path: root/cpu/mpc83xx
2006-04-20Merged MPC8349ADS and MPC8349EMDS ports into MPC8349EMDS port:Kumar Gala
- Removed MPC8349ADS port - Added PCI support to MPC8349ADS - reworked memory map to allow mapping of all regions with BATs Patch by Kumar Gala 20 Apr 2006 Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-04-16Some code cleanupWolfgang Denk
2006-03-16Support for DDR with 32-data path. Addotional notes on injectingRafal Jaworowski
multiple-bit errors.
2006-03-14Add support for ECC DDR initialization on MPC83xx.Marian Balakowicz
2006-03-14Add DMA support for MPC83xx.Marian Balakowicz
2006-03-14Add sync in do_reset() routine for MPC83xx after RPR registerMarian Balakowicz
was written to. It is need on some targets when BAT translation is enabled.
2006-03-14Add Dcbz(), Dcbi() and Dcbf() routines for MPC83xx.Marian Balakowicz
2006-03-14Correct shift offsets in icache_status and dcache_status for MPC83xx.Marian Balakowicz
2006-03-12Merge with git://git.kernel.org/pub/scm/boot/u-boot/u-boot.git#mpc83xxWolfgang Denk
2006-02-10Enable address translation on MPC83xxKumar Gala
Patch by Kumar Gala, 10 Feb 2006
2006-01-25Decopuled setting of OR/BR and LBLAWBAR/LBLAWAR on MPC83xxKumar Gala
Patch by Kumar Gala, 25 Jan 2006
2006-01-11Add helper function for generic flat device tree fixups for mpc83xxKumar Gala
Patch by Kumar Gala 11 Jan 2006
2006-01-11Only disable the MPC83xx watchdog if its enabled out of reset.Kumar Gala
If its disabled out of reset SW can later enable it if so desired Patch by Kumar Gala, 11 Jan 2006
2006-01-11Allow config of GPIO direction & data registers at boot on 83xxKumar Gala
2006-01-11Enable time handling on 83xxKumar Gala
2006-01-11Make System IO Config Registers board configurable on MPC83xxKumar Gala
2005-12-04Code cleanup, especially MIPS for GCC 4.xWolfgang Denk
2005-10-17Add PCI support for the TQM834x board.Rafal Jaworowski
2005-10-15Merge with /home/m8/git/u-bootWolfgang Denk
2005-10-11Added support for TQM834x boards.Marian Balakowicz
2005-08-05Fix compiler warningsWolfgang Denk
2005-08-01Fix style issues primarily in 85xx and 83xx boards.Jon Loeliger
- C++ comments - Trailing white space - Indentation not by TAB - Excessive amount of empty lines - Trailing empty lines
2005-07-28* Patch by Eran LibertyEran Liberty
Add support for the Freescale MPC8349ADS board.
