path: root/cpu/mpc5xxx
2006-06-16Add support for CONFIG_SERIAL_MULTI on MPC5xxxWolfgang Denk
Patch by Martin Krause, 8 Jun 2006 This patch supports two serial consoles on boards with a MPC5xxx CPU. The console can be switched at runtime by setting stdin, stdout and stderr to the desired serial interface (serial0 or serial1). The PSCs to be used as console port are definded by CONFIG_PSC_CONSOLE and CONFIG_PSC_CONSOLE2. See README.serial_multi for details.
2006-04-18MPC5200: enable snooping of DMA transactions on XLB even if no PCILABEL_2006_04_18_1106Wolfgang Denk
is configured; othrwise DMA accesses aren't cache coherent which causes for example USB to fail.
2006-04-16Some code cleanupWolfgang Denk
2006-04-06Fix Lite500B support: Merge with /home/raj/git/u-boot.l5200b_pciWolfgang Denk
2006-03-29Set SDelay register in the DDR controller for the MPC5200B chip.Rafal Jaworowski
2006-02-22Initial port to MCC200 board (work in progress)Wolfgang Denk
Minimally modified patch by Bluetechnix, Vienna
2005-12-16MPC5200: Set PCI retry counter to 0 = infinite retry;Wolfgang Denk
The default of 255 is too short for slow devices. Patch by Martin Nykodym, 12 Dec 2005
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-09-25Fix MGT5100 PSC baudrate calculationWolfgang Denk
Patch by Sebastian Schau, 27 Jan 2005
2005-09-04Update MPC5200 FIFO Control settingsWolfgang Denk
(u-boot.habanero.fifo_cntrl.patch from Freescale)
2005-08-22Add esd cpci5200 and pf5200 boardsStefan Roese
Patch by Reinhard Arlt, 22 Aug 2005
2005-08-09Added support for O2DNT board.
2005-08-02Coding style cleanupWolfgang Denk
2005-07-21Fix low-level OHCI transfers for ARM920t and MPC5xxxWolfgang Denk
A new, Windows compatible init sequence was also backported from Linux 2.6, but disabled with #undef NEW_INIT_SEQ as it wouldn't change the behaviour of the memopry sticks we tested. Maybe it's not relevant for mass storage devices. For recerence, see file common/usb.c, function usb_new_device(), section #ifdef NEW_INIT_SEQ.
2005-06-27* Fix baudrate calculation problem on MPC5200 systemswdenk
* Add MPC8220 boards to MAKEALL script * Add EEPROM and RTC support for HMI1001 board * Patch by Detlev Zundel, 20 Jun 2005: Fix initialization of low active GPIO pins on inka4x0 board
2005-06-10* Add support for HMI1001 boardwdenk
* Disable "date" and "sntp" commands on TQM866M which has no RTC
2005-04-13Add support for canmb boardLABEL_2005_04_14_0115wdenk
2005-03-14* Patch by David Brownell, 10 Mar 2005:wdenk
Restore copyright statements in OHCI drivers. * Add support for TQM8540 board
2005-02-24* Add support for ext2 filesystems and image timestamps to TQM5200 boardwdenk
* Add reset code for Coral-P on INKA4x0 board * Patch by Martin Krause, 28 Jun 2004: Update for TRAB board. * Fix some missing "volatile"s in MPC5xxx FEC driver
2004-12-16Add support for INKA4X0 boardwdenk
2004-10-10* Patch by Gridish Shlomi, 30 Aug 2004:wdenk
- Add support to revA version of PQ27 and PQ27E. - Reverted MPC8260ADS baudrate back to original 115200 * Patch by Hojin, 17 Sep 2004: Fix typo in cfi_flash.c * Patch by Mark Jonas, 09 September 2004: mtest's data line test (with CFG_ALT_MEMTEST set) returned a wrong error message * Patch by Mark Jonas, 31 August 2004: Added option CFG_XLB_PIPELINING to enable XLB pipelining. This improves FTP performance for MPC5200 systems. Enabled for IceCube by default.
2004-07-12Patch by Mark Jonas, 02 Jul 2004:wdenk
Fix lowboot (again) on MPC5xxx
2004-07-11Patch by Mark Jonas, 01 Jul 2004:wdenk
Added support for Total5100 and Total5200 (Rev.1 and Rev.2) MGT5100 and MPC5200 based Freescale platforms.
