path: root/cpu/mpc5xx/config.mk
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-01-26ppc: remove -ffixed-r14 gcc option.Joakim Tjernlund
This is no loger needed, free up r14 for general usage. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2008-02-14PPC: Use r2 instead of r29 as global data pointerWolfgang Denk
R29 was an unlucky choice as with recent toolchains (gcc-4.2.x) gcc will refuse to use load/store multiple insns; instead, it issues a list of simple load/store instructions upon function entry and exit, resulting in bigger code size, which in turn makes the build for a few boards fail. Use r2 instead. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-11-15Revert "Correct relocation fixup for mpc5xx"Grant Likely
This reverts commit 3649cd99ba815b6601868735765602f00ef3692b. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-07-04Correct relocation fixup for mpc5xxGrant Likely
2007-07-04Consolidate mpc5xx linker scriptsGrant Likely
2003-11-17* Use "-fPIC" instead of "-mrelocatable" to prevent problems withwdenk
recent tools * Add checksum verification to 'imls' command * Add bd_info fields needed for 4xx Linux I2C driver * Patch by Martin Krause, 4 Nov. 2003: Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap) * Print used network interface when CONFIG_NET_MULTI is set
2003-03-31* Patch by Martin Winistoerfer, 23 Mar 2003wdenk
- Add port to MPC555/556 microcontrollers - Add support for cmi customer board with Intel 28F128J3A, 28F320J3A or 28F640J3A flash. * Patch by Rick Bronson, 28 Mar 2003: - fix common/cmd_nand.c
