path: root/cpu/mpc83xx
2008-02-14PPC: Use r2 instead of r29 as global data pointerWolfgang Denk
R29 was an unlucky choice as with recent toolchains (gcc-4.2.x) gcc will refuse to use load/store multiple insns; instead, it issues a list of simple load/store instructions upon function entry and exit, resulting in bigger code size, which in turn makes the build for a few boards fail. Use r2 instead. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-02-14ppc: Refactor cache routines, so there is only one common set.Rafal Jaworowski
Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
2008-02-12QE: Move FDT support into a common fileKumar Gala
Move the flat device tree setup for QE related devices into a common file shared between 83xx & 85xx platforms that have QE's. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-17mpc83xx: Fix the fatal conflict of mergeDave Liu
The commit 9e89647889cd4b5ada5b5e7cad6cbe55737a08d7 will cause the mpc8315erdb board can't boot up. The patch fix that bug, and remove the duplicated #ifdef CFG_SPCR_TSECEP code and clean the SCCR_TSEC2 for MPC8313E processor. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-16mpc83xx: add support for more system clock performance controlsKim Phillips
System registers that are modified are the Arbiter Configuration Register (ACR), the System Priority Control Register (SPCR), and the System Clock Configuration Register (SCCR). Signed-off by: Michael F. Reiss <Michael.F.Reiss@freescale.com> Signed-off by: Joe D'Abbraccio <ljd015@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-16mpc83xx: Add config of eTSEC emergency priority in SPCRDave Liu
The TSEC emergency priority definition of 831x/837x is different than the definition of 834x in SPCR register. Add the other config of TSEC emergency priority into cpu_init.c Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-12Fixed syntax error in function init_e300_core() of mpc83xx/start.S ifHeiko Schocher
Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Heiko Schocher <hs@denx.de>
2008-01-10mpc83xx: Fix the bug of 266MHz data rate DDRDave Liu
The DDR doesn't work on the 266MHz data rate, the patch fix the bug. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-10mpc83xx: add "fsl, qe" compatible fixupsAnton Vorontsov
New device trees will use "fsl,qe" compatible properties. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-08mpc83xx: convert to using do_fixup_*()Kim Phillips
convert to using simpler mpc85xx style fdt update code; streamline by eliminating macros OF_SOC, OF_CPU, etc. which allows us to rm the old school FLAT_TREE code from 83xx (since the sbc8349 was just converted over to using libfdt). Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-08Add support CONFIG_UEC_ETH3 in MPC83xxJoakim Tjernlund
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2008-01-08mpc83xx: Add the support of MPC837xEMDS boardDave Liu
The MPC837xEMDS board support: * DDR2 400MHz hardcoded and SPD init * Local bus NOR Flash * I2C, UART, MII and RTC * eTSEC RGMII * PCI host Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-01-08mpc83xx: Add the support of MPC8315E SoCDave Liu
The MPC8315E SoC including e300c3 core and new IP blocks, such as TDM, PCI Express and SATA controller. Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-01-08mpc83xx: Add the support of MPC837x SoCDave Liu
The MPC837x SoC including e300c4 core and new IP blocks, such as SDHC, PCI Express and SATA controller. Signed-off-by: Dave Liu <daveliu@freescale.com>
2007-12-07Convert boards that set memory node to use fdt_fixup_memory()Kumar Gala
2007-11-21Update libfdt from device tree compiler (dtc)Kumar Gala
Update libfdt to commit 8eaf5e358366017aa2e846c5038d1aa19958314e from the device tree compiler (dtc) project. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-11-15Revert "Correct fixup relocation for mpc83xx"Grant Likely
This reverts commit 057004f4a4863554d56cc56268bfa7c7d9738e27. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-08-17mpc83xx: fix typo in DDR2 programmingKim Phillips
introduced in the implement board_add_ram_info patch as I was cleaning out the magic numbers. sorry. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-16mpc83xx: implement board_add_ram_infoKim Phillips
add board_add_ram_info, to make memory diagnostic output more consistent. u-boot banner output now looks like: DRAM: 256 MB (DDR1, 64-bit, ECC on) and for boards with SDRAM on the local bus, a line such as this is added: SDRAM: 64 MB (local bus) also replaced some magic numbers with their equivalent define names. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-15mpc83xx: migrate remaining freescale boards to libfdtKim Phillips
this adds libfdt support code for the freescale mpc8313erdb, mpc832xemds, mpc8349emds, mpc8349itx, and gp boards. Boards remain compatible with OF_FLAT_TREE. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-15mpc83xx: move common /memory node update mechanism to cpu.cKim Phillips
also adds common prototypes to include/common.h. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-15mpc83xx: remaining 8360 libfdt fixesKim Phillips
PCI clocks and QE frequencies weren't being updated, and the core clock was being updated incorrectly. This patch also adds a /memory node if it doesn't already exist prior to update. plus some cosmetic trimming to single line comments. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-15mpc83xx: fix UEC2->1 typo in libfdt setup codeKim Phillips
2007-08-10mpc83xx: Suppress the warning 'burstlen'Dave Liu
suppress the warning 'burstlen' of spd_sdram. Signed-off-by: Dave Liu <daveliu@freescale.com>
