path: root/cpu/mips/Makefile
2008-06-07[MIPS] cpu/mips/Makefile: Split [CS]OBJS onto separate linesShinya Kuribayashi
Also get rid of some #ifdefs in *.c files. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2005-09-25Add support for AMD's Pb1x00 eval board;Wolfgang Denk
add MII routines to the au1x00 ethernet driver; add USB ohci driver (work in progress) Patch by Thomas Sailer, 20 Jan 2005
2003-10-09* Patch by Steven Scholz, 10 Oct 2003LABEL_2003_10_09_2320wdenk
- Add support for Altera FPGA ACEX1K * Patches by Thomas Lange, 09 Oct 2003: - Endian swap ATA identity for all big endian CPUs, not just PPC - MIPS only: New option CONFIG_MEMSIZE_IN_BYTES for passing memsize args to linux - add support for dbau1x00 board (MIPS32)
2003-03-27* Add support for MIPS32 4Kc CPUswdenk
* Add support for INCA-IP Board
