path: root/cpu/mcf52x2/fec.c
2007-08-16ColdFire: MCF52x2 updateTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-07-10cpu/ rtc/ include/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09cpu/m*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04cpu/ non-mpc*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-09-04Merge with /home/m8/git/u-bootWolfgang Denk
2006-06-10Minor code cleanup.Wolfgang Denk
2006-06-10Merge with /home/hs/U-Boot/u-boot-devWolfgang Denk
2006-04-20Add MCF5282 support (without preloader)Heiko Schocher
relocate ichache_State to ram u-boot can run from internal flash Add EB+MCF-EV123 board support. Add m68k Boards to MAKEALL Patch from Jens Scharsig, 08 Aug 2005
2006-01-26Add support for Freescale M5271 processorZachary P. Landau
2005-12-04Code cleanup, especially MIPS for GCC 4.xWolfgang Denk
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2004-02-12* Some code cleanupwdenk
* Patch by Josef Baumgartner, 10 Feb 2004: Fixes for Coldfire port * Patch by Brad Kemp, 11 Feb 2004: Fix CFI flash driver problems
