path: root/cpu/mcf547x_8x
2009-03-17ColdFire: PLATFORM_CPPFLAGS updates for new compilerTsiChung Liew
Update PLATFORM_CPPFLAGS to accept 4.3.x version of ColdFire compiler. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2009-03-17Coldfire: XL Bus minor fixesarun c
According to coldfire manual data timeout > address time out also use correct macro to program XARB_CFG Signed-off-by: Arun C <arunedarath@mistralsolutions.com>
2009-02-07pci: Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY for clarityKumar Gala
The PCI_REGION_MEMORY and PCI_REGION_MEM are a bit to similar and can be confusing when reading the code. Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY to clarify its used for system memory mapping purposes. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-12-06Update U-Boot's build timestamp on every compilePeter Tyser
Use the GNU 'date' command to auto-generate a new U-Boot timestamp on every compile. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-11-03ColdFire: Relocate FEC's GPIO and mii functions protocolsTsiChung Liew
Place FEC pin assignments in cpu_init.c from platform's mii.c Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-10-21Use strmhz() to format clock frequenciesWolfgang Denk
2008-09-02Introduce netdev.h header file and remove externsBen Warren
This addresses all drivers whose initializers have already been moved to board_eth_init()/cpu_eth_init(). Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-28ColdFire: I2C fix for multiple platformsTsiChung Liew
2008-08-26Moved initialization of MCFFEC Ethernet driver to CPU directoryBen Warren
Added a cpu_eth_init() function to coldfire CPU directories and removed code from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Moved initialization of FSL_MCDMAFEC Ethernet driver to CPU directoryBen Warren
Added a cpu_eth_init() function to cpu/mcf547x_8x directory and removed code from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-07-11ColdFire: Change invalid JMP to BRA caught by new v4e toolchainTsiChung Liew
Signed-off-by: Kurt Mahan <kmahan@freescale.com>
2008-07-11ColdFire: Add -got=single param for new linux v4e toolchainsTsiChung Liew
2008-05-03Revert "ColdFire: Get information from the correct GCC"Wolfgang Denk
This reverts commit b7166e05a513c0806b63b9dfb6f1d77645cede2a (replaced by commit c4e5f52a58d278eebb87f476e353972c5dacea40).
2008-04-30ColdFire: Get information from the correct GCCTsiChung Liew
Signed-off-by: Kurt Mahan <kmahan@freescale.com> Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-03-31ColdFire: Fix alignment issue after CONFIG_IDENT_STRING in start.STsiChung Liew
When the version_string function in start.S is not 4-byte align, it will cause the compiler generates "unaligned opcodes detected in executable segment". This issue affects all ColdFire CPUs. By adding .align 4 after CONFIG_IDENT_STRING, it will pad 0's if it is not aligned. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-01-17ColdFire: Add MCF547x_8x cpu archTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
