifications for SPI DataFlash access
- Fix NAND flash detection bug
* Patch by Nicolas Lacressonniere, 24 Jun 2004:
Add Support for Flash AT49BV6416 for AT91RM9200DK board
Completion of the 8540ADS/8560ADS updates:
Fix some PCI and Rapid I/O memory maps,
Initialize both TSEC 1 and 2,
Initialize SDRAM
Update MAINTAINER for 85xx boards and README.mpc85xxads
Dynamically handle REV1 and REV2 MPC85xx parts.
(Jon Loeliger, 10-May-2004).
New consistent memory map and Local Access Window across MPC85xx line.
New CCSRBAR at 0xE000_0000 now.
Add RAPID I/O memory map.
New memory map in README.MPC85xxads
(Kumar Gala, 10-May-2004)
Better board and CPU identification on MPC85xx boards at boot.
SDRAM clock control fixes on MPC8540ADS & MPC8560 boards.
Some configuration options for MPC8540ADS & MPC8560ADS cleaned up.
(Jim Robertson, 10-May-2004)
Rewrite of the MPC85xx Three Speed Ethernet Controller (TSEC) driver.
Supports multiple PHYs.
(Andy Fleming, 10-May-2004)
Some README.MPC85xxads updates.
Copyright updates for "Freescale"
- Add support for RPC/STx GP3, Motorola 8560 board
- Update 85xx TSEC driver so it searches MII for first available PHY
and uses that one.
- Add functions to support console MII commands.
* Patch by Tolunay Orkun, 07 Apr 2004:
Move initialization of bi_iic_fast[]
from board_init_f() to board_init_r()
* Patch by Yasushi Shoji, 07 Apr 2004:
Cleanup microblaze port
* Patch by Sangmoon Kim, 07 Apr 2004:
Add auto SDRAM module detection for Debris board
- update board/emk tree; use common flash driver
- Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c
[adapted for other PPC CPUs -- wd]
- Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c
* Patch by Jon Diekema, 13 Feb 2004:
Call show_boot_progress() whenever POST "FAILED" is printed.
* Patch by Nishant Kamat, 13 Feb 2004:
Add support for TI OMAP1610 H2 Board
Fixes for cpu/arm926ejs/interrupt.c
(based on Richard Woodruff's patch for arm925, 16 Oct 03)
Fix for a timer bug in OMAP1610 Innovator
Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2
* Patches by Stephan Linz, 12 Feb 2004:
- add support for NIOS timer with variable period preload counter value
- prepare POST framework support for NIOS targets
* Patch by Denis Peter, 11 Feb 2004:
add POST support for the MIP405 board
* Cleanup compiler warnings
* Fix problem with side effects in macros in include/usb.h
* Patch by David Benson, 13 Nov 2003:
bug 841358 - fix TFTP download size limit
* Fixing bug 850768:
improper flush_cache() in load_serial()
* Fixing bug 834943:
MPC8540 - missing volatile declarations
* Patch by Stephen Williams, 09 Feb 2004:
Add support for Xilinx SystemACE chip:
- New files common/cmd_ace.c and include/systemace.h
- Hook systemace support into cmd_fat and the partition manager
* Patch by Travis Sawyer, 09 Feb 2004:
Add bi_opbfreq & bi_iic_fast to 440GX bd_info as needed for Linux
recent tools
* Add checksum verification to 'imls' command
* Add bd_info fields needed for 4xx Linux I2C driver
* Patch by Martin Krause, 4 Nov. 2003:
Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap)
* Print used network interface when CONFIG_NET_MULTI is set
small patch for mpc85xx
* Fix small problem in MPC5200 I2C driver
* Fix FCC3 support on ATC board
- Added Motorola CPU 8540/8560 support (cpu/85xx)
- Added Motorola MPC8540ADS board support (board/mpc8540ads)
- Added Motorola MPC8560ADS board support (board/mpc8560ads)
* Minor code cleanup
