path: root/cpu/mpc83xx/fdt.c
2008-10-18Adds two more ethernet interface to 83xxrichardretanubun
Added as a convenience for other platforms that uses MPC8360 (has 8 UCC). Six eth interface is chosen because the platform I am using combines UCC1&2 and UCC3&4 as 1000 Eth and the other four UCCs as 10/100 Eth. Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-21fdt: rework fdt_fixup_ethernet() to use env instead of bd_tKumar Gala
Move to using the environment variables 'ethaddr', 'eth1addr', etc.. instead of bd->bi_enetaddr, bi_enet1addr, etc. This makes the code a bit more flexible to the number of ethernet interfaces. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-148xxx-fdt: set ns16550 clock from CFG_NS16550_CLK, not bi_busfreqPaul Gortmaker
Some boards that have external 16550 UARTs don't have a direct tie between bi_busfreq and the clock used for the UARTs. Boards that do have such a tie should set CFG_NS16550_CLK to be get_bus_freq(0) -- which most of them do already. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2008-07-14fdt: add crypto node handling for MPC8{3, 5}xxE processorsKim Phillips
Delete the crypto node if not on an E-processor. If on 8360 or 834x family, check rev and up-rev crypto node (to SEC rev. 2.4 property values) if on an 'EA' processor, e.g. MPC8349EA. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-04-25mpc83xx: remove the unused CPM's stuffDave Liu
The MPC83xx family never have CPM block, so remove it from 83xx. Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-03-25mpc83xx: add "fsl,soc" and "fsl,immr" compatible fixupsAnton Vorontsov
device_type = "soc" is being deprecated, newer device trees will use "fsl,soc" and/or "fsl,immr" for the soc nodes. This patch also adds clock-frequency property for soc nodes (the same value as bus-frequency). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2008-03-2583xx: split COBJS onto separate linesAnton Vorontsov
..plus get rid of some #ifdefs in the .c files. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2008-02-12QE: Move FDT support into a common fileKumar Gala
Move the flat device tree setup for QE related devices into a common file shared between 83xx & 85xx platforms that have QE's. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-10mpc83xx: add "fsl, qe" compatible fixupsAnton Vorontsov
New device trees will use "fsl,qe" compatible properties. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-08mpc83xx: convert to using do_fixup_*()Kim Phillips
convert to using simpler mpc85xx style fdt update code; streamline by eliminating macros OF_SOC, OF_CPU, etc. which allows us to rm the old school FLAT_TREE code from 83xx (since the sbc8349 was just converted over to using libfdt). Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