2007-08-10mpc83xx: Consolidate the ECC support of 83xxDave Liu
Remove the duplicated source code of ecc command on the <board>.c, for reused, move these code to cpu/mpc83xx directory. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-10mpc83xx: Correct the burst length for DDR2 with 32 bitsDave Liu
The burst length should be 4 for DDR2 with 32 bits bus Signed-off-by: Dave Liu <daveliu@freescale.com>
2007-08-10mpc83xx: fixup generic pci for libfdtKim Phillips
add libfdt support to the generic 83xx pci code Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-10mpc83xx: fix 8360 and cpu functions to update fdt being passedKim Phillips
..and not the global fdt. Rename local fdt vars to blob so as not to be confused with the global var with the same three-letter name. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-10mpc83xx: Fix errors when CONFIG_OF_LIBFDT is enabledJerry Van Baren
Several node strings were not correct (trailing slashes and properties in the strings) Added setting of the timebase-frequency. Improved error messages and use debug() instead of printf(). Signed-off-by: Gerald Van Baren <vanbaren@cideas.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-10mpc83xx: Replace fdt_node_offset() with fdt_find_node_by_path().Jerry Van Baren
The new name matches more closely the kernel's name, which is also a much better description. These are the mpc83xx changes made necessary by the function name change. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Acked-by: Gerald Van Baren <vanbaren@cideas.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-10mpc83xx: Add support for the display of reset statusDave Liu
83xx processor family has many reset sources, such as power on reset, software hard reset, software soft reset, JTAG, bus monitor, software watchdog, check stop reset, external hard reset, external software reset. sometimes, to figure out the fault of system, we need to know the cause of reset early before the prompt of u-boot present. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-10Update SCCR programming in cpu_init_f() to support all 83xx processorsTimur Tabi
Update the cpu_init_f() function in cpu/mpc83xx/cpu_init.c to program the bitfields for all 83xx processors. The code to update some bitfields was compiled only on some processors. Now, the bitfields are programmed as long as the corresponding CFG_SCCR option is defined in the board header file. This means that the board header file should not define any CFG_SCCR macros for bitfields that don't exist on that processor, otherwise the SCCR will be programmed incorrectly. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-10mpc83xx: Add support for 8360 silicon revision 2.1Lee Nipper
This change adds 8360 silicon revision 2.1 support to u-boot. Signed-off-by: Lee Nipper <lee.nipper@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-07-09cpu/m*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04Correct fixup relocation for mpc83xxGrant Likely
2007-07-04Consolidate mpc83xx linker scriptsGrant Likely
2007-07-04cpu/mpc*/ : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-07-03Merge with /home/wd/git/u-boot/custodian/u-boot-testingWolfgang Denk
2007-06-22[ppc] Fix build breakage for all non-4xx PowerPC variants.Rafal Jaworowski
- adapt to the more generic EXCEPTION_PROLOG and CRIT_EXCEPTION macros - minor 4xx cleanup
2007-05-17Reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECxKim Phillips
For all practical u-boot purposes, TSECs don't differ throughout the mpc8[356]xx families; reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECx. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-05-01Fix memory initialization on MPC8349E-mITXTimur Tabi
Define CFG_DDR_SDRAM_CLK_CNTL for the MPC8349E-mITX and MPC8349E-mITX-GP. This allows ddr->sdram_clk_cntl to be properly initialized. This is necessary on some ITX boards, notably those with a revision 3.1 CPU. Also change spd_sdram() in cpu/mpc83xx/spd_sdram.c to not write anything into ddr->sdram_clk_cntl if CFG_DDR_SDRAM_CLK_CNTL is not defined. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Michael Benedict <MBenedict@twacs.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-05-01mpc83xx: replace elaborate boottime verbosity with 'clocks' commandKim Phillips
and fix CPU: to align with Board: display text. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-04-25mpc83xx: minor fixups for 8313rdb introductionKim Phillips
2007-04-23mpc83xx: Add generic PCI setup code.Scott Wood
Board code can now request the generic setup code rather than having to copy-and-paste it for themselves. Boards should be converted to use this once they're tested with it. Signed-off-by: Scott Wood <scottwood@freescale.com>
2007-04-23mpc83xx: Add 831x support to speed.c.Scott Wood
2007-04-23mpc83xx: Change PVR_83xx to PVR_E300C1-3, and update checkcpu().Scott Wood
Rather than misleadingly define PVR_83xx as the specific type of 83xx being built for, the PVR of each core revision is defined. checkcpu() now prints the core that it detects, rather than aborting if it doesn't find what it thinks it wants. Signed-off-by: Scott Wood <scottwood@freescale.com>
2007-04-23mpc83xx: Recognize SPR values for MPC8311 and MPC8313.Scott Wood
2007-04-23Merge git://www.denx.de/git/u-bootKim Phillips
2007-04-15Fix the ft_cpu_setup() property settings.Gerald Van Baren
Use "setter" functions instead of flags, cleaner and more flexible. It also fixes the problem noted by Timur Tabi that the ethernet MAC addresses were all being set incorrectly to the same MAC address.
