This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Move duplicated exception handling code into lib_arm.
Signed-off-by: Andreas Engel <andreas.engel@ericsson.com>
enables the RTS signal with CONFIG_SERIAL_RTS_ACTIVE.
No handshaking is done, but the active RTS signal allows to
connect to the target using a PC which is using RTS/CTS
handshake, and does no harm if the PC is set to ignore RTS.
Signed-off-by: Michael Schwingen <michael@schwingen.org>
allow to load the microde from flash or ram by download it through
the serial or other.
the following patch adds support to move the IXP42X NPE firmware to a
separate flash block, whose start address is defined in
CONFIG_IXP4XX_NPE_EXT_UCODE_BASE. Using that, it is possible to build
NPE-enabled u-boot without copyright problems due to the NPE firmware.
I hope the patch applies, I get whitespace-related differences in the NPE
files due to trailing whitespace in the original versions.
Change return values of init() functions in all Ethernet drivers to conform
to the following:
>=0: Success
<0: Failure
All drivers going forward should return 0 on success. Current drivers that
return 1 on success were left as-is to minimize changes.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Acked-By: Timur Tabi <timur@freescale.com>
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
Patch by Stefan Roese, 14 Jun 2006
- Add IXP4xx NPE ethernet MAC support
- Add support for Intel IXDPG425 board
- Add support for Prodrive PDNB3 board
- Add IRQ support
Patch by Stefan Roese, 23 May 2006
[This patch does not include cpu/ixp/npe/IxNpeMicrocode.c which still
sufferes from licensing issues. Blame Intel.]
Correct addessing errors in platform files.
Split off common core module data from Integrator header files to
include/armcoremodule.h.
Patch by Peter Pearse, 04 Oct 2005
Import "cc-option" shell function from kernel and
use it to get the correct ARM GCC options for individual CPUs
Patch by Peter Pearse, 30 Jun 2005
Patch by Joe <lgxue@yahoo.com>, 13 Jan 2005
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards
- introduce two new configuration options instead:
CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT
Declare reset_cpu() in include/common.h instead locally
* Patch by Richard Woodruff, 10 Jan 2005:
Update support for OMAP2420 (ARM11) and H4 board:
o clean up and add new types to H4 memory probe code.
o fix to work with internal boot.
o added PRCM config III operation.
o fix marginal flash timings.
o add revison ATAG usage.
o enable voltage scaling at power chip.
o fix compile error for i2c.
* Fix network problem (error when receiving multiple ARP packets)
Reset monitor size back to 256 so environment can be written
to flash on MPC85xx ADS and CDS releases.
* Patch by Paolo Broggini, 02 Sep 2004:
Make BSS clearing on ARM systems more robust
* Patch by Yue Hu and Joe, 01 Sep 2004:
- add PCI support for ixp425;
- add EEPRO100 suppor tfor ixdp425 board.
* Fix problem with protected sector detection in driver/cfi_flash.c
Fix clear_bss code for ARM systems (all except s3c44b0 which
doesn't clear BSS at all?)
ARM memory layout fixes: the abort-stack is now set up in the
correct RAM area, and the BSS is zeroed out as it should be.
Furthermore, the magic variables 'armboot_end' and 'armboot_end_data'
of the linker scripts are replaced by '__bss_start' and '_end',
resp., which is a further step to eliminate unnecessary differences
between the implementation of the CPU architectures.
* Patch by Kyle Harris, 30 Oct 2003:
Fix build errors for ixdp425 board
* Patch by David M. Horn, 29 Oct 2003:
Fixes to build under CYGWIN
* Get IceCube MGT5100 working (again)
- Added Motorola CPU 8540/8560 support (cpu/85xx)
- Added Motorola MPC8540ADS board support (board/mpc8540ads)
- Added Motorola MPC8560ADS board support (board/mpc8560ads)
* Minor code cleanup
* Make 5200 reset command _really_ reset the board, without running
any other code after it
* Fix flash mapping and display on P3G4 board
* Patch by Kyle Harris, 15 Jul 2003:
- add support for Intel IXP425 CPU
- add support for IXDP425 eval board
