path: root/cpu/mpc85xx/interrupts.c
2009-08-2885xx: Improve MPIC initializationTimur Tabi
The MPIC initialization code for Freescale e500 CPUs was not using I/O accessors, and it was not issuing a read-back to the MPIC after setting mixed mode. This may be the cause of a spurious interrupt on some systems. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-09Fix printf errors under -DDEBUGAndrew Klossner
Fix printf format-string/arg mismatches under -DDEBUG. These warnings occur with DEBUG defined for a platform using cpu/mpc85xx. Users of other architectures can unearth similar problems by adding the line "CFLAGS += -DDEBUG=1" in config.mk right after "CFLAGS += $(call cc-option,-fno-stack-protector)". Signed-off-by: Andrew Klossner <andrew@cesa.opbu.xerox.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-08-27mpc85xx: remove redudant code with lib_ppc/interrupts.cKumar Gala
For some reason we duplicated the majority of code in lib_ppc/interrupts.c not show how that happened, but there is no good reason for it. Use the interrupt_init_cpu() and timer_interrupt_cpu() since its why they exist. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-02-27Fix source for ECM error IVPRAndy Fleming
The source vector for the ECM was being set to 2, but that's what the source vector for DDR was being set to. Change it to 1. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-12-11Stop using immap_t on 85xxKumar Gala
In the future the offsets to various blocks may not be in same location. Move to using CFG_MPC85xx_*_ADDR as the base of the registers instead of getting it via &immap. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-08-1485xx start.S cleanup and exception supportAndy Fleming
From: Ed Swarthout <Ed.Swarthout@freescale.com> Support external interrupts from platform to eliminate system hangs. Define CONFIG_INTERRUPTS board configure option to enable. Enable ecm, ddr, lbc, and pci/pcie error interrupts in PIC. Remove extra cpu initialization redundant with hardware initialization. Whitespace cleanup. Define and use _START_OFFSET consistent with other processors using ppc_asm.tmpl Move additional code from .text to boot page to make room for exception vectors at start of image. Handle Machine Check, External and Critical exceptions. Fix e500 machine check error determination in traps.c TEXT_BASE can now be 0xfffc_0000 - which cuts binary image in half. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2007-07-09cpu/m*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04cpu/mpc*/ : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2005-05-13Fix timer handling on MPC85xx systemswdenk
