path: root/cpu/mcf52x2
2010-04-13m68k: Move cpu/$CPU to arch/m68k/cpu/$CPUPeter Tyser
2010-03-24ColdFire: Cache update for all platformsTsiChung Liew
The CF will call cache functions in lib_m68/cache.c and the cache settings are defined in platform configuration file. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2010-03-24ColdFire: Update processors' serial port configurationTsiChung Liew
Provide parameter passing to uart_port_config(). Update port configuration - un-mask it before enable the bits. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2010-03-24ColdFire: Correct bit definitionTsiChung Liew
Use correct definition for _MASK and _UNMASK. It was combined in the previous used and causes confusion. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2010-03-24Adding EP2500 MCF5282 board [PATCH]Michael Durrant
Mercury-EP2500.patch - added Mercury's EP2500 board uses the mcf5282 processor CREDITS.patch Signed-off-by: David Wu <davidwu@arcturusnetworks.com> Signed-off-by: Michael Durrant <mdurrant@arcturusnetworks.com>
2010-03-04MCF5271-only: Added a weak board_reset function to allow custom resetRichard Retanubun
This patch adds a board_reset function to allow boards to specify their own custom reset sequence (e.g. resetting by timing out watchdog). Tested only on MCF5271, can be expanded if needed. Based on Mike Frysinger's suggestion on: http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70304 Signed-off-by: Richard Retanubun <RichardRetanubun at RuggedCom.com>
2009-07-14ColdFire: Add M5208EVB and MCF520x CPU supportTsiChung Liew
2009-03-17ColdFire: PLATFORM_CPPFLAGS updates for new compilerTsiChung Liew
Update PLATFORM_CPPFLAGS to accept 4.3.x version of ColdFire compiler. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2009-02-06Coldfire: M5271: Allow board header file to specify clock multiplierRichard Retanubun
M5271 dynamic clock multiplier. It is currently fixed at 100MHz. Allow the board header file to set their own multiplier and divider. Added the #define for the multiplier and divider to the cpu header file. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
2009-02-06Coldfire: M5271EVB: Remove usage of CONFIG_SYS_FECI2CRichard Retanubun
Discontinue the use of CONFIG_SYS_FECI2C (only used by M5271EVB). Use read-modify-write to activate the FEC pins without disabling I2C. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
2009-02-06Coldfire: Fix half-baud UART by adding M5271 to Coldfire v2 core listRichard Retanubun
Added the CONFIG_M5271 to the list of Coldfire V2 processor. This was causing the bus clock (not CPU clock) to be declared twice as fast as it actually is. This causes UARTS to operate at half the specified baudrate. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
2008-12-16Coding style cleanup, update CHANGELOG.Wolfgang Denk
2008-12-06Update U-Boot's build timestamp on every compilePeter Tyser
Use the GNU 'date' command to auto-generate a new U-Boot timestamp on every compile. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-11-03ColdFire: Relocate FEC's GPIO and mii functions protocolsTsiChung Liew
Place FEC pin assignments in cpu_init.c from platform's mii.c Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-11-03ColdFire: Modules header files cleanupTsiChung Liew
Consolidate ATA, ePORT, QSPI, FlexCan, PWM, RNG, MDHA, SKHA, INTC, and FlexBus structures and definitions in immap_5xxx.h to more unify modules header files. Append DSPI support for m547x_8x. SSI cleanup. Remove USB Host structure from immap_539.h. Apply changes to use FlexBus structures in mcf52x2's cpu_init.c and platform configuration files. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-09-13Coding style cleanup, update CHANGELOGWolfgang Denk
2008-09-02Introduce netdev.h header file and remove externsBen Warren
This addresses all drivers whose initializers have already been moved to board_eth_init()/cpu_eth_init(). Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-28ColdFire: I2C fix for multiple platformsTsiChung Liew
2008-08-26Moved initialization of MCFFEC Ethernet driver to CPU directoryBen Warren
Added a cpu_eth_init() function to coldfire CPU directories and removed code from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-14ColdFire: Multiple fixes for M5282EVBTsiChung Liew
Incorrect CFG_HZ value, change 1000000 to 1000. Rename #waring to #warning. RAMBAR1 uses twice in start.S, rename the later to FLASHBAR. Insert nop for DRAM setup. And, env_offset in linker file. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-07-11ColdFire: Fix FB CS not setup properly for Mcf5282TsiChung Liew
Remove all CFG_CSn_RO in cpu/mcf52x2/cpu_init.c. If CFG_CSn_RO is defined as 0, the chipselect will not be assigned. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-07-11ColdFire: Fix compiling error for MCF5275TsiChung Liew
The compiling error was caused by missing a closed parentheses in speed.c Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-05-03Revert "ColdFire: Get information from the correct GCC"Wolfgang Denk
This reverts commit b7166e05a513c0806b63b9dfb6f1d77645cede2a (replaced by commit c4e5f52a58d278eebb87f476e353972c5dacea40).
2008-04-30ColdFire: Get information from the correct GCCTsiChung Liew
Signed-off-by: Kurt Mahan <kmahan@freescale.com> Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-04-13Coding Style cleanup; update CHANGELOGWolfgang Denk
2008-03-31ColdFire: Fix alignment issue after CONFIG_IDENT_STRING in start.STsiChung Liew
When the version_string function in start.S is not 4-byte align, it will cause the compiler generates "unaligned opcodes detected in executable segment". This issue affects all ColdFire CPUs. By adding .align 4 after CONFIG_IDENT_STRING, it will pad 0's if it is not aligned. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-03-31ColdFire: Remove R5200 boardTsiChung Liew
This board never went into production Signed-off-by: Zachary P. Landau <zachary.landau@labxtechnologies.com> Acked-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-03-31ColdFire: Added MCF5275 cpu support.Matthew Fettke
Signed-off-by: Matthew Fettke <mfettke@videon-central.com> Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-03-31ColdFire: Update correct FLASHBAR and RAMBAR1 for MCF5282TsiChung Liew
2008-02-23cpu/mcf52x2/config.mk: Make needlessly deffered expansions immediate.Shinya Kuribayashi
This will reduce the build time. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-02-20ColdFire: Fix 5282 and 5271 interrupt mask bitTsiChungLiew
2007-11-07ColdFire: Update cpu flag for 4.2-xx compilerTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-10-25ColdFire 5282: Fix external flash boot and return dramsizeTsiChungLiew
2007-08-18Coding style cleanupStefan Roese
2007-08-16ColdFire: Add M5253EVBE platform for MCF52x2TsiChungLiew
2007-08-16ColdFire: MCF52x2 updateTsiChungLiew
2007-07-10cpu/ rtc/ include/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09cpu/m*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04cpu/ non-mpc*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-01-23[ColdFire MCF5271 family] Add CPU detection based on the value of ChipBartlomiej Sieka
Identification Register (CIR).
2006-12-20Preliminary support for the iDMR board (ColdFire).Bartlomiej Sieka
2006-09-04Merge with /home/m8/git/u-bootWolfgang Denk
2006-06-10Minor code cleanup.Wolfgang Denk
2006-06-10Merge with /home/hs/U-Boot/u-boot-devWolfgang Denk
2006-05-10Minor cleanup.LABEL_2006_05_10_1800Wolfgang Denk
2006-05-09Fix watchdog issues for ColdFire boards.Wolfgang Denk
