path: root/cpu/mpc83xx/Makefile
2008-03-2583xx: serdes setup routinesAnton Vorontsov
This patch adds few routines to configure serdes on 837x targets. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2008-03-2583xx: split COBJS onto separate linesAnton Vorontsov
..plus get rid of some #ifdefs in the .c files. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2008-01-08mpc83xx: convert to using do_fixup_*()Kim Phillips
convert to using simpler mpc85xx style fdt update code; streamline by eliminating macros OF_SOC, OF_CPU, etc. which allows us to rm the old school FLAT_TREE code from 83xx (since the sbc8349 was just converted over to using libfdt). Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-10mpc83xx: Consolidate the ECC support of 83xxDave Liu
Remove the duplicated source code of ecc command on the <board>.c, for reused, move these code to cpu/mpc83xx directory. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-04-23mpc83xx: Add generic PCI setup code.Scott Wood
Board code can now request the generic setup code rather than having to copy-and-paste it for themselves. Boards should be converted to use this once they're tested with it. Signed-off-by: Scott Wood <scottwood@freescale.com>
2006-11-03mpc83xx: Update 83xx to use fsl_i2c.cTimur Tabi
Update the 83xx tree to use I2C support in drivers/fsl_i2c.c. Delete cpu/mpc83xx/i2c.c, include/asm-ppc/i2c.h, and all references to those files. Added multiple I2C bus support to fsl_i2c.c. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-11-03mpc83xx: add QE ethernet supportDave Liu
this patch adds support for the QUICC Engine based UCC gigabit ethernet device.
2006-11-03mpc83xx: Removed unused file resetvec.S for mpc83xx cpuTanya Jiang
Removed unused file resetvec.S for mpc83xx cpu Signed-off-by: Tanya Jiang <tanya.jiang@freescale.com>
2006-10-09Coding style cleanupWolfgang Denk
2005-10-17Add PCI support for the TQM834x board.Rafal Jaworowski
2005-07-28* Patch by Eran LibertyEran Liberty
Add support for the Freescale MPC8349ADS board.
