path: root/cpu/mpc8260/i2c.c
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-06-12i2c: Create common default i2c_[set|get]_bus_speed() functionsPeter Tyser
New default, weak i2c_get_bus_speed() and i2c_set_bus_speed() functions replace a number of architecture-specific implementations. Also, providing default functions will allow all boards to enable CONFIG_I2C_CMD_TREE. This was previously not possible since the tree-form of the i2c command provides the ability to display and modify the i2c bus speed which requires i2c_[set|get]_bus_speed() to be present. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-12i2c.h: Provide a default CONFIG_SYS_I2C_SLAVE valuePeter Tyser
Many boards/controllers/drivers don't support an I2C slave interface, however CONFIG_SYS_I2C_SLAVE is used in common code so provide a default Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-15i2c: merge all i2c_reg_read() and i2c_reg_write() into inline functionsTimur Tabi
All implementations of the functions i2c_reg_read() and i2c_reg_write() are identical. We can save space and simplify the code by converting these functions into inlines and putting them in i2c.h. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-By: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-12-09Section name should be ".data", not "data"Trent Piepho
Signed-off-by: Trent Piepho <tpiepho@freescale.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-18I2C: adding new "i2c bus" Command to the I2C Subsystem.Heiko Schocher
With this Command it is possible to add new I2C Busses, which are behind 1 .. n I2C Muxes. Details see README. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-10-18i2c: add CONFIG_I2C_MULTI_BUS for soft_i2c and mpc8260 i2c driver.Heiko Schocher
2004-10-10* Patch by Gridish Shlomi, 30 Aug 2004:wdenk
- Add support to revA version of PQ27 and PQ27E. - Reverted MPC8260ADS baudrate back to original 115200 * Patch by Hojin, 17 Sep 2004: Fix typo in cfi_flash.c * Patch by Mark Jonas, 09 September 2004: mtest's data line test (with CFG_ALT_MEMTEST set) returned a wrong error message * Patch by Mark Jonas, 31 August 2004: Added option CFG_XLB_PIPELINING to enable XLB pipelining. This improves FTP performance for MPC5200 systems. Enabled for IceCube by default.
2003-06-19Patches by Murray Jensen, 17 Jun 2003:wdenk
- Hymod board database mods: add "who" field and new xilinx chip types - provide new "init_cmd_timeout()" function so code external to "common/main.c" can use the "reset_cmd_timeout()" function before entering the main loop - add DTT support for adm1021 (new file dtt/adm1021.c; config slightly different. see include/configs/hymod.h for an example (requires CONFIG_DTT_ADM1021, CONFIG_DTT_SENSORS, and CFG_DTT_ADM1021 defined) - add new "eeprom_probe()" function which has similar args and behaves in a similar way to "eeprom_read()" etc. - add 8260 FCC ethernet loopback code (new "eth_loopback_test()" function which is enabled by defining CONFIG_ETHER_LOOPBACK_TEST) - gdbtools copyright update - ensure that set_msr() executes the "sync" and "isync" instructions after the "mtmsr" instruction in cpu/mpc8260/interrupts.c - 8260 I/O ports fix: Open Drain should be set last when configuring - add SIU IRQ defines for 8260 - allow LDSCRIPT override and OBJCFLAGS initialization: change to config.mk to allow board configurations to override the GNU linker script, selected via the LDSCRIPT, make variable, and to give an initial value to the OBJCFLAGS make variable - 8260 i2c enhancement: o correctly extends the timeout depending on the size of all queued messages for both transmit and receive o will not continue with receive if transmit times out o ensures that the error callback is done for all queued tx and rx messages o correctly detects both tx and rx timeouts, only delivers one to the callback, and does not overwrite an earlier error o logic in i2c_probe now correct - add "vprintf()" function so that "panic()" function can be technically correct - many Hymod board changes
2003-03-06* Patches by Robert Schwebel, 06 Mar 2003:wdenk
- fix bug in BOOTP code (must use NetCopyIP) - update of CSB226 port - clear BSS segment on XScale - added support for i2c_init_board() function - update to the Innokom plattform * Extend support for redundand environments for configurations where environment size < sector size
