path: root/cpu/mpc83xx/traps.c
2007-07-09cpu/m*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04cpu/mpc*/ : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-11-28mpc83xx: Miscellaneous code style fixesTimur Tabi
Implement various code style fixes and similar changes. Signed-off-by: Timur Tabi <timur@freescale.com>
2005-07-28* Patch by Eran LibertyEran Liberty
Add support for the Freescale MPC8349ADS board.
