path: root/cpu/mpc5xxx
2003-09-13* Patch by David Müller, 13 Sep 2003:LABEL_2003_09_13_2100wdenk
various changes to VCMA9 board specific files * Add I2C support for MGT5100 / MPC5200
2003-09-05* Add support for SK98xx driverLABEL_2003_09_06_0055wdenk
* Add PCI support for SL8245 board * Support IceCube board configurations with 1 x AMD AM29LV065 (8 MB) or 1 x AM29LV652 (two LV065 in one chip = 16 MB); Run IPB at 133 Mhz; adjust the MII clock frequency accordingly * Set BRG_CLK on PM825/826 to 64MHz (VCO_OUT / 4, instead of 16 MHz) to allow for more accurate baudrate settings (error now 0.7% at 115 kbps, instead of 3.5% before) * Patch by Andreas Mohr, 4 Sep 2003: Fix a lot of spelling errors
2003-09-02* Add support for PPChameleon Eval Boardwdenk
* Add support for P3G4 board * Fix problem with MGT5100 FEC driver: add "early" MAC address initialization
2003-08-28* Fix ICU862 environment problemwdenk
* Fix RAM size detection for RMU board * Implement "reset" for MGT5100/MPC5200 systems
2003-08-17* Make Ethernet autonegotiation on INCA-IP work for all clock rates;U-Boot-0_4_6wdenk
allow selection of clock frequency as "make" target * Implement memory autosizing code for IceCube boards * Configure network port on INCA-IP for autonegotiation * Fix overflow problem in network timeout code * Patch by Richard Woodruff, 8 Aug 2003: Allow crc32 to be used at address 0x000 (crc32_no_comp, too).
2003-08-07Disable debug print for normal use.wdenk
Fix MPC5200 FEC driver
2003-08-05* Fix PCI support for MPC5200 / IceCube Boardwdenk
2003-07-31Must enable timebase earlier on MPC5200wdenk
2003-07-26* Allow crc32 to be used at address 0x000wdenk
* Provide consistent interface to standalone applications to access the 'global_data' structure Provide a doc/README.standalone more useful to users/developers. * Make IceCube MGT5100 FEC driver work
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-07-16* Add support for IceCube board (with MGT5100 and MPC5200 CPUs)U-Boot-0_4_4wdenk
