path: root/cpu/mpc512x/cpu_init.c
2009-06-12MPC512x: remove include/mpc512x.hWolfgang Denk
Move needed definitions (register descriptions etc.) from include/mpc512x.h into include/asm-ppc/immap_512x.h. Instead of using a #define'd register offset, use a function that provides the PATA controller's base address. All the rest of include/mpc512x.h are register offset definitions which can be eliminated by proper use of C structures. There are only a few register offsets remaining that are needed in cpu/mpc512x/start.S; for these we provide cpu/mpc512x/asm-offsets.h which is intended as a temporary workaround only. In a later patch this file will be removed, too, and then auto-generated from the respective C structs. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: John Rigby <jcrigby@gmail.com>
2009-06-12MPC512x: use I/O accessors instead of pointer accessesWolfgang Denk
This commit changes the MPC512x code to use I/O accessor calls (i.e. out_*() and in_*()) instead of using deprecated pointer accesses. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: John Rigby <jcrigby@gmail.com>
2007-08-02Coding style cleanup, update CHANGELOGWolfgang Denk
2007-07-27[ADS5121] Support for the ADS5121 boardRafal Jaworowski
The following MPC5121e subsystems are supported: - low-level CPU init - NOR Boot Flash (common CFI driver) - DDR SDRAM - FEC - I2C - Watchdog Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Signed-off-by: Rafal Jaworowski <raj@semihalf.com> Signed-off-by: Jan Wrobel <wrr@semihalf.com>