2004-07-11* Patch by Martin Krause, 30 Jun 2004:wdenk
Add support for TQM5200 board * Patch by Martin Krause, 29 Jun 2004: Add loopw command: infinite write loop on address range
2004-06-09* Patch by Mark Jonas, 08 June 2004:wdenk
- Make MPC5200 boards evaluate the SVR to print processor name and version in checkcpu() (cpu/mpc5xxx/cpu.c). * Patch by Kai-Uwe Bloem, 06 May 2004: Fix endianess problem in cramfs code
2004-06-09* Patch by Martin Krause, 27 May 2004:wdenk
Fix a MPC5xxx I2C timing issue in i2c_probe(). * Patch by Leif Lindholm, 27 May 2004: Fix board_init_f() for dbau1x00 board.
2004-05-12Fix minor network problem on MPC5200wdenk
2004-04-18* Temporarily disabled John Kerl's extended MII command code becausewdenk
"miivals.h" is missing * Patches by Mark Jonas, 13 Apr 2004: - Remove CS0 chip select timing setting from cpu/mpc5xxx/start.S - Add sync instructions to IceCube SDRAM init code - Move SDRAM chip constants into seperate include files - Unify DDR and SDR initialization code - Unify all IceCube (Lite5xxx) target names
2004-04-08* Patch by Mark Jonas: Remove config.tmp files only whenwdenk
unconfiguring the board * Adapt RMU board for bigger flash memory * Test fix for ethernet problems on MPC5200
2004-03-23* Patch by Phillippe Robin, 16 Mar 2004:wdenk
avoid dereferencing NULL pointer in lib_arm/armlinux.c * Patch by Stephen Williams, 15 Mar 2004: Fix CONFIG_SERIAL_SOFTWARE_FIFO documentation * Patch by Tolunay Orkun, 15 Mar 2004: Initialize bi_opbfreq to real OPB frequency via get_OPB_freq() * Patch by Travis Sawyer, 15 Mar 2004: Update CREDITS & MAINTAINERS files for PPC440GX & Ocotea port
2004-03-23* Add start-up delay to make sure power has stabilized beforewdenk
attempting to switch on USB on SX1 board. * Patch by Josef Wagner, 18 Mar 2004: - Add support for MicroSys XM250 board (PXA255) - Add support for MicroSys PM828 board (MPC8280) - Add support for 32 MB Flash on PM825/826 - new SDRAM refresh rate for PM825/PM826 - added support for MicroSys PM520 (MPC5200) - replaced Query by Identify command in CPU86/flash.c to support 28F160F3B * Fix wrap around problem with udelay() on ARM920T * Add support for Macronix flash on TRAB board
2004-03-14Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340wdenk
2004-03-14* Patch by Tolunay Orkun, 5 Mar 2004:wdenk
Fix early board initialization for Cogent CSB272 board * Patch by Ed Okerson, 3 Mar 2004: fix CFI flash writes for little endian systems * Patch by Reinhard Meyer, 01 Mar 2004: generalize USB and IDE support for MPC5200 with according changes to IceCube.h and TOP5200.h add Am29LV256 256 MBit FLASH support for TOP5200 boards add info about USB and IDE to README
2004-03-14* Patch by Yuli Barcohen, 4 Mar 2004:wdenk
Fix problems with GCC 3.3.x which changed handling of global variables explicitly initialized to zero (now in .bss instead of .data as before). * Patch by Leon Kukovec, 02 Mar 2004: add strswab() to fix IDE LBA capacity, firmware and model numbers on little endian machines * Patch by Masami Komiya, 02 Mar 2004: - Remove get_ticks() from NFS code - Add verification of RPC transaction ID * Patch by Pierre Aubert, 02 Mar 2004: cleanup for IDE and USB drivers for MPC5200
2004-03-11Fix LOWBOOT configuration for MPC5200 with DDR memorywdenk
2004-02-27* Patch by Pierre Aubert, 26 Feb 2004wdenk
add IDE support for MPC5200 * Patch by Masami Komiya, 26 Feb 2004: add autoload via NFS * Patch by Stephen Williams Use of CONFIG_SERIAL_SOFTWARE_FIFO in board.c consistent with uses elsewhere in the source.
