path: root/cpu/mcf5445x
2008-05-03Revert "ColdFire: Get information from the correct GCC"Wolfgang Denk
This reverts commit b7166e05a513c0806b63b9dfb6f1d77645cede2a (replaced by commit c4e5f52a58d278eebb87f476e353972c5dacea40).
2008-04-30ColdFire: Get information from the correct GCCTsiChung Liew
Signed-off-by: Kurt Mahan <kmahan@freescale.com> Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-03-31ColdFire: Fix alignment issue after CONFIG_IDENT_STRING in start.STsiChung Liew
When the version_string function in start.S is not 4-byte align, it will cause the compiler generates "unaligned opcodes detected in executable segment". This issue affects all ColdFire CPUs. By adding .align 4 after CONFIG_IDENT_STRING, it will pad 0's if it is not aligned. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-03-31ColdFire: Add dspi and serial flash support for MCF5445xTsiChung Liew
2008-01-17ColdFire: PCI and misc updates for MCF5445xTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
2007-11-07ColdFire: MCF5445x - Update correct RAMBAR and missing linker filesTsiChungLiew
2007-11-07ColdFire: Update cpu flag for 4.2-xx compilerTsiChungLiew
2007-08-16ColdFire: Add M54455EVB for MCF5445xTsiChungLiew
