We will soon see several new MPC521x based boards added. This patch
moves files that are not board specific to a common directory so they
can be shared by all such ports. It also splits off common IDE code
into a new file, cpu/mpc512x/ide.c .
Cc: John Rigby <jcrigby@gmail.com>
IIM (IC Identification Module) is the fusebox for the mpc5121.
Use #define CONFIG_IIM to turn on the clock for this module
use #define CONFIG_CMD_FUSE to add fusebox commands.
Fusebox commands include the ability to read
the status, read the register cache, override the register cache,
program the fuses and sense them.
Signed-off-by: Martha Marx <mmarx@silicontkx.com>
Signed-off-by: John Rigby <jrigby@freescale.com>
And in the process eliminate some duplicate register defines.
Signed-off-by: Kenneth Johansson <kenneth@southpole.se>
The following MPC5121e subsystems are supported:
- low-level CPU init
- NOR Boot Flash (common CFI driver)
- DDR SDRAM
- FEC
- I2C
- Watchdog
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
Signed-off-by: Jan Wrobel <wrr@semihalf.com>
