path: root/cpu/mcf5227x
2009-03-17ColdFire: PLATFORM_CPPFLAGS updates for new compilerTsiChung Liew
Update PLATFORM_CPPFLAGS to accept 4.3.x version of ColdFire compiler. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-12-06Update U-Boot's build timestamp on every compilePeter Tyser
Use the GNU 'date' command to auto-generate a new U-Boot timestamp on every compile. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-11-03ColdFire: Fix compilation errorTsiChung Liew
The error was caused by the change for strmhz() in cpu.c. A few of them were one extra close parenthesis. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-11-03ColdFire: Add SBF support for M52277EVBTsiChung Liew
Add serial boot support Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-10-21Use strmhz() to format clock frequenciesWolfgang Denk
2008-08-28ColdFire: I2C fix for multiple platformsTsiChung Liew
2008-07-11ColdFire: Fix incorrect define for mcf5227x and mcf5445x RTCTsiChung Liew
Rename CONFIG_MCFTMR to CONFIG_MCFRTC to include real time clock module in cpu/<cf arch>/cpu_init.c Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-05-03Revert "ColdFire: Get information from the correct GCC"Wolfgang Denk
This reverts commit b7166e05a513c0806b63b9dfb6f1d77645cede2a (replaced by commit c4e5f52a58d278eebb87f476e353972c5dacea40).
2008-04-30ColdFire: Get information from the correct GCCTsiChung Liew
Signed-off-by: Kurt Mahan <kmahan@freescale.com> Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-03-31ColdFire: Fix alignment issue after CONFIG_IDENT_STRING in start.STsiChung Liew
When the version_string function in start.S is not 4-byte align, it will cause the compiler generates "unaligned opcodes detected in executable segment". This issue affects all ColdFire CPUs. By adding .align 4 after CONFIG_IDENT_STRING, it will pad 0's if it is not aligned. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-01-17ColdFire: Add MCF5227x cpu and MCF52277EVB support-2TsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
