The CF will call cache functions in lib_m68/cache.c and the
cache settings are defined in platform configuration file.
Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
Reside Ethernet buffer descriptors in SRAM instead of DRAM. Add
CONFIG_SYS_TX_ETH_BUFFER in platform configuration file. Update
DRAM control and SRAM control register setting. Update cache
setting where size does not write to proper region.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Add CPU compile flag -mcpu=53015 in cpu/config.mk
Provide parameter passing to uart_port_config(). Update port
configuration - un-mask it before enable the bits.
Use correct definition for _MASK and _UNMASK. It was combined in
the previous used and causes confusion.
CONFIG_MONITOR_IS_IN_RAM is broken for MCF532x. This patch fixes this
by conditionally
- removing the vector table at the beginning of code
- not overwriting the vector base register
- removing the code to re-set the PLL, which effectively disables
SDRAM access
Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
in cpu/mcf532x/start.S, the function icache_enable enables the cache for
a fixed 32MB region starting at the SDRAM start address; this patch
changes the function to cover the region defined by CONFIG_SYS_SDRAM_SIZE
Signed-off-by: Wolfgang Wegner <w.wegner at astro-kom.de>
Change %08lX to %08X in board.c. Remove unused variable
'oscillator' in mcf5227x/cpu_init.c and 'scm2' in
mcf532x/cpu_init.c. Provide argument type cast in
drivers/dma/MCD_dmaApi.c.
Update PLATFORM_CPPFLAGS to accept 4.3.x version of
ColdFire compiler.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Use the GNU 'date' command to auto-generate a new U-Boot
timestamp on every compile.
The error was caused by the change for strmhz() in cpu.c.
A few of them were one extra close parenthesis.
Place FEC pin assignments in cpu_init.c from platform's
mii.c
This addresses all drivers whose initializers have already
been moved to board_eth_init()/cpu_eth_init().
Added a cpu_eth_init() function to coldfire CPU directories and
removed code from net/eth.c
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
This reverts commit b7166e05a513c0806b63b9dfb6f1d77645cede2a
(replaced by commit c4e5f52a58d278eebb87f476e353972c5dacea40).
Signed-off-by: Kurt Mahan <kmahan@freescale.com>
When the version_string function in start.S is not 4-byte align,
it will cause the compiler generates "unaligned opcodes detected
in executable segment". This issue affects all ColdFire CPUs.
By adding .align 4 after CONFIG_IDENT_STRING, it will pad 0's if
it is not aligned.
Acked-by: John Rigby <jrigby@freescale.com>
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
Signed-off by: John Rigby <jrigby@freescale.com>
from cpu_init() to uart_gpio_conf()
Enabled cache in cpu_init_f() for faster flash to mem allocation. Updated cache handling in start.S. Applied cache invalidate in fec_send() and fec_recv(). Added CFG_UNIFY_CACHE for CF V3 only.
Signed-off-by: TsiChung <tcliew@Goku.(none)>
interrupt_init() and dtimer_intr_setup() are placed in interrupts.c. Added interrupts.o to Makefile
Replaced immap_5329.h and m5329.h with immap.h. Removed whitespaces.
Replaced immap_5329.h and m5329.h with immap.h. Enabled icache_enable() in cpu_init_r().
Replace immap_5329.h and m5329.h with immap.h. Removed interrupt_init() and placed it in interrupts.c
Added board/freescale/m5329evb, cpu/mcf532x, drivers/net,
drivers/serial, immap_5329.h, m5329.h, mcfrtc.h,
include/configs/M5329EVB.h, lib_m68k/interrupts.c, and
rtc/mcfrtc.c
Modified CREDITS, MAKEFILE, Makefile, README, common/cmd_bdinfo.c,
common/cmd_mii.c, include/asm-m68k/byteorder.h, include/asm-m68k/fec.h,
include/asm-m68k/io.h, include/asm-m68k/mcftimer.h,
include/asm-m68k/mcfuart.h, include/asm-m68k/ptrace.h,
include/asm-m68k/u-boot.h, lib_m68k/Makefile, lib_m68k/board.c,
lib_m68k/time.c, net/eth.c and rtc/Makefile