2004-02-26* Patch by Markus Pietrek, 24 Feb 2004:wdenk
NS9750 DevBoard added * Patch by Pierre AUBERT, 24 Feb 2004 add USB support for MPC5200 * Patch by Steven Scholz, 24 Feb 2004: - fix MII commands to use values from last command * Patch by Torsten Demke, 24 Feb 2004: Add support for the eXalion platform (SPSW-8240, F-30, F-300)
2004-02-24* Patch by Masami Komiy, 22 Feb 2004:wdenk
Add support for NFS for file download * Minor code cleanup
2004-02-23* Patches by Reinhard Meyer, 14 Feb 2004:wdenk
- update board/emk tree; use common flash driver - Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c [adapted for other PPC CPUs -- wd] - Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c * Patch by Jon Diekema, 13 Feb 2004: Call show_boot_progress() whenever POST "FAILED" is printed. * Patch by Nishant Kamat, 13 Feb 2004: Add support for TI OMAP1610 H2 Board Fixes for cpu/arm926ejs/interrupt.c (based on Richard Woodruff's patch for arm925, 16 Oct 03) Fix for a timer bug in OMAP1610 Innovator Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2 * Patches by Stephan Linz, 12 Feb 2004: - add support for NIOS timer with variable period preload counter value - prepare POST framework support for NIOS targets * Patch by Denis Peter, 11 Feb 2004: add POST support for the MIP405 board
2004-02-22* Patch by Travis Sawyer, 09 Feb 2004:wdenk
o 440GX: - Fix PCI Indirect access for type 1 config cycles with ppc440. - Add phymode for 440 enet - fix pci pre init o XPedite1K: - Change board_pre_init to board_early_init_f - Add user flash to bus controller setup - Fix pci pre init - Fix is_pci_host to check GPIO for monarch bit - Force xpedite1k to pci conventional mode (via #define option) * Patch by Brad Kemp, 4 Feb 2004: - handle the machine check that is generated during the PCI scans on 82xx processors. - define the registers used in the IMMR by the PCI subsystem. * Patch by Pierre Aubert, 03 Feb 2004: cpu/mpc5xxx/start.S: copy MBAR into SPR311 * Patch by Jeff Angielski, 03 Feb 2004: Fix copy & paste error in cpu/mpc8260/pci.c * Patch by Reinhard Meyer, 24 Jan 2004: Fix typo in cpu/mpc5xxx/pci_mpc5200.c
2004-02-09* Patch by Rahul Shanbhag, 28 Jan 2004:wdenk
Fix flash protection/locking handling for OMAP1610 innovator board. * Patch by Rolf Peukert, 28 Jan 2004: fix flash write problems on CSB226 board (write with 32 bit bus width) * Patches by Mark Jonas, 16 Jan 2004: - fix rounding error when calculating baudrates for MPC5200 PSCs - make sure CFG_RAMBOOT and CFG_LOWBOOT are not enabled at the same time which is not supported
2004-01-02* Cleanup lowboot code for MPC5200wdenk
* Minor code cleanup (coding style) * Patch by Reinhard Meyer, 30 Dec 2003: - cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE, - added CONFIG_PHY_ADDR to include/configs/IceCube.h, - turned debug print of PHY registers into a function (called in two places) - added support for EMK MPC5200 based modules * Fix MPC8xx PLPRCR_MFD_SHIFT typo * Add support for TQM866M modules * Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash) * Fix a few compiler warnings
2003-12-27* Make CPU clock on ICA-IP board controllable by a "cpuclk"wdenk
environment variable which can set to "100", "133", or "150". The CPU clock will be configured accordingly upon next reboot. Other values are ignored. In case of an invalid or undefined "cpuclk" value, the compile-time default CPU clock speed will be used. * Enable Quad-UART on BMS2003 board (initialize the PCMCIA memory window that is used to access the UART registers by the Linux driver) * Patch by Reinhard Meyer, 20 Dec 2003: Fix clock calculation for the MPC5200 for higher clock frequencies (above 2**32 / 10 = 429.5 MHz).
2003-12-06* Patch by Gleb Natapov, 19 Sep 2003:wdenk
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c * Patch by Anders Larsen, 17 Sep 2003: Bring ARM memory layout in sync with the documentation: stack and malloc-heap are now located _below_ the U-Boot code
2003-11-17* Use "-fPIC" instead of "-mrelocatable" to prevent problems withwdenk
recent tools * Add checksum verification to 'imls' command * Add bd_info fields needed for 4xx Linux I2C driver * Patch by Martin Krause, 4 Nov. 2003: Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap) * Print used network interface when CONFIG_NET_MULTI is set
2003-11-07* Patch by Bernhard Kuhn, 28 Oct 2003:wdenk
Add low boot support for MPC5200 * Fix problem with dual PCMCIA support (NSCU) * Fix MPC5200 I2C initialization function
2003-10-14* Make sure HUSH is initialized for running auto-update scriptsLABEL_2003_10_14_2140wdenk
* Make 5200 reset command _really_ reset the board, without running any other code after it * Fix flash mapping and display on P3G4 board * Patch by Kyle Harris, 15 Jul 2003: - add support for Intel IXP425 CPU - add support for IXDP425 eval board
